LG 22LG3000 LCD TV: Resets to Factory Default Settings After Turning Off or Standby
vrabac 16272 3
  • #1 15521430
    vrabac
    Hello, I have LG 22LG3000 LCD TV. Problem is that when I turn off TV and later turn on TV I get welcome screen, like screen when TV was first time started and I need to go thru the wizard and save settings. It looks like my TV goes to factory reset mode (factory default settings) every time it turns off/or in standby.
  • #2 15662124
    diddygy
    Rate: 14
    Hi try put another memory and write bin ...
  • #3 15920659
    kbyrski91
    I know that this topic is quite old but this kind of problem often has an easy solution so maybe I will help someone else.
    Try to find in settings an option called "Demo mode" or "Shop mode" and turn it off. The feature is used in shops in order to automatically restore settings which were changed by customers.
  • #4 16866025
