Samsung Smart TV Samsung Smart TV Not Opening Our-Kino.tv - How to Unblock & Fix the Issue?
pirat.48911 9360 12
Why does our-kino.tv not open on my Samsung Smart TV while other websites work, and how can I unblock it?
The problem is most likely on the site or network side, not in the Samsung TV itself: the operator may have blocked TV devices, the network/ISP may be blocking the site, or the site may simply be inactive [#17352089][#17829389] If the site opens on a computer connected to the same network, then the TV should also work; if it does not open there either, the block is probably outside the TV [#17829389] One user suggested trying a factory reset of the TV as a general troubleshooting step, but no confirmed fix was reported [#17352122]
  • #1 17351802
    pirat.48911
    Hello, I have a small problem I bought a Samsung TV about 2 weeks ago. From the very beginning it was all great going online in smart tv and typing our-kino.tv page everything worked and it was great. But since yesterday when I try to enter this site, nothing happens all the other pages work, for example I am on CDA. Pl and wanting to come from this side on the above Unfortunately, in the search bar, the our-kino.tv page is entered and the CDA is displayed. How do you fix or unblock this page to make it work?
  • #2 17352089
    gulson
    System Administrator
    Help: 150
    Rate: 6121
    I do not know if sometimes the operator of this site has not blocked certain devices, eg TV sets?
  • #3 17352105
    pirat.48911
    Hello. All other pages are opening except this one. On all devices like smartphone etc. it also opens.
  • #4 17352122
    kindlar
    Help: 919
    Rate: 1622
    Maybe tv downloaded some update that broke something. Restore to factory settings and check.
  • #5 17352156
    pirat.48911
    As for the internet, I did it to factory settings. In TV, we can not find where it can be done?
  • #6 17352179
    Pan Rak
    Help: 8
    I would also block websites that offer watching movies that have not been paid for.
  • #7 17352241
  • #8 17352247
    pirat.48911
    mihal2002 wrote:
    Have you read the CDA regulations?
    Test CDA Premium for 14 days for free!
    But CDA works for me as well as other websites besides this one
  • #9 17352378
  • #10 17352414
    pirat.48911
    Of course I read the CDA rules, but it opens easily. I do not have one website. Our-kino.eu puts them in the search engine even in Google they pop me on the site I click on one of them and nothing happens is still Google and on top instead of writing Google.pl it writes our-kino.tv and Even the Google website does not open, or the other page where our-kino.pl is entered
  • #11 17661323
    milan87
    Friend, you have solved the problem because I have the same, pages like google wp or the other starts as I want to tap or cda pops up with no connection to the server. On the smartphone, everything works (read all pages) on samsung ue48ju7000 do not work _
  • #12 17751780
    paulina02033
    Hi. Did you solve the problem? Because it's the same for me
  • Orange network blocking caused site access issue
    #13 17829389
    Darek A.
    Help: 39
    Rate: 204
    It was once the case that the operator Orange blocked the entrance to our cinema, on all other devices in other networks, it worked, and in Orange it was not. I do not know if anyone intervened or how, but after some time they restored. If the site opens on a computer that is on the same network as the television, the TV will also work. Probably the site is closed for some reason. Our-kino.tv quite often is inactive, even at this moment (March 9, 2019).
The discussion revolves around a user experiencing issues accessing the website our-kino.tv on their Samsung Smart TV, while other websites function normally. Various suggestions are provided, including the possibility of the website blocking certain devices, the need to restore the TV to factory settings, and the potential for network-related issues, such as ISP restrictions. Users also mention that the site may be inactive at times and that it works on other devices within the same network. The conversation highlights the importance of checking for updates and network settings to resolve the access issue.
TL;DR: On Samsung Smart TVs, our-kino.tv may fail due to ISP blocks (1 ISP—Orange—blocked it) or site outages; "Our-kino.tv quite often is inactive." First, test on a PC on the same network; then try a Smart Hub/TV reset. [Elektroda, Darek A., post #17829389]
Why it matters: For Samsung Smart TV owners who can’t open our-kino.tv, this FAQ shows how to diagnose, unblock, and fix access issues fast.
Why won’t our-kino.tv open on my Samsung Smart TV?
