Xiaomi Powerbank 20000mAh Problem: Not Charging, Button LED Issues & 3.292V Reading - Solutions?
cross099 18561 15
How can I fix a Xiaomi 20000 mAh power bank that shows about 3.292 V on the cell but does not react to charging, and is the damaged micro‑USB socket still repairable?
The most likely fault is the damaged micro‑USB socket or its soldering, so the power bank is still repairable if the board itself is not badly torn up [#17309434][#17311686] Clean the charging socket and verify the voltage while the charger is connected; an ordinary soldering iron with good flux and a flat tip is enough to replace the socket [#17309434][#17311686] The missing middle pins are not a problem for charging, because only pins 1 and 5 are needed; the other pins are data pins and may only have been for mechanical support [#17314298][#17314591] If the pads under the socket are really gone, the board is harder to repair, but it can still be salvaged by an experienced soldering-iron operator [#17314863] As a workaround, you can bypass the broken charger input and use a TP4056 Li-ion charger board directly on the cell pack, but it will charge at about 1 A and take longer [#17314863] If you want faster charging, a charger module rated up to 3 A with a 5 V, 3 A USB supply was also suggested [#17315378]
  • Battery at 3.292 V suggests protection or charge-port fault
    #1 17309007
    cross099
    Hi.
    I have had a power bank for 3 years and I use it from time to time but it is usually charged. Now I used it more often and I was going to charge it. I used it today and it "ran out of electricity", so when I came home I wanted to connect the powerbank for charging. Unfortunately, it doesn't respond to the charger at all. The button lights up all the LEDs that go out in turn, unfortunately nothing happens when connected. I opened it and after measuring on + and - it shows 3.292 V. Unfortunately, I do not know how to remove the board from the housing to do nothing and verify that the charging socket is OK. 1500 mA charger. What can I do, is it still suitable for something?
  • #2 17309434
    E8600
    Help: 529
    Rate: 2520
    Colleague, measure the voltage on the cell when connecting to the charger will know if there is voltage. Clean the charging socket beforehand.
  • #3 17311679
    cross099
    Ok, I measured it and it turned out so that the battery normally showed 3,292 V after connecting, nothing changed. However, I left electricity for 12 hours and the voltage increased to 3.324V. It made me think, and I looked at the power bank under the microscope. I noticed that the MicroUsb socket would probably be the fault. It seems like 3 out of 5 legs were slightly broken. I was on the site and they sang 60-70 PLN. Little profitable price a bit,
    Can such things be soldered only with hot air? I have a soldering station, tin rosin and solder paste, but I suppose it may not be suitable for such things. Does anyone know where it can be cheaper? Because in total, a bit expensive, 70 PLN as a new power bank is about 120-130 PLN
  • #4 17311686
    E8600
    Help: 529
    Rate: 2520
    An ordinary soldering iron and a good flux, and you can change the socket yourself. I recommend a flat tip to heat all pins at once.
  • #5 17311882
    cross099
    Ok, I bought a gel flux, I also have rosin and tin. I am currently using a ZD-919 soldering station with a standard tip. I was already soldering some cables, I soldered the cables to the boards but the sockets were not, what temperature will not damage the board? Any guides found somewhere wise?
  • #6 17314286
    cross099
    Well, it turned out that the problem is bigger, when I soldered 2 feet that were sticking, it turned out that 2 of 3 feet that were broken do not have solder pads. They just dropped out when the port was pulled out or something can be done about it? Scraping the plate will give something to get to the copper part?
  • #7 17314298
    E8600
    Help: 529
    Rate: 2520
    Insert a picture, but there was not solder fields because they are data pints - not needed to charge the device. For charging you need pins 1 and 5.
  • #8 17314435
    cross099
    Well, I took something quick to see there. If there is a need for better, I will do it in better lighting tomorrow https://photos.app.goo.gl/xhy2SofMQSWdJCrW6
    Moderated By Dzimi:
    Please put photos in accordance with the rules of the forum - it will greatly help in solving the problem.
  • #9 17314591
    E8600
    Help: 529
    Rate: 2520
    Probably there were pins but they were not necessarily functional, they could only stabilize the socket. Wash the plate with flux alcohol and insert a better picture.
