Medion S7852 Tablet: Need DF 3082150 (1ICP3/82/150) 3.7V Li-ion Polymer Battery 4800mAh Replacement
stereo1 8547 6
  • #1 16560998
    stereo1
    I have a Medion S7852 tablet. For some time strange things began to happen to him, the battery stopped to hold gradually (after each charge it worked less). After some time, the battery began to swell, which was manifested by distortions on the screen (it looked like you press your finger on the LCD matrix). I decided to disassemble the tablet, I saw the battery DF 3082150 (1ICP3 / 82/150) 3.7V Li-ion Polymer Battery 4800mAh 17.76Wh 201403 (I attach some pictures to the topic).
    Medion S7852 Tablet: Need DF 3082150 (1ICP3/82/150) 3.7V Li-ion Polymer Battery 4800mAh Replacement Medion S7852 Tablet: Need DF 3082150 (1ICP3/82/150) 3.7V Li-ion Polymer Battery 4800mAh Replacement Medion S7852 Tablet: Need DF 3082150 (1ICP3/82/150) 3.7V Li-ion Polymer Battery 4800mAh Replacement
    The dimensions of the battery measured amateurish are: 3.5 mm thick, 8.3 cm wide and 15.1 cm high (measured together with the yellow tape). Unfortunately, I can't find such a battery. My question: which battery could be a replacement for the factory-fitted one?
    Best regards (please be understanding, this is one of my first topics in this forum).
  • #2 16561009
    Ronin64
    Help: 248
    Rate: 347
    Look for a battery with the same dimensions and capacity. Just check if the removed one has any electronics on the plate under the yellow tape.
  • #3 16561037
    stereo1
    Ronin64 - there is some electronics under the yellow tape, only that no information can be read from them, because the systems are inaccessible to the human eye :)
    I enclose photos so that you can see what's going on.
  • #5 16561093
    stereo1
    Ronin64, thanks for the help, but there aren't these batteries on some Polish portals?
  • #7 16588611
    stereo1
    Solution - I bought the battery from the link above, everything works without a problem.
✨ The discussion revolves around the Medion S7852 tablet, which has experienced battery issues, including reduced charge retention and swelling, leading to screen distortions. The user identified the battery as DF 3082150 (1ICP3/82/150) 3.7V Li-ion Polymer Battery with a capacity of 4800mAh. Suggestions for replacement batteries include ensuring compatibility in dimensions and capacity, with links to potential options on AliExpress and Polish portals. The user successfully purchased a replacement battery from a provided link, resolving the issue.
