Ford Focus MKII 6000CD – what Bluetooth PIN for ZTE Blade III?
proenergia 105411 11
What Bluetooth PIN should I use to pair a ZTE Blade III with Ford Audio in a Ford Focus MKII 6000CD, and where do I enter it?
Use the Bluetooth PIN 0000, and enter it from the phone by choosing the option to add or pair a device [#12877436][#12877782] If the phone does not ask for a code or pairing still fails, remove the previously stored phone entries from the car’s Bluetooth memory first [#12896158] In this case, the previous owner had already filled all six memory slots, and deleting them made pairing work normally [#12896158]
  • #1 12877335
    proenergia
    Rate: 33
    I turned on bluetooth on the radio and in the phone and the phone detects "Ford Audio", unfortunately when I click connect, it pops up that there is an incorrect connection code and unfortunately I do not know what code to enter and where to enter it at all.
    I am using a ZTE Blade III phone
  • #2 12877436
    coperfild
    Help: 291
    Rate: 1697
    It should be 0000
  • #3 12877527
    proenergia
    Rate: 33
    Thanks, but do you know where I should enter this code? No message pops up for me to enter this code.
  • #4 12877782
    coperfild
    Help: 291
    Rate: 1697
    On your phone, you must have add or pair a device.
  • #5 12896158
    proenergia
    Rate: 33
    It turned out that the previous owner of the car had already entered 6 numbers in the memory and I had to remove them and then the connection with the teelfon worked without any problems. I could ask the seller right away ;) Thank you for your help!
  • #6 13038247
    adiksutil16
    Rate: 67
    And how to run bluetoth on the radio, I just bought a focus mk2 and can't connect.
  • #7 13039487
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1709
    adiksutil16 wrote:
    And how to run bluetoth on the radio, I just bought a focus mk2 and I can't connect.
    And is it bluetooth in the car?
  • #8 13040456
    adiksutil16
    Rate: 67
    I do not know. When he searches by phone, he does not find it, but the radio has a Green and Red receiver.
  • #9 13041079
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1709
    adiksutil16 wrote:
    but the radio has a Green and a Red handset
    The radio is bluetooth capable, but the module is separate from the radio - it may not be there.
  • #10 14160311
    dejna33
    Rate: 26
    hello and how to check if the radio has such a module to pair with the phone and where on the radio you can check if it has bluetooth thanks for the info
  • #11 14259313
    michael_777
    Rate: 30
    The module should be located behind the passenger glove box at the top. I have the same problem, I have a balupunkt radio travelpilot fx - the module is mounted as I wrote behind the passenger glove compartment, the microphone is factory-placed in the headlining between the lighting and I cannot connect to the bluetooth with the car. I don't know what might be playing. Maybe someone knows?
  • #12 16070970
    zmijka121
    Rate: 70
    And how to delete these phone numbers because I have the same problem?
The discussion revolves around connecting a ZTE Blade III phone to a Ford Focus MKII's 6000CD radio via Bluetooth. The user initially encounters an incorrect connection code issue when attempting to pair the devices. Responses suggest that the default code is "0000" and that the user should initiate the pairing process from their phone. It is later revealed that the previous owner had stored multiple connection codes, which needed to be cleared for successful pairing. Additional inquiries about enabling Bluetooth on the radio and checking for the necessary Bluetooth module indicate that the module may be located behind the passenger glove box. Users also express concerns about deleting stored phone numbers from the radio's memory.
