Xiaomi 10000mAh Power Bank: First LED Flashing When Charging - Possible Damage?
revool 11766 16
Is a flashing first LED on a Xiaomi 10000mAh power bank while it is charging a sign of damage?
A flashing first LED while charging is usually normal and indicates the charge level, not damage [#16599851] One LED blinking can mean about 25% charged, two LEDs about 50%, and four blinking LEDs fully charged [#16599851] The first charge can take time, so it is better to let the 10000mAh power bank keep charging for the expected 6 hours before worrying [#16599865][#16599925] The cable is not the main factor here; the charger current matters more, with higher current charging faster and lower current taking longer [#16599950] In the thread, the power bank later moved on to the second LED, which suggested it was working normally [#16599919]
  • #1 16599820
    revool
    It has a Xiaomi powerbank with a power of 10000mAh and the point is that the first LED of the four flashes when charging with the included cable. Could it be damaged?
  • #2 16599837
    PeCeZu
    Help: 16
    Rate: 32
    While charging the powerbank or while charging the phone from the powerbank?
    Did you check with a different cable?
  • #3 16599839
    revool
    While charging the powerbank, I also checked with a different cable.
  • #4 16599850
    Luk31
    How long have you got this equipment? Maybe take advantage of the warranty.
  • #5 16599851
    PeCeZu
    Help: 16
    Rate: 32
    There are power banks that show the charge level with flashing LEDs. If it is 25% charged, one LED blinks, if it is 50% charged two LEDs blink, while when it is fully charged, four LEDs blink. How much time did you charge your power bank? Or maybe when you saw that one LED is flashing, did you disconnect it?
  • #6 16599857
    revool
    It was recently bought. Already from 3 hours is charging and supposedly in 6 hours. and it's charged.
  • #7 16599863
    Luk31
    Did you buy it in PL or in China?
  • #8 16599865
    PeCeZu
    Help: 16
    Rate: 32
    In my opinion, after such a time, there is no need to panic, but actually wait these 6 hours
    see what the situation will look like. But also not with a watch in hand that it will strike 6 o'clock and you turn it off.
    Let him recharge.
  • #9 16599876
    revool
    On the Allegro but a lot was sold. You can see that it is original.
  • #10 16599881
    Luk31
    Then do as your colleague advises you above - wait these 6 hours and see if it recharges.
  • #11 16599893
    revool
    Ok. Only this remains and the return and I have 30 days for it.
  • #12 16599896
    Luk31
    You can make it easy. Alternatively, ask the seller whether this situation is normal with this equipment.
  • #13 16599919
    revool
    I think it's okay because it jumped on the second LED but we had to wait a bit :)
  • #14 16599925
    PeCeZu
    Help: 16
    Rate: 32
    So it works as I wrote
    Charging for the first time takes some time. So don't panic.
  • #15 16599938
    revool
    Just calm :wink:
    I think the cable also matters because it is charging now with the included one and I was charging it earlier than the phone.
  • #16 16599950
    PeCeZu
    Help: 16
    Rate: 32
    Remember that your power bank has a large capacity so it also needs more time to recharge. And as for the cable, there is no difference, but when it comes to the charger, it is definitely because there is a difference in what current you charge. The higher the current, the faster the charging process but the shorter the service life. The lower the current, the longer the charging time
  • #17 16599955
    revool
    Ok I will remember. thanks for the advice.
    Greetings
The discussion revolves around a Xiaomi 10000mAh power bank that exhibits a flashing first LED during charging, raising concerns about potential damage. Users inquire about the charging process, the use of different cables, and the duration of charging. It is noted that the flashing LED may indicate the charge level, with one LED blinking suggesting a low charge. Participants recommend allowing the power bank to charge fully for the specified duration and suggest checking the warranty if issues persist. The importance of using the correct charger and cable for optimal charging speed is also emphasized.
