Vivitek D963HD =BENQ SP840 - Turn off, but no error message :(
micilacko 2442 3
  • #1 18221845
    micilacko
    I like to repair the DLP projector
    Vivitek D963HD (The main and the supply is equal BENQ SP840)
    I turn on first. It is OK, the colorwheel, and the ventilators are go, come to light, and I see the start picture..
    After 30-50 sec the light turn off, NO screen, no LEDs are on..
    The ventilators are going..
    And no buttons, no remote responding.. Nothing ...
    If I pull out the power cord, after 5-10 minutes It is starting again..
    I try to factory reset (1 times I can do, but nothing)
    12V is OK
    1.2 1.5 1.8 2.5 3.3 5V Is ok..
    But what Can I do.. ?
    L
  • #2 18223126
    Aquario_blue
    Level 19  
    Help: 41
    Rate: 155
    Try replacing integrated circuit of power supply primary
  • #3 18223801
    micilacko
    hello
    Thanks..
    The PFC is 367V. I push up 375V, but Nothing ... There is a sign on the panel 370V.. I think the 367 is enough, but I keep 375V.
    The colorwheel sensor I think ok, because the picture is good, until it works..
    L
  • #4 18224939
    Aquario_blue
    Level 19  
    Help: 41
    Rate: 155
    Sorry I had misunderstood your message, after reading more carefully, correcting my message, I already had a similar problem with a Benq projector and it was the Ic does boot up the power supply
