Seeking Firmware for Toshiba Smart TV Model 40L3453DB: TV Stuttering Issues
tonan 13980 8
  • #1 16480654
    tonan
    Rate: 13
    Hello, I am looking for firmware for this Tv Toshiba smart tv 40L3453DB model.
    Tv stutters and has temporary amnesia, I think that after uploading a new update something will change, please help, maybe someone has a firmware for this model.
  • #3 16481525
    tonan
    Rate: 13
    Thank you for the links, but the problem is that I have the same firmware and the problem is that I am looking for an older one or a different one. 3.5.5f best regards.
  • #4 16481715
    GanCegall
    Help: 339
    Rate: 1631
    Make up your mind, first you write:
    tonan wrote:
    I think that after uploading the new update something will change, I am asking for help
    After receiving the expected help, you write:
    tonan wrote:
    the problem is that I am looking for an older one or another
    You did not give any details, only the TV model, probably something would be found, but no one will look for what's inside.
  • #5 16481740
    robertamel
    Help: 115
    Rate: 56
    Much of the hardware is set up in such a way that you cannot easily go back to an earlier version using the USB stick upgrade procedure. Desolder the bone and connect it to the programmer. The company from Sucha Beskidzka boasts on Allegro that it has bones programmed for your model. Contact them.
  • #6 16482454
    tonan
    Rate: 13
    Thanks for the answer and best regards.
  • #7 16755915
    almou
    Rate: 55
    I need a bootloader for chassis 17mb95m 40'' The last time, I found mb95s-1 bootloader and when i correct the start, the problem is almost done but my tv can not tune. No satellite DVB tune but AV, HDMI correct
  • #8 16767478
    lipas22
    Rate: 10
    There is a 17mb95 board
    Should help
    • MB9x_Faz3_V362H_Core.zip (89.37 MB) You must be logged in to download this attachment.
  • #9 17855534
    electrosat_togo
    Rate: 69
    I believe with SW v3.2.6 can help?
✨ The discussion revolves around seeking firmware for the Toshiba Smart TV model 40L3453DB, which is experiencing stuttering issues and temporary memory loss. A user requests assistance in finding an older or alternative firmware version, as the current one does not resolve the problems. Several responses provide links to the official Toshiba firmware site and suggest that reverting to an earlier firmware version may not be straightforward due to hardware limitations. One response mentions a company that offers programmed chips for the model, while another user discusses issues related to a different chassis and bootloader. Overall, the conversation highlights the challenges of firmware management for this specific TV model.
