Free & Easy-to-Use Technical Drawing Program: Sketch & Dimension Kitchen Worktop Elements
bumble 62499 10
What free, easy-to-use app can I use to sketch kitchen worktop elements to scale and add dimensions?
LibreOffice Draw can do this, although some of the work has to be done manually [#18339578] A quick online alternative is draw.io, which is like Visio and lets you download the result as PDF [#18339602] LibreOffice Draw can also export drawings to many image formats and to PDF [#18344667] In Draw, you can click a line to select it, press Del to delete it, or change its thickness in the Properties window [#18344773] If you need to hide part of a shape, the fastest workaround is to overlay another rectangle filled with the background color [#18344797]
  • #1 18339548
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    Hello. I need a applet to sketch a few elements in it - it is about a kitchen worktop - and sign it with dimensions. It's good for him to dimension and draw in the right size, e.g. I choose a square, give the side length and I already have a square.
    Can you advise something?
    beatom
    Help: 421
    Rate: 876
    Libre Office should do the job, although a lot of things have to be done manually.
  • #4 18339665
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    I have a check in Libra office.
  • #5 18344659
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    You cannot write into libra a format other than odl.
  • #7 18344675
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    I mean Libra Office and a new drawing opened there. Yes it is a draw. So by exporting. okay.
    Added after 6 [minutes]:
    How do you bold lines or erase?
  • #8 18344773
  • #9 18344782
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    Sorry, I meant to erase some lines from a square, for example.
  • #11 18344808
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    and that's it.
A user seeks a free and easy-to-use technical drawing program to sketch kitchen worktop elements with precise dimensions. Responses suggest using LibreOffice Draw, which allows for manual drawing and exporting to various image formats and PDF. Another option mentioned is the online tool draw.io, similar to Visio, which facilitates quick drawings and also supports PDF downloads. The user inquires about specific functionalities in LibreOffice, such as bolding lines and erasing parts of shapes, receiving guidance on how to manipulate line thickness and use overlay techniques for erasing.
