LG 42LF561V Startup Issue: TV Resets to Basic Setup (Channel, Language, Country) - Solutions?
Neonri 2856 7
  • Suggesting SPI and NAND replacement for LG reset issue
    #1 18029236
    Neonri
    Level 4  
    Rate: 11
    Hi all,
    I have a problem with LG. Every switching on TV it goes from basic setup - channel search, language set, country set and so on...
    I have tried to put a new firmware inside but it doesn't wanna accept it since newer version is inside tv - newer than LG support pages.
    I suppose I could put new SPI & NAND inside,,,try with that....anyone has it?
    Model : LG 42LF561V
    Motherboard : EAX66203803 (1,2)
    Panel : LC420DUE (A4)
    Thanx in advance!
    :bye:
    VINZA
    Help: 49
    Rate: 164
    Hi, I send you the file for Nand with private message.
  • #3 18033053
    Neonri
    Level 4  
    Rate: 11
    Thnx a lot :)
  • #4 18033345
    VINZA
    Help: 49
    Rate: 164
    You're welcome!
  • #5 21764877
    Dancia11
    Neonri wrote:
    Hi everyone,
    I have a problem with my LG. Every time I turn on the TV it goes from basic settings - channel search, language setting, country setting etc....
    I have the same problem
    LG 42LF561V-ZF
    Please help, as even the software is now difficult for me to find.
  • #6 21765035
    stacho57
    Help: 170
    Rate: 449
    If you have a version lower than 03.05.37, you can try it. If not, then NAND to be replaced.
    • 42LF561V.zip (56.36 MB) You must be logged in to download this attachment.
  • #7 21765082
    Indyczes
    Help: 186
    Rate: 272
    I know from experience that there will still be NAND to replace.
  • #8 21765279
    Dancia11
    stacho57 wrote:
    If you have a version lower than 03.05.37, you can try it. If not then NAND to be replaced.
    Uploaded and TV fixed.
    Thank you.
LG 42LF561V TV repeatedly resets to the initial setup menu on every power-on, requiring channel search, language, and country selection again. A firmware update was attempted but rejected because the installed version was newer than the one available on LG support pages. The discussion points to a corrupted NAND/flash memory issue, with one solution being to load a compatible NAND file or replace the NAND chip; later replies note that if the firmware is below version 03.05.37 it may be tried, otherwise NAND replacement is required. A user reports the TV was fixed after uploading the provided NAND file.
