Simple graphic and technical program with JPG support - adding dimensions of obj
bobeeq 27351 9
How can I add dimension arrows and typed measurements to a JPG photo in a simple graphics program?
Use IPhotoDraw: load the photo, choose Linear Dimension, click the start and end points, and then enter the measurement; it supports arrowheads, arrow size, colors, text size/position, line thickness, guides, and more [#16865131] It is free for commercial use and also available in a portable version [#16865131] If you only need to draw arrows and add the numbers manually, vector or CAD tools such as Inkscape, Corel Draw, Illustrator, or a CAD program can do that too [#13321709][#13371118]
  • #1 13316178
    bobeeq
    Hello. I am looking for a simple graphics application that supports JPG.
    I need to mark the dimensions of the photographed objects in large numbers.
    The end result should be something like this:
    Instructions for posting photos and pictures on the forum:
    https://www.elektroda.pl/rtvforum/topic2053101.html
    The point is that the program should be able to apply such arrows and enter any dimension normally from the keyboard - I do not need anything else.
  • #2 13316293
    SebMarszal
    Help: 5
    Rate: 13
    Look for DraftSight - it has that capability.
  • #3 13316319
    bobeeq
    And there is a chance that I will find out how to import jpeg in the program and which option is to apply dimension arrows? Because I installed it, but you are going to get lost between the options ...
  • #4 13317690
  • #5 13317753
    bobeeq
    In every? I have been using Adobe Photoshop 7.0 CE and I know a bit for a long time and somehow there is no such function ... or I do not know it? But okay, I'll check out GIMP, although I don't know that he has anything like that either.
  • #6 13321709
  • #7 13371118
    krzysiu_69
    Hello, my first post :)
    Inkscape (Free, I don't know it but should have it)
    Not only free, but also open source, so you can use it for commercial work. It would be very easy and fun to apply such arrows (regular line + arrow-shaped ends ;) ) only one thing but - Inkscape slows down from version to version and takes more and more RAM. Well ... One more thing: export only to PNG. Maybe there are some plugins that allow you to export to JPEG.
    1) Open the image in the program or create a new file and drag the JPEG there.
    2) click on the line icon and mark the first and second point
    3) having selected the line, press ctrl + shift + f - we will see the color option, and in probably the last tab there are options for the end / start of the line.
    If we want to rotate the text, we use the text input function. After writing, we go to the selection mode. The first click allows you to resize. By clicking on the object for the second time, we have the handles for rotation. You can also do something like Text> Snap Text to Path with both the line and text selected.
  • #8 16865131
    Genius_kce
    Rate: 10
    I know that the topic is from 2014, but I had a similar problem and I was also looking for such a program.
    As I was able to find it and it is free for commercial use, I decided to dig out the topic.
    IPhotoDraw, because we are talking about it, allows you to add dimensions to photos.
    You load the picture, click linear dimension. you click on the start point and end point, then it asks for the dimensions ... and that's it!
    Line ending can be formatted into arrows, arrow size, colors, text size, text position, line thickness, whether to be guides, colors, etc.
    Available here, also in a portable version
    Here is an example
  • #9 16872252
    Roberted
    It doesn't work, what am I doing wrong?
  • #10 16872297
    REMUR.
    Help: 143
    Rate: 255
    It works, and what you are doing wrong, we don't know.
    • Nanoszenie wymiarów.mp4 (4.61 MB) You must be logged in to download this attachment.
A user seeks a simple graphics application that supports JPG format for marking dimensions on photographed objects. Responses suggest several software options, including DraftSight, GIMP, Inkscape, and IPhotoDraw. DraftSight is noted for its capabilities, while GIMP and Inkscape are recommended for their free and open-source nature, although Inkscape may have performance issues. IPhotoDraw is highlighted for its specific functionality in adding dimensions easily. Users discuss the ability to create arrows and input dimensions manually, with some confusion regarding the features of Adobe Photoshop. The conversation emphasizes the need for straightforward tools to annotate images with dimensions.
