Need eMMC Dump for Sony KD-55X8509C TV - Mainboard 1-894-596-22, H26M52103FMR, Chassis BMFL
stele1981 22800 13
Where can I download an eMMC dump for a Sony KD-55X8509C TV with mainboard 1-894-596-22 and H26M52103FMR eMMC?
A dump link was shared here: gsmserverpro.com/index.php?a=downloads&b=file&id=13339, and another thread was pointed out as a specialist reference for the same board [#20741020][#19377604] One repairer reported that RT809H and TNM500 did not work well, while the T56 could write to RPMB enough for the TV to restart [#20495468] However, other replies warn that without the original RPMB key it will not fully work, so Google and update services may still fail after the repair [#20747531][#21317037]
  • #1 18597247
    stele1981
    Sony kd-55x8509c
    MAINBOARD: 1-894-596-22
    eMMC : H26M52103FMR
    Chassis BMFL
    The tv stuck on the android logo, I read eMMC with easy jtag pro and Health report is very bad so I need to change eMMC, and I don't have the eMMC dump, does anyone have or can they tell me where I can download eMMC dump ..... thank you
    Need eMMC Dump for Sony KD-55X8509C TV - Mainboard 1-894-596-22, H26M52103FMR, Chassis BMFL Need eMMC Dump for Sony KD-55X8509C TV - Mainboard 1-894-596-22, H26M52103FMR, Chassis BMFL
  • #2 19302699
    SAMKE
    Rate: 10
    Hello. Still need an emmc dump?
  • #3 19313116
    Guardado
    Rate: 9
    Please share the dump 50w800c could be de placed
  • Bad eMMC health points to replacement and dump needed
    #4 19377604
    Łuki_83
    stele1981 wrote:
    Sony kd-55x8509c
    MAIN BOARD: 1-894-596-22
    eMMC: H26M52103FMR
    BMFL chassis
    TV stuck on android logo, I read eMMC with easy jtag pro and health report is very bad so I have to change eMMC and I don't have eMMC dump, can anyone have or can tell me where can I download eMMC screenshot ..... thank you
    Look here https://www.elektroda.pl/rtvforum/topic3789168.html#19329100
    Adam4321 is a great specialist
  • #5 19697475
    george1312
    I could also use the Sony KDL-55W809C dump if possible, please!
  • #6 20495127
    kubus1111111112
    Rate: 18
    witam ma ktos jeszcze nanda do tej płyty?
  • #7 20495468
    Lolo81700
    Help: 10
    Rate: 46
    hello repairman friend
    what programmer do you have?
    I tried with 3 programmers, RT809H, TNM500 and Xgpro T56, only the T56 worked by writing to the RPMB.
    You can restart the TV, but not google and update services.
    good repair
  • #8 20499468
    imran333
    You think t48 can work as that works the same way as t56 ?
    Added after 40 [seconds]:
    >>20495468
    You think t48 can work as that works like t56 ?
  • #10 20746159
    Lolo81700
    Help: 10
    Rate: 46
    Hello, repairing friends. I do not know the T48. If it reads and writes the MBPR, it can work. Good luck.
  • #11 20747531
    Adewag
    Help: 36
    Rate: 251
    Lolo81700 wrote:
    If he reads and writes the MBPR
    Without the key it won't work.
  • #12 21317028
    tmszwojcicki
    Help: 15
    Rate: 58
    @ElektrodaBot And where do you get the key? I have a UFI and it has the possibility to write RPMB...
  • RPMB key cannot be read from eMMC or UFS
    #13 21317037
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    tmszwojcicki wrote:
    And where do I get the key from? I have a UFI and it has the ability to write RPMB...
    Preliminary evaluation of available information .
    Good morning,
    From your question, it appears that you have a UFI Box with the ability to write to the RPMB area and are wondering where to get the key needed for this operation. However, you have not stated what specific device you are working on or the purpose of your operation (e.g. eMMC/UFS memory replacement, software repair, device unlock).
    Direct answer to question .
    The RPMB key is a unique, secure key generated during manufacture of the device and is necessary for authorised access to the RPMB area. It is not publicly accessible or readable from the device.
    The tool UFI Box does not allow the original RPMB key to be obtained from the device. Without this key, full access to the RPMB is restricted. However, there are some procedures and alternatives that may help depending on the specific device and situation.
    Detailed analysis of the problem .
    What is the RPMB and why is a key needed? .
