Anida vs ATX Platinum Battery for Samsung Omnia HD: Which Replacement Option is Best?
Ojciec25 3045 4
  • #1 17279354
    Ojciec25
    Hello all
    I am trying to buy a battery for a samsung omnia HD phone. Recently I bought a new one from Maxximus - it turned out to be faulty - the phone did not want to charge at all
    I know that the original best ones, but on the Allegro, they are 50 PLN
    I am looking for a replacement for my phone on Allegro - but there is a small selection,
    I am thinking of buying ATX platinum or Andida, or no name for PLN 35
    Photos for the battery below in the attachments
    Which battery would you recommend to me
    Thank you for your reply. Regards!
    • Anida vs ATX Platinum Battery for Samsung Omnia HD: Which Replacement Option is Best? bateria do samsunga.PNG (267.39 KB) You must be logged in to download this attachment.
    • Anida vs ATX Platinum Battery for Samsung Omnia HD: Which Replacement Option is Best? bateria andida.PNG (187.93 KB) You must be logged in to download this attachment.
    • Anida vs ATX Platinum Battery for Samsung Omnia HD: Which Replacement Option is Best? bateria ATX.PNG (565.16 KB) You must be logged in to download this attachment.
  • #2 17279366
    electron123
    Rate: 20
    Buying replacements for a good battery is a good idea. It also depends on what capacity you need. I bought an ATX.
  • #3 17279369
    Ojciec25
    well, I would like the battery to last as long as possible and to serve it for several years
    ATX platinum supposedly has 1500mah Andia like 1800mah-but I know that it is certainly overpriced, this name supposedly has 1500mah
    and do you praise this ATX platinum battery?
  • #4 17279372
    electron123
    Rate: 20
    I just bought.
  • #5 17280602
    electron123
    Rate: 20
    In fact, "counterfeit" batteries are often the same ones, only without their certification. Companies earn a lot of money from it.
