Vin Check: Swift Audi Verification - WAUZZZ4F78N047697 Car Assistance Requested
sarnas 52011 10
How can I verify an Audi's history and equipment from its VIN, including whether it is S line?
You can’t get a complete free VIN check from VIN alone; the Polish vehicle-history site needs the registration number and the first registration date in Poland, and otherwise a full Audi report is usually paid [#17272602] [#17272614] [#17272649] For quick decoding, people suggested myAudi or online VIN decoders such as vin-decoder.net and similar Audi/VW tools [#17273141] One posted decode for this VIN shows an Audi A6 Avant quattro with a 3.0 TDI 171 kW engine, tiptronic, and equipment like sports suspension (1BE), sports front seats (Q1D), and a sports steering wheel (1XW) [#17272763] However, the posted list does not explicitly name an S line package, so it’s better used as an equipment-code check rather than proof of S line [#17272763]
  • #1 17272536
    sarnas
    could someone check me a car? I will be very grateful
    WAUZZZ4F78N047697
  • #2 17272563
    yanes
    Help: 211
    Rate: 610
    You pay for it, probably there is no such thing as doing it for free.
  • #3 17272568
    DiZMar
    Help: 2892
    Rate: 6652
    But there is no time to pay. Checking needed quickly :wink: :!:
    TERMAT:
    vin- check the audi quickly
    WAUZZZ4F78N047697
  • #5 17272614
    DiZMar
    Help: 2892
    Rate: 6652
    E8600 wrote:
    Only in addition to the VIN, you need a registration number and the date of first registration in Poland.
    After the VIN itself, as it was previously written only for a fee.
    So much free.
  • #6 17272649
    yanes
    Help: 211
    Rate: 610
    How cool Audi is worth it to pay 50 PLN, I did it myself and I got everything, equipment description and service entries with ASO. Those who decode vin search the forum A 4 or A 5.
  • #7 17272763
    sarnas
    ktos mi znajdzie czy to s line?
    E0ASpecial editions: Without special action equipment
    1PDLockable wheel bolts: Wheel bolts with anti-theft protection (unlockable)
    0HPVehicle class differentiation units/platform components: Vehicle class differentiation -4F0-
    5P0Mounting fixture for oxygen bottle: Without mounting fixture for oxygen bottle
    7GGEmission standard: Emission standard EU4 DPF
    1D0Trailer hitch: without trailer towing
    4UEairbag: driver and front passanger airbags
    0W1Label for central electric: Label for central electric system German-speaking countries
    QE1Tray areas package: Storage compartment package 1
    6XDExterior mirror setting: Exterior mirrors, power-adjustable/ heated
    5SLLeft exterior mirror: Left exterior mirror, aspherical
    6TSRight exterior mirror: Right exterior mirror: aspherical, large viewing field
    1X1Drive type: Four-wheel drive
    A8SEquipment levels: Standard equipment
    1KDBrake type in rear: Disc brakes in rear
    J0Zbatteries: Battery 520 A (110 Ah)
    1LGBrake type, front: Disc brakes in front
    6FAComponents with special surface: Components without special surface
    QF0Receiver (car phone): Without receiver (car phone)
    NY0Battery/alternator capacity: Standard battery/alternator capacity
    B0AComponent part sets with country-specific design requirements: build parts set without county specific documentatio
    1S1vehicle tools and jack: vehicle tools and jack
    0VCOwner's manuals: Information kit in German
    7QTCD ROM/DVD/SD card: CD ROM (Europe)
    7A2CD changer/CD player: CD changer
    C17General operating permit, alterations: Operating permit, alteration
    2D0Cd enhancing underbody panel: Without cd enhancing underbody panel
    1BEShock absorption/suspension, chassis: Sports suspension/shock absorption
    3S1Roof rails/roof load rack: Bright roof rails
    3FERoof insert/convertible top: Tilting and sliding glass sunroof with sunbshade
    3X0Load-through hatch/ski bag: without load through system
    2G0Insert for the filling up of unleaded fuel/fuel type: Without insert for the filling up of fuel
    7AATheft protection system: Electronic immobilizer
    5MGInserts: Decorative inserts, burr-walnut
    7M1Scuff plates: Scuff plates in door apertures with metal inserts
    7X1Park distance control: Park distance control
    GZ0Power-operated door (power latching): door, manually operated
