Audi a3 paint code after VIN - Will someone find the paint code? Because it is n
DjPaczu 31812 8
  • #1 17364186
    DjPaczu
    WAUZZZ8LZVA075742
  • #2 17364222
    KapitanSTS
    Level 30  
    Help: 115
    Rate: 274
    From what I remember, the color should be in the spare wheel. Personally, I do not check if it is because I have LPG installed.
  • #3 17364224
    DjPaczu
    I do not have it at all
  • #4 17364234
  • #7 17364981
    KapitanSTS
    Level 30  
    Help: 115
    Rate: 274
    Try to decode your VIN. If you do not enter it, you can compare it with yours.
  • #8 17514918
    Zendzen
    Rate: 14
    Please help. What is the paint code for the following VIN: WAUAGAFD4EN011672
  • #9 19635636
    Julopl
    Please help :) I cannot read the paint code in my A3 (stickers broken) WAUZZZ8P05A117823
The discussion revolves around finding the paint code for an Audi A3 using the VIN WAUZZZ8LZVA075742. Participants suggest checking the spare wheel for the color code and mention that the paint code may also be found in the service book or on the nameplate. They recommend providing a photo of the car for better assistance and suggest that custom paint sellers might help based on the VIN. A link to a resource for paint codes is shared, and there are inquiries about decoding the VIN for paint information. Other users also seek help for different VINs, indicating a common issue with locating paint codes in Audi A3 models.
