[Solved] Philips 42pfs4012/12 Boot Failure: Seeking TP.MS3463S.PB801 Dump for K420WDKB Panel
Acca85 9672 7
  • #1 18400894
    Acca85
    Rate: 19
    Hello, does anyone have the dump for a Philips 42pfs4012/12?
    The main board is a TP.MS3463S.PB801 and the panel is k420wdkb
    I've tried some dumps from some 40" and the TV starts but the picture isn't right.
  • #2 18401552
    Aquario_blue
    Level 19  
    Help: 41
    Rate: 155
    Try this 43 file
    • 43PFS4001 SPI.BIN (8 MB) You must be logged in to download this attachment.
  • #3 18402002
    Acca85
    Rate: 19
    Unfortunately it doesn't work, the TV boots but the image is not right and is upsidedown too
  • #4 18402252
    billobirillo
    Help: 338
    Rate: 798
    prova questo
    • PHILIPS_42PFS401212_UF1.bin (8 MB) You must be logged in to download this attachment.
  • #5 18402882
    Acca85
    Rate: 19
    No, non va.
    With this last firmware the screen seems to be ok but it doesn't fully boot just like the fw it came with.
    The Philips logo appears, then the bottom osd with the channel information starts flashing on and off, the TV won't accept any command.
    With the first firmware linked the TV works: I can enter the menu, change channels etc..the screen is flipped tho.
    querij
    Help: 42
    Rate: 227
    Try to update the firmware
    • 42PFS4012_12_FZ1_SDA17110434.zip (5.73 MB) You must be logged in to download this attachment.
  • #7 18405168
    Acca85
    Rate: 19
    MY DUDE! Fixed.
    Ok, the update did the trick.
    I'm gonna indicate 2 ways to fix this tv:
    1) In case the 25Q64 is good, like mine is, but compromised it is necessary to only copy the update file on a USB drive, plug it in and then plug the tv in. If the standby led stays red press power and wait: the led will flash slowly and then faster, in my case it never stopped flashing fast so I unplugged the TV from the AC. At reboot the TV worked.
    2) This could be helpful for other TV as well.
    I had the "wrong" firmware on the 25q64, the one linked before. The tv started, image was flipped and wrong, remote worked partially.
    You can press Menu (either on the remote or the tv) and then 1147 to enter service menu, in there you can enable mirror mode and change PANEL SETTING => Preset Panel ID so the image looks fine. In there you can also see what the update file should be named so the tv updates itself on boot, this information is located in the System info menu alongside with the board model and panel model the software is designed for.
    I renamed the update file from what it was to what this "wrong" software expected, it updated and at boot everything was set as expected for this tv, right panel, no mirroring, remote works.
    I've factory reset the TV and copied the firmware; I'm attaching it for you guys to use.
    • Philips 42pfs401212 25Q64.bin (8 MB) You must be logged in to download this attachment.
  • #8 18405301
    Acca85
    Rate: 19
    Infos in previous post
The discussion revolves around a boot failure issue with the Philips 42PFS4012/12 television, specifically related to the main board TP.MS3463S.PB801 and the K420WDKB panel. The original poster seeks a firmware dump to resolve the problem, as attempts with other firmware files resulted in improper image display and functionality issues. A successful solution was found by updating the firmware, which involved copying the update file to a USB drive and following specific steps to ensure the TV booted correctly. Additionally, accessing the service menu allowed for adjustments to the panel settings, which helped correct the image orientation and display issues.