Common causes are ISP-level blocking and site downtime. One ISP (Orange) blocked our-kino.tv in the past, while other networks worked. The site has also had outages. Start by checking the site on another device on the same home network. If it’s reachable there, try a Smart Hub or TV reset to clear any browser or cache issue on the TV. If neither works and other sites load fine, wait for the site to return or contact your ISP. [Elektroda, Darek A., post #17829389]
How can I check if my ISP is blocking our-kino.tv?
Open our-kino.tv on a computer that uses the same home network as your TV. If it opens there, it should also open on the TV. If it fails on both while other sites work, that suggests a network or operator block rather than a TV fault. As one user noted, Orange previously blocked access while other operators allowed it. “If the site opens on a computer that is on the same network as the television, the TV will also work.” [Elektroda, Darek A., post #17829389]
Could a Samsung update or settings change be the cause?
Yes. A recent TV update or browser change can break access to specific sites. One practical fix is restoring the TV or Smart Hub to factory defaults, which often clears glitches introduced by updates. After resetting, try our-kino.tv again. If it still fails but other sites work, the issue is likely external to the TV. [Elektroda, kindlar, post #17352122]
How do I reset Smart Hub or the TV to try to fix this?
Try a clean start:
  1. Power cycle the TV and router, then retest our-kino.tv.
  2. In Settings, use Support/Self Diagnosis to reset Smart Hub or perform a factory reset.
  3. Reconnect to Wi‑Fi, then test our-kino.tv again. This clears update-related glitches. [Elektroda, kindlar, post #17352122]
Why does the TV browser show Google while I type our-kino.tv?
That symptom points to a failed navigation or a redirection block. Users reported that entering our-kino.tv keeps them on Google, while the address bar shows our-kino.tv. This can happen if the site is unreachable or blocked upstream. It’s not a general internet failure if other sites load normally. Confirm by testing the URL on another device using the same network. [Elektroda, pirat.48911, post #17352414]
Does this affect specific models like UE48JU7000?
Yes. A user with a Samsung UE48JU7000 reported the same behavior: common sites like Google or WP loaded, yet attempts to open content sites failed with connection errors. Meanwhile, smartphones still loaded all pages. This indicates it’s not limited to one firmware branch or a single account. [Elektroda, milan87, post #17661323]
Is the site itself down right now?
It could be. “Our-kino.tv quite often is inactive,” and on 2019‑03‑09 it was reported down. If your other sites work but our-kino.tv doesn’t on any device, it’s likely a site outage. Wait and retry later. If it works elsewhere but not on your network, check for an operator block. [Elektroda, Darek A., post #17829389]
Are other sites like CDA affected on Samsung Smart TV?
No, not in the reports here. Users noted CDA and other websites opened normally, while our-kino.tv failed. That pattern points to a site-specific issue rather than a general TV browser or internet problem. Use working sites to confirm your TV’s connectivity before deeper troubleshooting. [Elektroda, pirat.48911, post #17352247]
Is it legal to access our-kino on my TV?
Legal status depends on your country and whether content is licensed. One poster stated, “I would also block websites that offer watching movies that have not been paid for.” Respect local laws and platform terms, and use legitimate services to avoid risk. Consider verified apps where available. [Elektroda, Pan Rak, post #17352179]
Could this be my home Wi‑Fi or router?
Possibly, but check scope first. If our-kino.tv opens on a computer on the same home network, the TV should also reach it. If neither device reaches it while other sites work, suspect an operator block or a site outage. If the computer works and the TV doesn’t, try a TV or Smart Hub reset. [Elektroda, Darek A., post #17829389]
What if factory reset and network checks don’t help?
If the TV still refuses to load our-kino.tv and keeps returning to Google, you’ve hit a persistent block or the site remains down. Keep using other sites, and contact your ISP if you suspect blocking. Recheck the site later for availability changes. [Elektroda, pirat.48911, post #17352414]
Does a new TV failing to open our-kino mean it’s defective?
Not necessarily. One user experienced the issue roughly two weeks after buying a Samsung TV, while other sites worked fine. That timing and selective failure point to site availability or operator blocking, not a hardware defect. Rule those out before considering service. [Elektroda, pirat.48911, post #17351802]
