Ford S-Max 2008 2.0 - Loss of Power, Engine Fault Light, DPF & Turbine Sensor Issues
fordzino smax 15633 1
  • #1 17471651
    fordzino smax
    maybe there was something similar so I apologize in advance because I did not find it
    describe my problem, please help
    So I will start that one day my smax lost power while driving and the engine fault light came on and the car went into emergency mode, so you can drive slowly, sudden lack of power, no acceleration possible. So I led the mechanic to the mechanic, the computer indicated two errors clogged dpf and the turbine copy sensor (something did not control the turbine blades) so he ordered to clean the dpf or buy then the errors will disappear. I did as I wanted and the dpf error disappeared and it was the one from copying the turbine, so the mechanic started to rummage at the same time he changed the junk with the sensor from another, the error is still an electrician also checked with him if it was not the fault of the wires, but everything was fine, the mechanic gave up after checking everything around and your knowledge. I took him to the next mechanic and he also gave up, saying that it might be some bullshit, but I can't find the turbine, the blades are working, everything is fine and the car is in service mode. maybe someone will tell you what could be, what I could pass the info to the mechanic. the car is already at the next mechanic who starts shaking his nose and feels the next surrender.
    please help
  • #2 17472718
    marcias
    Help: 18
    Rate: 87
    Anyone at least checked the boost parameters while driving? Are you paying them for this mess?
