MAN TGX 18.440 Euro 6 2014: EDC Error 04295-09, Power Limitation - Seeking Solutions
comar3 32148 6
  • #1 17420359
    comar3
    Rate: 67
    Which means error EDC 04295 - 09. When it appears, the power is limited.
  • #2 17420632
    darfur5
    Help: 267
    Rate: 1712
    Main relay: Relay was open too early. FMI 09; device damaged.
  • #3 18390573
    pawcio7337
    Rate: 68
    The same error was displayed in the fire Man TGM 15-290. The new car has done 900 km. Which relay is it?
  • #4 18392708
    MAN Electronics
    Help: 321
    Rate: 1717
    1. Are you turning off the main battery breaker if there is one?
    2. If so, how long after ignition off?
  • #5 18392729
    pawcio7337
    Rate: 68
    The main switch is on. It has two options, the first is a short press that turns off the electricity after 180 minutes, and the second is a longer press that turns off the electricity immediately. Colleagues were on a trip and probably the driver turned off the electricity too soon after that trip, which could be the cause of the error, right? When I started the car, the check engine light came on red and after driving, the power was reduced.
  • #6 18392912
    MAN Electronics
    Help: 321
    Rate: 1717
    Most likely, this was the reason, the rule is that after turning off the ignition, wait about 2 minutes for the so-called run-down in the controllers, in other words, the correct completion of the system operation.
    This surprises me a bit. Does this TGM already have the new Bosch adblue system with an injector on the muffler?
    After all, this is a new vehicle and it has a warranty, and if the fault persists, you should drive to the service center.
  • #7 18394694
    pawcio7337
    Rate: 68
    Car from 2019. I visited the service, they deleted the errors (there were a lot, in all groups) after the company where the bodywork was made, and everything is fine. Time will tell if this is due to the power being turned off too early. Thank you for your interest.
✨ The discussion revolves around the EDC error code 04295-09 encountered in a MAN TGX 18.440 Euro 6 (2014) vehicle, which results in power limitation. Users suggest that the error may be linked to the main relay being open too early, potentially causing damage. One user mentions a similar issue with a MAN TGM 15-290, prompting inquiries about the specific relay involved. It is noted that turning off the main battery breaker too soon after ignition can lead to this error, emphasizing the importance of allowing a proper run-down period for the controllers. A user with a 2019 model reports that after visiting a service center, the errors were cleared, and the vehicle functioned normally, indicating that premature power shutdown might have been the cause.
