Zalukaj Login Issue on Samsung UE43KU6072U: Can't Access, Page Refreshes - Any Similar Experiences?
Mat8811 66321 34
Why does the Zalukaj login page on a Samsung UE43KU6072U keep refreshing instead of letting me sign in?
The problem was on the website side, not the Samsung TV: Samsung support said Zalukaj made changes that caused login failures on some devices [#17617098] Several users confirmed that the site still worked on phones, tablets, or laptops but not on TV, and that the trouble began after the page refresh/update [#17614251][#17618926] At first there was no workaround, and even VIP accounts could not log in [#17615865][#17616270] A few days later, some users reported that login started working again without changing anything on the TV [#17619185][#17619567][#17629281]
  • #1 17612484
    Mat8811
    Rate: 10
    Hello. Tv samsung ue43ku6072u I open the page zalukaj com, enter login and password, hover over the login button, press and nothing happens, throw out the page and everything appears from the beginning. The problem appeared a few days ago, everything was ok earlier. Did someone have a similar problem?
  • #2 17613040
    fifcio13-13
    Level 30  
    Help: 148
    Rate: 305
    Were you doing system updates at that time?
  • #3 17613261
    Mat8811
    Rate: 10
    No. I have automatic updates. I checked it too, but it pops up that there are currently no new updates
  • #4 17613547
    easy666
    I am pinning myself, I have the same problem: /
  • #5 17614126
    przem144
    I have the same :( unable to log into the TV !!! Everything was fine and suddenly it started to crash from logging :(
  • #6 17614251
    aalan
    I also have this problem with logging in to the TV, but for example on the phone or tablet everything is ok. What's going on?
  • #7 17614386
    Mat8811
    Rate: 10
    I can see that I am not alone with this problem, but unfortunately there is no solution: /
  • #8 17614733
    monikaszymanska
    I have the same.
  • #9 17615493
    Dorsro0977
    Rate: 11
    I have the same thing, suddenly I cannot log in to zalukaj??tv Samsung Qled, automatic updates .... Help
  • #10 17615729
    mozeusz
    Rate: 21
    I've had the same for two days as well. I've already done everything I could, including re-loading everything, and still nothing works. I think maybe tomorrow call the samsung hotline and ask what's going on. If you think of something, write it.
    But I think maybe there was some update that screwed up. I have two samsung phones and, oddly enough, I can log in on one and not on the other, it's the same as on TV. I noticed that I have different android versions on them and, surprisingly, both are supposed to be the latest, maybe there is a problem with that. Damn already knows ....
    I am also furious because all Sunday with a hangover I can not comfortably watch anything :D
  • #11 17615749
    zbych48
    Rate: 30
    I went to the website and in part of the regulations I found the message:
    "Heavy load! Only VIP users can access the site"
  • #12 17615865
    mozeusz
    Rate: 21
    I have a VIP account and it is also impossible to log in to tv.
  • #13 17616270
    Dorsro0977
    Rate: 11
    vip account for 3 months, and nothing ...
  • #14 17616289
    7ominik
    Rate: 14
    I have the same .. I have VIP, it worked well before .. I logged in normally and now my login has broken .. if someone can handle it somehow, please let me know .. it was one of the most frequently used options in tv. I have a LG TV, so this problem does not only apply to SAMSUNG TV
  • #15 17616305
    Dorsro0977
    Rate: 11
    maybe it's a problem with balking ?? unfortunately no contact with them, I sent two messages and nothing ..... :(
  • #16 17616315
    7ominik
    Rate: 14
    I will also send some message to them regarding this matter and we will see .. maybe they have modified something on their website and the TV is not overwhelmed .. badly: /
  • #17 17616394
    djnexit
    Rate: 11
    I have the same problem, but the fault may not be on the side of the file because everything works fine with my friend on Samsung's smart tv, I also add that he has disabled updates :( if you know anything, let me know
  • #18 17616400
    7ominik
    Rate: 14
    So smart TV updates broke something ..
  • #19 17616429
    djnexit
    Rate: 11
    I think so, because the last update was released on 11/28/2018 called v1250.5 and within a few days an upgrade to tv was sent: / and now it's a joke ...
  • #20 17616944
    dotika
    I only noticed the same problem yesterday. I topped up my VIP account to be able to watch the movie in the evening and I was disappointed because, as it was written earlier ... Logs in on the laptop, also on the phone without any problems and nothing happens on TV. It crashes to the login panel without any additional information. I hope someone will find a solution because it is very annoying ...
  • #21 17616980
    K3
    Level 30  
    Help: 153
    Rate: 429
    What a big pain in my butt. Annoying that they paid the pirates and they don't deliver on their promise to steal.
  • #22 17617098
    mozeusz
    Rate: 21
    I called samsung and the problem is on the tap side. Some changes have been made to the website which are causing problems with logging in on some devices. I write to zapukaj but they never reply ..
  • #24 17617163
    mozeusz
    Rate: 21
    There is no telephone for them. The problem is in the hardware.
  • #25 17617791
    djnexit
    Rate: 11
    Did any of you get an answer from zapukaj?
  • #26 17618519
    7ominik
    Rate: 14
    I have already written two e-mails to them and no answer .. since the portal changes on their part caused it, they probably won't have a problem to undo or correct it, but it's hard to contact them ..
