Activating Bluetooth and Pairing Phone with Radio in Iveco Daily 2016: A Comprehensive Guide
Rafal235467 230472 7
  • #1 17240986
    Rafal235467
    Rate: 16
    How do you connect the radio to your phone to use the handsfree option in this car? On the steering wheel I have buttons for answering phone calls and disconnecting, and the radio has a bluetooth inscription, so somehow I can probably. Does anyone know how to pair it? I will add that the phone does not 'see' the radio in this car. How to turn on bluetooth on this radio?
  • #2 17241154
    Pedros050
    Help: 2471
    Rate: 3930
    Hello. The model and brand of this radio?
  • #3 17244350
    Rafal235467
    Rate: 16
    The radio is factory, the simplest one that has been installed in those of the Iveco Daily since 2014.
  • #4 17285442
    kamil1235k.m
    Rate: 26
    Buddy, you go to the Menu and there is the BT on option or something, BT turns on (the icon pops up) in the radio, then you look for it with the phone and connect, ask for a code that will be displayed on the radio. And then the radio should have the instructions attached to the vehicle.
  • #5 17474238
    boniek55
    Rate: 22
    On the radio, press the menu key until the BT MODE option pops up and turn the potentiometer to the ON option.
    Another option in the menu is BT PAIR, it must jump on VISIBLE.
    Ready.
    The radio is already visible, now search by phone and enter the code displayed on the phone into the phone.
  • #6 17640794
    sroger
    Rate: 57
    Ready.
    I do not have this option BT PAIR and therefore I can not search for it.
  • #7 17641319
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1710
    Check that there are no maximum phones assigned to the radio.
  • #8 17641328
    sroger
    Rate: 57
    How to check?
    Added after 10 [hours] 32 [minutes]:
    One important thing, the car cannot set up, it must stand.
    Then an additional BT PAIR option appears.
    There is only BT MODE ON or OFF while driving.
    Anyway, I set it up.
To connect the factory-installed radio in the 2016 Iveco Daily to a phone for hands-free use, users should access the radio's menu and enable Bluetooth (BT) mode. This involves navigating to the BT ON option and ensuring the radio is set to visible for pairing. If the BT PAIR option is not available, it may be due to the vehicle being in motion; the car must be stationary for the pairing option to appear. Users should also check if the maximum number of paired devices has been reached. Once the radio is visible, the phone can search for it and connect using the code displayed on the radio.
