[Solved] Forgot Password & No Volume Buttons: Hard Resetting selecline MID11Q9L Tablet (with Picture)
hcn 29889 10
How can I hard reset or remove a forgotten password from a Selecline MID11Q9L tablet that has no volume buttons?
Reset it by flashing the correct firmware with PhoenixUSBPro/PhoenixCard; for A33 tablets, PhoenixUSBPro is the recommended tool, and if the tablet has a HOME button you can try holding HOME + POWER on the powered-off tablet for a few seconds [#17041276] If USB flashing does not start, prepare a microSD card with PhoenixCard, burn the image to the card, insert it into the tablet, and start it from there [#17040143][#17040632] Do not short the SDA/SCL/INT/RST pads, because they are not the reset method here [#17040632][#17048332] The thread also notes there is no reset hole/button visible on this unit [#17041326][#17048332] Make sure you use the correct firmware image, because a wrong one can boot in French and leave the touch panel not working [#17048499][#17048628]
  • #1 17039622
    hcn
    Rate: 17
    Tablet as in the title.
    The tablet has no volume down / up, but it has a password that the client forgot. I was looking for and even found a softa, but in order to do it, I have to have USB debugging and I'm in the middle of it. I found sda, scl, int, RST on the output board. I tried to close something, but nothing.
    I attach a picture. Maybe you know how to reset the damn thing?
    Thanks
  • #2 17040143
    nutergsm
    Help: 1034
    Rate: 1665
    Upload the firmware using an SD card prepared with the PhoenixCard program, or use the PhoenixUSBPro program.
    Tablet has a Back button?
    gradek83
    Help: 930
    Rate: 2104
    hcn wrote:
    sda, scl, int, RST
    Do not break anything there!
    Run the PhoenixSuit program during startup, you can install the driver install it. After turning on, click on the Firmware anchors and load the software for your tablet, then attach the tablet there will appear the procedure but because you do not have the buttons and if the upload does not move the needle marked pins 7 and 8 on the memory nand and the MIC microphone have a reset button after pressing it for 5s release it and after 2s release the needle should initialize the new device drivers you have in the directory PhoenixSuit_V1.10 \ Drivers \ AW_Driver \.
    If it does not move then plug the card under the micro SD card reader and plug in USB on the PC and run the PhoenixCard program select the drive letter of this card select the file system that you want to upload to the card Img File select Format to Normal as it will format press on Burn. The card must be large enough to accommodate the system image. When the process is finished, remove the card and put it in the tablet and press reset for 3s should the installation of the new system start from the card.
    • PhoenixCard_V3.1.0_20130618.zip (2.3 MB) You must be logged in to download this attachment.
    • PhoenixSuit_V1.10.zip (16.44 MB) You must be logged in to download this attachment.
  • #4 17041120
    hcn
    Rate: 17
    thanks for the answer.
    Where is the reset button here? Do you need to make a record?
    Added after 6 [minutes]:
    The tablet has a POWER button and probably HOME.
    There is no combination to make an android wipe?
    nutergsm
    Help: 1034
    Rate: 1665
    For the tablets with the A33 processor only the PhoenixUSBPro program.
    In that case, hold the HOME button and then the power button on the off tablet for a few seconds.
    gradek83
    Help: 930
    Rate: 2104
    There, when you showed the picture in the marked place, there is no button or small hole? But from what I see is a POWER button
  • #7 17048332
    hcn
    Rate: 17
    error Forgot Password & No Volume Buttons: Hard Resetting selecline MID11Q9L Tablet (with Picture)
    Unfortunately it does not work
    Added after 47 [second]:
    Unfortunately, there is no reset.
    nutergsm
    Help: 1034
    Rate: 1665
    But can the firmware be loaded into one of the programs or does it crash?
  • #9 17048356
    hcn
    Rate: 17
    The pheonixcard is: write mode: product, startup burnkey - which one to choose?
    After uploading firmwar (and a good one) it is in French and the touch does not work.
    http://www.doc-doapi.com/EM/selecline/tablet/861894/
    I uploaded via pheonixcard with the option "product"
    nutergsm
    Help: 1034
    Rate: 1665
    So it looks like you've uploaded a bad firmware.
  • #11 17048628
    hcn
    Rate: 17
    I uploaded a good one because the tablet has such markings:
    and I uploaded this firmware:
    http://www.doc-doapi.com/EM/selecline/tablet/...4/sun8iw5p1_android_yh11q9_uart0_sig_0715.rar
    but then I looked for a different model name and it seems to me (because it works) that what I uploaded later is OK:) and the link to it is:
    http://www.doc-doapi.com/EM/selecline/tablet/875313/875313PO672346and674561and675375.rar
    maybe somebody else will need it:
    firmware to
    MOTOCULTURE
    auchan
    garden star
    inexive
    lazer
    qilive
    SELECLINE
    Best regards and thanks for your help!
The discussion revolves around resetting a Selecline MID11Q9L tablet that lacks volume buttons and has a forgotten password. Users suggest using the PhoenixCard or PhoenixUSBPro programs to upload firmware via an SD card. One user mentions the possibility of using a reset button located near the microphone, while others discuss the need to hold the HOME and POWER buttons for a hard reset. The conversation also touches on issues with firmware uploads, including incorrect firmware leading to language and touch functionality problems. Users share links to firmware files and emphasize the importance of using the correct version for the device.
