[Solved] Replacing eMMC on SONY KD-49X8309C TV: Main Board 1-894-595-12
Lolo81700 5499 1
  • Need correct eMMC firmware for KD-49X8309C
    #1 21142767
    Lolo81700
    Help: 10
    Rate: 46
    Hello repair friends
    TV SONY model KD-49X8309C, main 1-894-595-12, eMMC H26M52103FMR
    the original eMMC is damaged, XGECU T56 gives reading and verification errors.
    I replaced the eMMC with the same model, H26M52103FMR. I don't have the original program for this model, I put my program for KD-55X8509C.
    The motherboard starts with orange/green led, and initial Sony music, but no picture and backlight. How can I switch the motherboard to 49 inches without picture? Is it possible?
    Or do I need to find the program that will work with this model?
    Thank you for your help
  • #2 21143077
    Lolo81700
    Help: 10
    Rate: 46
    with the right program, it works better.
    The reprogramming of the new eMMC worked perfectly with a dump found.
    Thanks repair friends