    4R4window regulator: Power windows with comfort operation and circuit breaker
    5NHHood and trunk stay: Tailgate vent lock
    8K9Headlight activation: Daytime headlights with automatic headlight control and coming home function
    1C1Antifreeze: Antifreeze up to -25 degree Celsius tolerance up to -30 degree C
    F0AVehicle specifications: No special purpose vehicle, standard equipment
    VY0Danger alarm system: Without danger alarm system
    8GVAlternators: Alternator 180 A
    0G7Transmission types/gearshift mechanisms: tiptronic
    0YKWeight category rear axle: Weight range 10 installation control only, no requirement forecast
    0JLWeight category front axle: Weight category front axle weight range 11
    T41Base engine: 6-cylinder diesel engine 3.0 l unit 059.D
    6M1Tie down straps/net/pocket: Tie down straps
    8T1cruise control system: Cruise control system (CCS)
    VC0Garage door opener: without Garage door opener
    5A5Luggage compartment trim: Luggage compartment trim, with storage compartments
    G0RTransmission specifications: 6-speed automatic transmission for four-wheel drive
    6V1Rear trim panel: Rear trim panel (ECE)
    A51Manufacturer: Audi AG
    5J0Rear spoiler: Without rear spoiler
    0N5Rear axle: Standard rear axle
    6NJMolded headliner: Standard molded headlining
    3NZRear seats: Rear bench seat, not split, split backrest, folding
    9AQHeating and air-conditioning system: Air conditioning plus
    8EDHeadlamps: Bi-functional headlamps with gas discharge lamp, for driving on the right
    FC0Customized installation: Without individual installation
    U2AInstrument clusters: Instrument cluster with km/h speedometer, radio clock, tachometer and trip odometer
    4L6Breakaway interior rearview mirror: Breakaway interior rearview mirror, auto-dimming
    K8DBody style: Wagon/Avant
    6SSLuggage compartment floor covering: Luggage compartment floor covering
    4W0Cassette and CD storage unit: without cassette / CD tray
    0M5Fuel tank capacity: Fuel tank
    4H3child safety: Manual child lock
    4D0Seat ventilation/massage seat: Without seat ventilation/massage seat
    1Z2Fuel quantity for initial filling: Increase in initial standard fuel filling
    0F3Fuel systems: Fuel system for diesel engine
    5C0Body measures: Without special body measures
    3G0Child seat anchors in front: Without child seat anchora in front (ISOFIX)
    6W6Front license plate bracket: Front license plate bracket
    5K0Paint preservative/transit coating: Without surface protection, with additional transit coating
    3GDRear cargo area: Plane rear cargo area
    QQ1Light package (lighting): With additional lights (interior lighting)
    L0LSteering system arrangement: Left-hand drive
    1N3steering: Speed-related variable steering assist (Servotronic)
    7P1Lumbar support: Power adjustable lumbar support in front seats
    1XWsteering wheels: Leather-wrapped multi-function sports steering wheel
    9VDSpeaker installation: active loudspeakers
    2C5Steering column systems: Steering column, adjusted axially and vertically
    8Q5Headlight range control: Dynamic headlight range control, with cornering light (AFS 1)
    6E3Center armrest: Front center armrest
    FM0Versions: Basic equipment variant
    9Q4Multi-function display/trip computer: Multi-function display/trip computer with check control
    8Z5Engine cooling: not hot country
    D1DEngine specifications: 6-cyl. turbo diesel engine 3.0 l/171 kW (24V) V6 TDI, common rail base engine is T41
    7Q2Navigation device: navigation system with colour screen
    8TFrear fog lamp: Rear fog lights, left and right
    FQ0Audi Sport/ Quattro GmbH: Series wheels
    AQ0Quality class: Standard-production quality
    C5GWheels: Alloy wheels 8J x 18
    8YQRadios: Radio "HIGH"
    7K0Tire pressure monitoring system: Without tyre pressure monitor
    HE6tire: Tires 245/40 R18 Y
    V0ATire suppliers: Tires without specification of tire brand
    1G8Spare wheel/breakdown kit: Breakdown kit
    9LASurround sound combination/rotating beacon light: Without rotating emergency lights
    PACstorage package
    PNANavigation system with DVD incl. MMI
    PRFCast aluminium alloy wheels, 8Jx18, 7-arm design, with 245/40 R 18 tyres
    PS1--
    PXA--
