Toshiba 32AV933 Firmware Update: Enhance Your TV's Performance & Features
mitsoman61 15024 7
  • #1 17867702
    mitsoman61
    Rate: 28
    Toshba 32AV933 firmware update
    • frmwre-20120628150834.zip (4.06 MB) You must be logged in to download this attachment.
  • #2 18995063
    ictc
    The original dump is almost 8Mb. Is this supposed to work as an update to run from the TV itself? Is there a way to merge its content with the original BIOS?
  • DVB-T2 support likely requires hardware upgrade
    #3 19837014
    davidromih
    Hi, I've used this firmware but it seems that it is the same as the original from 2012. Is that true or did I do something wrong? Anyway, I searched all over the internet and couldn't find anything useful. Does someone know if it is possible with a firmware update for this Toshiba model to set the TV on DVB-T2 version? Or is this more of a hardware solution?
    Sorry for asking, I am a complete rookie for TVs.
    Thanks for any help.
    Regards,
    David
  • #4 20349662
    elszerviz
    Good backup, the TV works perfectly with it. Thank you
  • #5 20357922
    _msbln
    32" Toshiba AV933
    my last dump from Dec 2012
    contains also firmware with
    version 1.25.02 (never saw a later version)
    copy the bin-file onto fat32-stick
    if anything goes wrong use backup file from poster above
    greetings from germany
    _matthias
    • xx_xV_xL_DB_933x_125_REV01.bin (4.21 MB) You must be logged in to download this attachment.
    • Installation_Instruction.pdf (218.11 KB) You must be logged in to download this attachment.
    • procedure_of_downloading.pdf (554 KB) You must be logged in to download this attachment.
  • #6 20394089
    Arkkl
    Hmm, I updated this TV today but it still only finds 6 channels. Does this TV have the ability to receive Polish channels? Won't he get over it. The antenna is connected collectively.
  • #7 20394147
    Michał99
    Help: 140
    Rate: 345
    It's still a lot, there won't be any more, buy a second or DVB-T2 HEVC decoder
  • #8 20655094
    MANTZARIS NIKOS
    Σε εμένα δούλεψε κανονικά όταν φόρτωσα το βίντεο.
    Δεν ξεκινούσε, φόρτωνε συνεχώς μια μπάρα.
The discussion revolves around the firmware update for the Toshiba 32AV933 TV model. Users express concerns about the effectiveness of the firmware, with one noting that the update appears to be the same as the original from 2012. There are inquiries about the possibility of enabling DVB-T2 functionality through firmware, with suggestions that it may require hardware changes. Users share experiences with the update process, including successful backups and issues with channel reception, particularly regarding Polish channels. Recommendations include using a FAT32 USB stick for the update and considering additional hardware for improved reception.
