[Solved] ESR & Capacity: New 1000uF 16V Electrolytic Capacitors - ESR Deviation & Electronic Tester Results
mateusz2015_5102 24948 8
  • #1 17407247
    mateusz2015_5102
    Pupil
    Rate: 81
    I bought new 1000uF 16V electrolytic capacitors and checked them with an electronic components tester. The tester results are ESR 0.30 ohms and 1001uF. And according to the table, the ESRs should be less than 0.30 ohms.
    Please reply.
    And what should the ESR deviation be, e.g. +/- 20% electrolytic capacitors?
    • ESR & Capacity: New 1000uF 16V Electrolytic Capacitors - ESR Deviation & Electronic Tester Results tmp-cam-1220301370.jpg (593.79 KB) You must be logged in to download this attachment.
    • ESR & Capacity: New 1000uF 16V Electrolytic Capacitors - ESR Deviation & Electronic Tester Results tmp-cam-1270314176.jpg (602 KB) You must be logged in to download this attachment.
    krzysiozak
    Level 40  
    Help: 510
    Rate: 1154
    These are the parameters given in approx. And it can vary significantly, it is difficult to produce a product that will be in such an exact class.
  • #3 17407267
    bartekjasecki
    Help: 18
    Rate: 27
    According to the table, they should be 0.15
  • #4 17407426
    jarek_lnx
    Help: 4198
    Rate: 6126
    I don't know where you got this table from, but a 1000uF / 16V capacitor from the RTE series by Zhuhai Leaguer Capacitor Co. Ltd. has 0.09? in the catalog with what tolerance they have specified, ask the manufacturer.
    In addition, a tester is not the same as a meter, whether the manufacturer gives some parameters, how exactly it measures it, the measurement method or frequency may be different, it also affects the result.
  • #5 17407560
    mateusz2015_5102
    Pupil
    Rate: 81
    I wentogle "ESR table" and took the first one.
    I still watched this movie https://youtu.be/5DBQ-XmIsgY
  • #6 18161253
    comandos21
    Rate: 105
    I am curious how to measure it, because according to another table ...
    Link
    The new 1000uF / 10V capacitor has 0.38Ohm on the meter and the ESR is too high according to the table, it means that although the capacitance is correct, the capacitor should be thrown away ??
  • ESR must be judged against the capacitor datasheet
    #7 18161471
    jarek_lnx
    Help: 4198
    Rate: 6126
    If you want to check it properly, read the manufacturer and type of the capacitor, find the datasheet and then compare.
    If the capacitor being measured was a lowESR capacitor in a high-current converter then it would be useless, if a regular capacitor used in light applications it might be acceptable.
    The ESR of the capacitor must be compared with how much it should be, a random table from the Internet will not help you with this.
  • #8 18161587
  • #9 18839480
    mateusz2015_5102
    Pupil
    Rate: 81
    Problem solved.
The discussion revolves around the performance of new 1000uF 16V electrolytic capacitors, specifically focusing on their Equivalent Series Resistance (ESR) and capacitance measurements. A user reported an ESR of 0.30 ohms and a capacitance of 1001uF, questioning the validity of these results against a reference table indicating an ESR threshold of less than 0.30 ohms. Responses highlighted the variability in capacitor specifications, the importance of consulting manufacturer datasheets for accurate ESR values, and the potential discrepancies in measurement methods between testers and meters. Suggestions included charging the capacitors before testing and considering the application context of the capacitors to determine their usability.