    RPMB (Replay Protected Memory Block) is a special, protected memory area in modules eMMC or UFS , used to store safety-critical data such as:
    - Cryptographic keys
    - Certificates
    - Device security status information
    The RPMB key is unique for each device and is used to authorise read and write operations in the RPMB area. Without this key, any attempt to modify data in the RPMB will be rejected by the memory for security reasons.
    Why can't the RPMB key be obtained? .
    - Hardware security : The key is stored in memory OTP (One-Time Programmable) of the eMMC/UFS chip and cannot be read or modified once written.
    - Uniqueness : The RPMB key is generated from unique hardware identifiers such as CID memory and processor identifiers.
    - No universal keys : There is no universal key that could allow access to the RPMB in different devices.
    Options available to service technicians .
    1. Initialisation of a new RPMB key :
    - UFI Box enables the procedure RPMB Provisioning , i.e. writing a new key to a clean eMMC/UFS memory.
    - Consequences :
    - Loss of data : Entering a new key will result in loss of access to data protected by the previous key.
    - Problems getting the device to work : The device may not work properly because the original software expects the original RPMB key.
    2. Using the manufacturer's service files :
    - For Xiaomi devices with Qualcomm processors :
    - You can use the file `devcfg` from the official engineering software (eng ROM) .
    - This file contains the RPMB key which allows the device to operate normally after memory replacement.
    - Process :
    - After initialising the new RPMB key in memory, special software containing the `devcfg` file must be uploaded.
    - This allows the system to bypass verification of the original RPMB key.
    3. Using alternative tools :
    - EasyJTAG Classic : This tool allows you to work with the RPMB using a user-created key.
    - Limitations :
    - Does not guarantee correct operation of the device without the original key.
    - Requires advanced knowledge and caution.
    Is it possible to obtain the RPMB key from the device? .
    - No , the RPMB key cannot be read from the device, even with advanced service tools.
    - The key is hardware protected and access to it is not possible without the appropriate manufacturer's authorisations.
    Consequences of entering a new key .
    - Loss of functionality : The device may cease to function properly.
    - Lack of certificates : Some functions may not be available, such as those related to the mobile network or security.
    - Risk of damage to the device : Improper operations may lead to permanent damage to the device.
    Current information and trends .
    - As of 24/11/2024 there have been no publicly available methods to read the original RPMB key from devices.
    - Manufacturers are strengthening the security of their devices, making it more difficult to tamper with the RPMB area without authorisation.
    - Service tools such as UFI Box are regularly updated, but respect manufacturers' security.
    Supporting explanations and details
    - Mechanism HMAC : Operations in the RPMB are authorised using the HMAC (Hashed Message Authentication Code) mechanism using the RPMB key.
    - Authentication : Every write or read attempt is verified to prevent unauthorised modifications and replay attacks.
    Ethical and legal aspects .
    - Passing the safeguards may breach the terms of the warranty and be unlawful.
    - Data security : RPMB protects critical data; tampering may expose data loss or security breaches.
    - Intellectual Property Law : Attempts to obtain keys may infringe manufacturers' rights.
    Practical tips .
    - Consult an authorised service centre : They have access to tools and procedures in accordance with the manufacturer's policy.
    - Check documentation : Some manufacturers provide official repair procedures after memory replacement.
    - Consider alternatives : In some cases it is possible to circumvent the problem without interfering with the RPMB.
    Possible objections or additional comments .
    - No universal solution : Each device may require an individual approach.
    - Risks : Attempts on their own can lead to irreversible damage.
    Suggestions for further research .
    - UFI Box updates : Monitor the latest software updates and features.
    - Service Forums : Sharing on the forums can help to share experiences with other service technicians.
    - Education : Gain knowledge of hardware security and service procedures.
    Short summary .
    The RPMB key is a unique and secure element of each device, generated during manufacture and is not accessible to the end user or service technicians. UFI Box allows RPMB operations, but without the original key full access is not possible. It is recommended to use the manufacturer's official procedures or consult an authorised service centre to resolve the problem.
    User enquiries .
    - What is the model of the device you are working with? This will help in finding a specific solution.
    - Have you replaced the eMMC/UFS memory in the device? If so, there are procedures for initialising new memory.
    - Do you have access to the manufacturer's official service files? These may contain the necessary tools or instructions.
    Please provide me with additional information so that I can provide more detailed assistance.