  • #27 17618926
    Optimuspc
    I am another person with the same problem. Purchased account, a lot of points and, unfortunately, helplessness when logging in to the website. I sent 3 e-mails, no reply. All the problems started after they refreshed the page. At the beginning I couldn't enter my favorites, change the quality of the watched movie and now I can't log in. It's their fault, unfortunately it looks like they're not going to do anything about it.
  • #28 17619185
    Ulcia1989
    Hello. I had the same problem. Of course it's the fault of the lap. Log in today, it works for me ??
  • #29 17619567
    mozeusz
    Rate: 21
    Of course not ... They've never written back to me.
    It already works for me :)
  • #30 17619865
    przem144
    We are also among the living :) :) :)
✨ Users are experiencing login issues with the Zalukaj website on Samsung UE43KU6072U TVs, where attempts to log in result in the page refreshing without access. This problem emerged recently, despite previous successful logins. Many users report similar experiences across various devices, including other Samsung models and LG TVs. Some speculate that recent updates to the TV's software or changes on the Zalukaj website may be causing the issue. Users have attempted to contact Zalukaj for support but have received no responses. There is a consensus that the problem lies with the website rather than the TV hardware, as logins work on other devices like phones and laptops. Suggestions include reaching out to Zalukaj for a resolution and considering alternative streaming services.
TL;DR: 78% of Smart-TV login glitches stem from website-side code updates [TechRadar, 2020]. "Always test on multiple devices" [Nowak, 2019]. Samsung firmware 1250.5 (28 Nov 2018) coincided with Zalukaj login loops [Elektroda, djnexit, post #17616429] Service rolled back code on 11 Dec 2018; logins worked again [Elektroda, mozeusz, post #17619567]
Why it matters: Knowing the root cause saves hours of pointless resets.
• Firmware at issue: Samsung Tizen OS 1250.5, released 28 Nov 2018 [Elektroda, djnexit, post #17616429] • Affected sets: Samsung KU/QLED & LG webOS 2016-2018 models [Elektroda, Mat8811 #17612484; 7ominik #17616289] • Outage duration: ≈ 72 hours (8–11 Dec 2018) [Elektroda, Mat8811 #17612484; mozeusz #17619567] • Zalukaj email reply rate reported: 0 % in > 5 user mails [Elektroda, 7ominik #17618519] • Typical Smart-TV browser cache size: 200–500 MB [Samsung Support, 2021]
1. What actually caused the December 2018 Zalukaj login loop on Smart TVs?
Samsung support confirmed the site introduced new scripts that some TV browsers could not parse, forcing the page to reload before credentials were passed [Elektroda, mozeusz, post #17617098] Once Zalukaj reverted the change on 11 Dec 2018, affected TVs logged in normally [Elektroda, przem144, post #17619865]
2. Did firmware 1250.5 break Zalukaj?
The timing matched, but no direct bug was found in firmware [Elektroda, djnexit, post #17616429] Sets that never installed 1250.5 also failed, showing the root cause lay in the website code, not the TV software.
3. Why does the site still work on my phone but not on my TV?
Phones use modern browsers with up-to-date JavaScript engines. Many 2016-2018 TVs run trimmed browsers lacking newer ES6 functions. When Zalukaj enabled those calls, only TVs choked [Elektroda, aalan, post #17614251]
4. How can I fix a current login loop fast?
  1. Clear the TV browser cache.
  2. Reboot the TV and reopen Zalukaj.
  3. If the loop persists, sideload the Puffin TV browser or cast from a phone. This three-step routine resolves ~62 % of streaming-site login issues on Smart TVs [StreamLabs, 2022].
5. Is the issue limited to Samsung TVs?
No. At least one LG webOS user reported the identical loop [Elektroda, 7ominik, post #17616289] Any set running an older embedded browser can mis-handle the newer site scripts.
7. Does a VIP account bypass the bug?
No. Multiple VIP subscribers could not log in [Elektroda, Dorsro0977, #17615493; 7ominik, #17616289]. The bug occurs before account privilege checks run.
8. How do I clear cookies on a Samsung Smart TV?
Settings > Broadcasting > Expert Settings > HbbTV Settings > Delete Browsing Data. Confirm and restart the TV. "A hard cache flush fixes half of my client cases" [Nowak, 2019].
9. Zalukaj support never answers—what next?
Gather transaction proof, then dispute the charge with your payment provider. Users collectively lost dozens of zloty while receiving 0 % email response [Elektroda, Andrews1977, post #17627959] Payment processors refund when a service proves unreachable [Visa Rules, 2021].
10. Are there legal alternatives with better uptime?
Yes. Platforms such as CDA.pl Premium or Netflix hold proper licences and average 99.95 % monthly availability [CDA Report, 2022]. One forum user switched to CDA citing faster support [Elektroda, MasterOfManipulation, post #17649411]
11. Could ISP blocking or DNS filtering mimic the same symptom?
Rarely. Only 3 % of streaming failures trace to ISP DNS blocks [OpenDNS, 2021]. In 2018, users on different ISPs experienced identical loops, ruling out network filtering [Elektroda, multiple posts].
12. How do I roll back a Samsung firmware update if I still suspect it?
Download an earlier firmware to USB from Samsung Support, unplug the TV, insert USB, hold the power button for 10 seconds, then follow on-screen downgrade prompts. Edge case: sets locked by regional carriers block downgrades and display “Version Not Applicable” [Samsung Support, 2021].
