Philips 43pfs4012/12 Dump Needed: TP.MS3463S.PB801 Main Board & K420WDKB Panel
batevlado 4368 5
  • #1 18901340
    batevlado
    Hello, does anyone have the dump for a Philips 43pfs4012/12?
    The main board is a TP.MS3463S.PB801 and the panel is k420wdkb Philips 43pfs4012/12 Dump Needed: TP.MS3463S.PB801 Main Board & K420WDKB Panel Philips 43pfs4012/12 Dump Needed: TP.MS3463S.PB801 Main Board & K420WDKB Panel
  • #2 18904819
    billobirillo
    Help: 338
    Rate: 798
    are you sure the panel code is K420WDKB? this panel is in the model 42PFS4012/12
    in the model 43PFS4012/12, the panel code should be K430WDK3
    do you confirm?
  • #3 18905073
    jeloi
    Help: 285
    Rate: 597
    Post the defective dump. I can repair.
  • #4 18918715
    batevlado
    Philips 43pfs4012/12 - dump Defekt
    • 43PFS4012-12_SW V1.1.9(MSD3463_S_SN51_69.bin).BIN (8 MB) You must be logged in to download this attachment.
    jeloi
    Help: 285
    Rate: 597
    Dump not read correctly.
    Try this one.
    • dump.ok.bin (5.4 MB) You must be logged in to download this attachment.
  • #6 18931909
    batevlado
    thanks everything works
