[Solved] Karcher HDS 610 User Manual, Control Panel Lights Explanation & First Flashing Light Meaning
sparkson 10806 3
  • #1 17035602
    sparkson
    Rate: 11
    I am looking for a user manual, or at least a description of the lights on the Karcher HDS 610 panel, especially which means the first one is flashing.
    I enclose a photo of the lamps that interest me.
  • #2 17036130
    mateov3000
    Help: 50
    Rate: 29
    The manual should say what they mean exactly, but I do not see it, so I suspect that it is a clogged lance nozzle or too little pressure of water entering the washer, or oil level if it has a pump lubrication tank or the cleaning agent is running out if it has a tank for the agent, but that's only my suggestions because I personally do not have a pressure washer.
  • #3 17443802
    sparkson
    Rate: 11
    The first one informs about the lack of liquid preventing the coil from calcification. The lower one is about engine overheating.
  • #4 17443803
    sparkson
    Rate: 11
    Added after 38 [seconds]:
    As in the post above.