    WDBBusiness plus package
    WDCBusiness package
    YOAcontrol number
    4X3Side airbag: Side airbag in front, with curtain airbag
    7F9Gearshift knob/handle: Gearshift knob/handle in plastic/leather
    A00Self-collection / special control: No self-collection
    2KRSpecial labels/plates: Labels in English and German
    8SKTail lamp assemblies: Taillight assemblies with diodes (LED)
    4E0Locking mechanism for boot lid/cover rear: Tailgate/trunk lid unlocking from outside
    2K1Bumper systems: bumper reinforced
    9P3Seat belt check: Seat belt reminder, electric contact in buckle
    N5Wseat covers: Seat trim covers in leather
    3L3Seat adjustment: Manual height adjustment for front seats
    4A3seat heater: seat heating for front seats separat controlable
    0LWSafety certificate: With special labels safety certificates for Germany
    5XCsun visors: Sun visors, with vanity mirror illuminated on driver's and front passenger side
    VX0Voice enhancer: Without voice enhancer
    QH0Audio-response system/voice control: without voice control
    7Y0Lane change assist/lane keeping system: no lane change assistant
    4KCSide and rear windows: Side and rear windows in heat-insulating glass
    3Y0Sunroof roller blind for rear/side windows: without roller blind
    7B2power outlet: 12 volt socket in luggage compartment
    FA0Handling production and pre-production: Control of standard production
    8X1Headlamp washer system: Headlamp washer system
    3M3Special approval measures: Passenger car design
    4K4Door and lid locking system: Central locking w/ radio remote control
    B01Type approval countries/countries with special requirements: Type approval country Germany
    5D7Carrier frequency for remote control: Carrier frequency 868 MHz without panic button
    NT0Transit coating: Transit coating (type 1)
    QV0TV reception/digital radio reception: without TV/digital radio reception
    1VHAssembly parts for engine (drive bearing): Assembly part for 6-cyl. engine
    1SAFront underbody guard: Without additional front underbody guard
    1EXIdentification plates: Special identification plate for EU
    2Z1Type sign: Type sign at rear and "Quattro" nameplates respectively
    1T3First aid kit / warning triangle: First aid kit with warning triangle
    Q1DFront seats: Sports front seats
    4Y0Storage compartment -- veneered key storage box: Without storage compartment/safe box
    9ZFTelephone / telematics: preperation for mobile phone with hands free teleph.
    4GHWindshield Glass: Windshield in heat-insulating glass with sunshield
    2WAAdditional tires (snow tires): without spare tyre
    0TDfloor mats: Front and rear floor mats
    4ZBDecorative trims: Bright decorative trims
    3B4Additional child seat anchors: Child seat anchors for child seat system ISOFIX
    6U0Additional dust seals: Without additional seals outside
    9M0Auxiliary heating system: Without auxiliary heater/parking heater
  • #8 17272817
    DiZMar
    Help: 2892
    Rate: 6652
    Who and what should you find? You want to translate it to yourself here .
  • #11 17273214
    johny222
    Help: 6
    Rate: 63
    I do not understand if you are going to buy a car with only vin or how?
    Because if you already have this audi and you can have a look, I do not know what the problem is.
    Examples:
    https://a4-klub.pl/topic/64881-pakiet-s-line-zewn%C4%99trzny-i-wewn%C4%99trzny/
    https://www.a3-club.net/forum/showthread.php?5376-8L-Jak-Rozpozna%E6-Audi-S-Line
    https://a6forum.pl/s-line-po-czym-rozpoznac-ze-mam-lub-nie-t1576.html
A user requested assistance in verifying the VIN WAUZZZ4F78N047697 for an Audi vehicle. Responses indicated that while free checks are limited, several online resources can be utilized for vehicle history verification, including the Polish site for vehicle history. Users noted that additional information such as the registration number and date of first registration may be required for comprehensive checks. Some participants shared links to various VIN decoding websites and emphasized the value of paying for detailed reports, which can include equipment descriptions and service history. The discussion also touched on identifying whether the vehicle is an S-Line edition, with suggestions to refer to specific Audi forums for guidance.