The discussion centers on obtaining an eMMC dump for the Sony KD-55X8509C TV with mainboard 1-894-596-22, eMMC chip H26M52103FMR, and chassis BMFL. The TV is stuck on the Android logo, and the eMMC health is poor, necessitating replacement. Users inquire about availability of eMMC dumps, referencing similar Sony models like KDL-55W809C and 50W800C. Various programmers are discussed for reading and writing the RPMB area, including RT809H, TNM500, Xgpro T56, and T48, with T56 noted as effective for RPMB writes. The importance of the RPMB key, a unique manufacturer-generated security key required for authorized RPMB access, is emphasized; it is not publicly available and cannot be extracted using tools like UFI Box. Without this key, full RPMB access and successful eMMC replacement are limited. Links to external resources and specialists are shared, along with a YouTube video related to the repair process.
TL;DR: KD-55X8509C boot‑loop work hinges on RPMB handling; in one report, only 1 of 3 programmers succeeded—"only the T56 worked by writing to the RPMB." Get a proper dump and plan for RPMB keys. [Elektroda, Lolo81700, post #20495468]
Why it matters: This FAQ helps TV repair techs replace the eMMC, program RPMB, and source dumps for Sony Android TVs stuck on the logo.
What’s the typical failure when a KD-55X8509C is stuck on the Android logo?
This symptom aligns with a degraded eMMC on this model. In the thread, the H26M52103FMR eMMC showed a very bad health report. The TV stayed at the Android logo. The mainboard is 1-894-596-22 with BMFL chassis. Plan for eMMC replacement and a correct dump. Back up readable partitions before removal if possible. [Elektroda, stele1981, post #18597247]
Which programmer has confirmed RPMB write success on this board?
A tech tested RT809H, TNM500, and XGpro T56. Only the T56 wrote the RPMB successfully, i.e., 1 out of 3 tools. Afterward, the TV restarted but Google services did not update. "Only the T56 worked by writing to the RPMB." Choose tools with proven RPMB support. [Elektroda, Lolo81700, post #20495468]
Will a T48 work like a T56 for RPMB writes?
It can if the T48 truly reads and writes the RPMB area. Success depends on full RPMB access, not brand. "If it reads and writes the MBPR, it can work." Confirm RPMB support, adapters, and voltages before attempting. [Elektroda, Lolo81700, post #20746159]
Do I need the RPMB key?
Yes. RPMB operations require the correct per‑device key. Without it, authenticated access fails. "Without the key it won't work." Plan your repair around the key requirement. Avoid writes that assume a universal key. [Elektroda, Adewag, post #20747531]
Can I read or obtain the original RPMB key with UFI or Easy JTAG?
No. The RPMB key is unique and stored securely; tools cannot read it. UFI can provision a new key on a clean chip. A new key breaks access to data tied to the original key. Some functions may not work afterward. Use official service files when available. [Elektroda, ElektrodaBot, post #21317037]
How do I replace the eMMC and set up RPMB?
  1. Fit a new eMMC and perform RPMB provisioning with a supported tool (T56/UFI) on a clean chip.
  2. Write a correct full dump or vendor service firmware matched to board and chassis.
  3. Reassemble, power up, and complete software setup; expect limitations if keys differ. [Elektroda, ElektrodaBot, post #21317037]
Why does the TV boot but Google services won’t update after eMMC work?
This indicates a mismatch between software expectations and the new RPMB state. Data tied to the original RPMB key becomes invalid. The system may boot, but protected services can fail. Use vendor service packages when possible. Some features can remain unavailable without the original key. [Elektroda, ElektrodaBot, post #21317037]
Can I flash a KDL-55W809C or 50W800C dump onto KD-55X8509C?
Avoid cross‑model dumps. Software, board variants, and RPMB bindings differ. Unique keys and certificates tie software to hardware. Mismatches cause boot or service failures. Use dumps matched to KD-55X8509C, 1-894-596-22, and BMFL chassis. [Elektroda, ElektrodaBot, post #21317037]
Is this board using eMMC or NAND?
This case uses an eMMC: H26M52103FMR on mainboard 1-894-596-22. The failure report and readout came from that eMMC. Prepare eMMC‑specific handling and adapters. [Elektroda, stele1981, post #18597247]
What should I try if RPMB writes but the TV still won’t boot?
Confirm you used a dump matching the exact board and chassis. Reflash a full, verified image or official service firmware. Re‑provision RPMB on a clean chip if needed. Understand that missing the original key can still limit functionality. Consider manufacturer repair files. [Elektroda, ElektrodaBot, post #21317037]
Where else can I request or discuss dumps for related Sony models?
Follow the recommended Elektroda thread referenced by members and contact the noted specialist. Cross‑check model, board, and chassis before flashing. Avoid using unrelated model dumps to prevent failures. [Elektroda, Łuki_83, post #19377604]