  • #10 17314739
    cross099
    Ok, I've seen a little bit if there will be something and I have slightly started this CD. Better photos here https://photos.app.goo.gl/Le1ATy6KnaERMUPJA
    As you can see, even if pins 1 and 5 are responsible for charging, there is no one ...
  • #11 17314863
    E8600
    Help: 529
    Rate: 2520
    I see it black - I don't know if there were any elements next to the socket that you accidentally desoldered. The board is salvageable but for a good soldering iron operator.
    My suggestion to buy a TP4056 Li-ion charging system (cost about PLN 5) and connect directly to the series of cells connected in series. The downside of this solution is that the charging time will be longer because this system gives 1A.
  • #12 17314878
    cross099
    I watched this port again and I don't see anything come out except this port. But OK.
    I will try again today and see what happens.
    Do you have information about these ready enclosures for powerbanks with modules? They cost about PLN 30 for 8 batteries, so I have 6, and I would buy 2, I would have even bigger power banks. Only does it work reasonably well? Because sometimes it charges the phone for navigation and needs a lot of electricity. It shows that they are with 1 port 1a and one port 2a but can you believe it?
    And I wonder how they land ...
  • #13 17314896
    Frog_Qmak
    Help: 7
    Rate: 298
    When it comes to housings, the cheap ones often connect batteries in parallel (without a balancer) - that is, you should not add any other than those that worked in the current charger. Do they work well - it's hard to tell. Probably depends on the model. A very general question
  • #14 17314898
    cross099
    And any recommended housing?
    Or a charging system that will charge this power bank a little faster because now it has landed on the 1500ma charger over 14h
  • #15 17315050
    gumisie
    Help: 1667
    Rate: 2485
    @ cross099 firstly, it would be good to wash the PCB (the place where the micro_USB connector was soldered), then take a picture of "this" place (not the whole power bank) and post according to the rules adopted here on the forum.
    Maybe it will be easier for us to help you.
    Regards
    PS
    Frog_Qmak wrote:
    because already on the 1500mah charger landed over 14h
    If you give some values, they should be given correctly and so for this power supply it is: 1500mA. In addition, this 20Ah powerbank should be charged with higher current (1C)
  • #16 17315378
    E8600
    Help: 529
    Rate: 2520
    Buddy, here you have a charger system with a current of up to 3A.
    https://www.elektroda.pl/rtvforum/topic2685729.html
    If you have a powerful USB charger with a current of 3 A or higher at a voltage of 5 V. The downside is that the system does not have a microUSB port, therefore it requires more combining. It also has an outlet for a protection thermistor, which you have glued to the cells.
    If you have been charging with 1.5 A current so far, at 3 A the charging time should be reduced by half.
The discussion revolves around a Xiaomi Powerbank 20000mAh that is not charging and exhibits LED issues, with a voltage reading of 3.292V. The user initially reports that the power bank does not respond to charging attempts. After measuring the voltage and inspecting the MicroUSB socket, it is discovered that several pins are broken. Suggestions include cleaning the charging socket, using a soldering iron to replace the socket, and considering alternative charging systems like the TP4056 Li-ion charging module. The user also explores options for new enclosures and faster charging systems, with advice on ensuring compatibility and proper charging rates for the power bank's capacity.
TL;DR: Xiaomi 20000 mAh not charging? A 3 A module can cut time by ~50%; "charging time should be reduced by half." Check the micro‑USB pads and measure pack voltage before/after plugging in. [Elektroda, E8600, post #17315378]
Why it matters: This FAQ helps Xiaomi 20000 mAh owners fix no‑charge, blinking‑LED, or ~3.3 V issues and decide between DIY repair, module bypass, or replacement.
Why won’t my Xiaomi 20000 mAh power bank charge even though LEDs cycle?
Start by cleaning the micro‑USB socket with isopropyl alcohol. Then measure the pack voltage while you plug in the charger. If the voltage does not rise, the input path is open or the jack is faulty. This quick test differentiates a dead input from a weak cell issue. Next, inspect the connector legs and anchor tabs under magnification. Replace or re‑solder the socket if legs or pads are cracked. [Elektroda, E8600, post #17309434]
My meter shows about 3.292 V across +/−. What does that tell me?
A reading around 3.29 V that doesn’t increase when you connect the charger indicates the charging path isn’t delivering power. In the thread, the voltage stayed ~3.292 V when plugged in and crept only to ~3.324 V after many hours. That pattern points to a damaged micro‑USB connector or lifted pads. Inspect the jack under a microscope for broken legs or missing pads. [Elektroda, cross099, post #17311882]
How do I confirm the micro‑USB jack is the culprit?
