[Solved] Suspected Unauthorized Connection: Apator Corax 1 Meter - Monitoring Consumption in Block of Flats
Qooglarz 24036 3
  • #1 17233301
    Qooglarz
    Good morning,
    I live in a block of flats and I suspect someone has hooked up to my installation.
    I want to turn off all devices and check on the meter if there is any consumption, but I don't know how to check it on the electronic meter.
    The meter model is Apator Corax 1.
    Is it possible to check the consumption yourself?
    Thank you in advance for any help.
    kj1
    Electrician specialist
    Help: 278
    Rate: 850
    There should be a diode (red) on the meter that flashes when energy is being consumed. It is also described how many "flashes" are per kWh. When you turn off all receivers, the LED should not flash.
    bartekfigura
    Level 30  
    Help: 112
    Rate: 525
    There's an even better way ... Corax / Norax meters are equipped with a consumption indicator. on the display at the top is the symbol L1 it symbolizes the flow of phase to the meter and above this symbol is an arrow pointing to the right when there is consumption when there is no consumption on the recipient side, the arrow disappears.
  • #4 17233748
    Qooglarz
    I checked the diode and arrow, everything is correct.
