Best OBD II Diagnostic Tester Under PLN 300: Error Diagnosis, Throttle Voltage, Lambda Probes
John5MM 7563 5
  • #1 17123695
    John5MM
    Level 19  
    Rate: 402
    Hello, is there something worth recommending for such money? I am referring to error diagnosis and deletion, reading of components, e.g. throttle voltage, lambda probes, flowmeter and similar components, I do not want to download the software. Can you recommend something?
  • #2 17123718
    ireneusz1981
    Level 19  
    Help: 26
    Rate: 82
    Would you need more for one brand or more? and whether you are only interested in engine or ABS diagnostics, counter, Airbag, and others. Do you want a device with a display, or can it be, for example, an Android phone? In general, diagnostic toys after the engine itself are a lot. So specify something else.
  • #3 17123740
    John5MM
    Level 19  
    Rate: 402
    First of all, I care about the functionality and capabilities of various software, as I wrote, it is about diagnostics of individual car components, lambda probe flowmeter, catalyst, engine components, but to make it a more professional device than a bullion for PLN 30 showing fuel consumption and tachometers, it may have display, not quite for android, first of all usability as much as possible.
  • #4 17123833
    ireneusz1981
    Level 19  
    Help: 26
    Rate: 82
    I use a multimeter and oscilloscope to test and diagnose individual car components, lambda sensor flowmeter, catalyst, engine components. And for clearing error codes and carrying out adaptations we have at kts + FSA, carman, launch x341 stations and with these devices we are not able to comprehend all the cars. It will be hard to find such a universal device.
  • #5 17123901
  • #6 17123910
    ireneusz1981
    Level 19  
    Help: 26
    Rate: 82
    A good multimeter can cost more and do more.