Check which micro‑USB pins still connect to the board. Only pins 1 (VBUS) and 5 (GND) are required for charging. If either is lifted or its pad is gone, the power bank won’t accept charge. Re‑solder those pins or replace the connector and retest. "For charging you need pins 1 and 5." [Elektroda, E8600, post #17314298]
Can I re‑solder the micro‑USB port without hot air?
Yes. Use a standard soldering iron, quality flux, and a flat tip to bridge the pin row efficiently. Clean old solder, align the jack, tack the shell tabs, then drag‑solder the pins with flux. Finish by inspecting for bridges under magnification. "I recommend a flat tip to heat all pins at once." [Elektroda, E8600, post #17311686]
What iron temperature and technique help avoid PCB damage?
Use a moderate iron temperature and short contact time. Pre‑tin the pads and pins, apply gel flux, and let the solder flow quickly. Secure the shell tabs first to avoid pad stress, then solder the signal pins. Clean residues with isopropyl alcohol and re‑inspect. Practice on scrap boards if you’re new to connector work. [Adafruit, 2022]
Two connector pads ripped off. Is the board still repairable?
Yes. With the right skills, the board is salvageable. A careful technician can rework the area and restore connectivity. If you lack experience with pad repairs, consider professional help to avoid further damage. "The board is salvageable but for a good soldering iron operator." [Elektroda, E8600, post #17314863]
Do I need D+ and D− pads to charge this power bank?
No. The power path uses only micro‑USB pin 1 (VBUS) and pin 5 (GND). Missing data pads usually won’t stop charging, though they can affect fast‑charge negotiation on some devices. "For charging you need pins 1 and 5." [Elektroda, E8600, post #17314298]
How do I quickly diagnose the charging path?
Try this: 1) Clean the micro‑USB socket thoroughly. 2) Measure pack voltage, then plug in the charger and watch for a rise. 3) If voltage doesn’t increase, focus on the connector, pads, and input traces. This method confirms whether the charger’s voltage reaches the battery. [Elektroda, E8600, post #17309434]
Can I use a TP4056 module to charge the cells directly?
Yes, but only for a single 1‑series pack (cells in parallel). TP4056 is a 1 A linear Li‑ion charger designed for 1‑cell applications. It’s slower but simple. Do not use TP4056 on multi‑series packs without a proper multi‑cell BMS/charger. Confirm cell configuration before wiring. [TP4056 Datasheet]
How can I charge faster than with a 1.5 A input?
Use a charger board that supports up to 3 A and pair it with a capable 5 V supply. Expect roughly half the charge time versus 1.5 A, assuming the power bank’s controller accepts the higher current. "Charging time should be reduced by half." Note: some boards omit a micro‑USB port and use thermistor inputs. [Elektroda, E8600, post #17315378]
Are cheap 6–8 cell power‑bank housings reliable and safe?
Quality varies. Many budget housings wire cells in parallel without a balancer, so you should not mix cells of different ages or histories. That mismatch can reduce capacity and stress cells. "Do they work well – hard to tell. Probably depends on the model." [Elektroda, Frog_Qmak, post #17314896]
Is a 60–70 PLN port repair worth it versus buying new?
It depends on your skills and time. Shops quoted 60–70 PLN for repair, while a new power bank costs ~120–130 PLN. A DIY fix with flux and a standard iron can be far cheaper if you’re comfortable with connector work. Otherwise, replacement may be more economical. [Elektroda, cross099, post #17311679]
Why did charging take over 14 hours at 1.5 A?
Large capacity plus conversion losses can stretch charge times. In the thread, the unit “landed on the 1500 mA charger over 14 h.” Higher input current reduces time only if the controller and cabling allow it. Consider a 3 A‑capable board and supply to shorten sessions. [Elektroda, cross099, post #17314898]
What power supply do I need for a 3 A charger board?
Use a robust 5 V USB supply rated at 3 A or higher. Lower‑rated adapters will current‑limit or sag, extending charge time. Some 3 A boards lack a micro‑USB jack and may include a thermistor header; plan wiring accordingly. Verify cable quality to minimize voltage drop. [Elektroda, E8600, post #17315378]
