blaupunkt 49/1480-GB-11B-FEGBP-EU chassis T.MS3463S.711 will not start
mjoao 4701 13
Where can I get the correct dump/bin file for a Blaupunkt 49/1480-GB-11B-FEGBP-EU TV with T.MS3463S.711 so it will start?
Flash the TV with the shared BIN file; it was reported to work perfectly on this same set after use [#19041946][#19050095] If you are reading your own memory, make sure the dump is captured correctly as a full 8 MB image, because a faulty read was reported [#19049702] The board/panel combination mentioned in the thread is Sharp T.MS3463S.711 main AV board A16020570 with LC490DUY-SHA1 panel [#19043203]
  • #1 19038800
    mjoao
    Rate: 34
    Mark:BLAUPUNKT
    Model:49/1480-GB-11B-FEGBP-EU
    Chassis (main board, components):T.MS3463S.711
    LCD Screen/Panel (if exist):LC490DUY-SHA1
    More information: good morning, I'm looking for the dump for this TV BLAUPUNKT
    TCON:6870C-0532B
    if someone can provide thank you
    Manuel Joao
  • #2 19041589
    billobirillo
    Help: 338
    Rate: 798
    serial number?
  • #3 19041804
    mjoao
    Rate: 34
    BS49E148FMOPOE6Y-96140200560
  • #4 19041946
    billobirillo
    Help: 338
    Rate: 798
    use this bin file and let me know if it works correctly
    • MSD3463.bin (4.68 MB) You must be logged in to download this attachment.
  • #5 19042018
    mjoao
    Rate: 34
    I will use the file and then say something, thanks
  • #6 19042549
    jeloi
    Help: 285
    Rate: 597
    Post the defective dump.
  • #7 19043085
    mjoao
    Rate: 34
    Good morning, it didn’t work, maybe there’s another malfunction in the plate. I’ll try to find a new plate, thanks anyway.
    lisek
    Service technician RTV
    Help: 6352
    Rate: 6883
    Tylko 30.GBP Link
    Sharp t.ms3463s.711 main av board A16020570
    - screen LC490DUY-SHA1
    billobirillo
    Help: 338
    Rate: 798
    last chance
    • UF1.bin (8 MB) You must be logged in to download this attachment.
  • #10 19047634
    mjoao
    Rate: 34
    good morning send the original dump
    • BLAUP 49 1480.bin (2 MB) You must be logged in to download this attachment.
  • #11 19047639
    mjoao
    Rate: 34
    lisek wrote:
    Tylko 30.GBP Link
    had already seen but it is sold out
  • #12 19049702
    jeloi
    Help: 285
    Rate: 597
    Dump not read correctly. Need 8MB
  • #13 19050095
    mjoao
    Rate: 34
    Good morning and thanks for the file. Works perfectly, again thanks a lot
    billobirillo wrote:
    last chance
  • #14 21308675
    danutu71
    pentru BS49E148BFM0P0E06S am copiat dampul care îl atasez
    • GD25Q64B_20241118_170802.BIN (8 MB) You must be logged in to download this attachment.
The discussion concerns a Blaupunkt TV model 49/1480-GB-11B-FEGBP-EU with chassis T.MS3463S.711 and LCD panel LC490DUY-SHA1, which fails to start. The user requests a firmware dump for repair purposes. Respondents ask for the serial number (provided as BS49E148FMOPOE6Y-96140200560) and share a bin file to test. The initial firmware file did not resolve the issue, suggesting possible hardware malfunction. Additional advice includes verifying the dump size (8MB required) and sharing the original dump for further analysis. A related Sharp main AV board T.MS3463S.711 and TCON 6870C-0532B are mentioned. The user confirms successful operation after receiving a correct firmware file. A later post references a dump for a similar model BS49E148BFM0P0E06S.
TL;DR: Need the right dump for a Blaupunkt 49/1480 with T.MS3463S.711? Key detail: 8 MB SPI dump; "Dump not read correctly. Need 8MB." Use that as your baseline for firmware recovery. [Elektroda, jeloi, post #19049702]
Why it matters: This FAQ helps bench techs and DIY TV repairers resolve firmware-related no-boot issues on Blaupunkt T.MS3463S.711 sets.
Which exact Blaupunkt setup does this apply to?
This thread covers Blaupunkt 49/1480-GB-11B-FEGBP-EU with chassis T.MS3463S.711. The panel is LC490DUY-SHA1, paired with T-CON 6870C-0532B. The original request was for a firmware dump matching this configuration. [Elektroda, mjoao, post #19038800]
How do I fix a T.MS3463S.711 Blaupunkt that won’t start?
Follow this firmware path:
  1. Read and back up the SPI flash; confirm the file is exactly 8 MB.
  2. Program a matching 8 MB bin for your unit.
  3. Verify write, power up, and test inputs. An expert noted: "Dump not read correctly. Need 8MB." [Elektroda, jeloi, post #19049702]
Where do I get the correct bin file for this TV?
Share your TV’s serial when requesting help. A helper explicitly asked for the serial before sharing a bin. This ensures the file matches your hardware variant. [Elektroda, billobirillo, post #19041589]
What size must the SPI flash dump be?
Exactly 8 MB. Smaller or partial reads indicate an incorrect or failed dump. As one expert stated, "Dump not read correctly. Need 8MB." Verify file size before programming. [Elektroda, jeloi, post #19049702]
What if the first firmware file doesn’t work?
The OP reported the first attempt failed and suspected a board fault. Consider trying another matching bin and verify the 8 MB read. If still dead, inspect or replace the main board. [Elektroda, mjoao, post #19043085]
Did flashing the shared bin actually fix it here?
Yes. The OP confirmed success after flashing the supplied file, stating, "Works perfectly." That validated the firmware approach for this set. [Elektroda, mjoao, post #19050095]
Can I replace the main board instead of reprogramming?
Yes. A T.MS3463S.711 main AV board A16020570 matched to LC490DUY-SHA1 was referenced around £30. Board replacement is a practical alternative when firmware repair fails. [Elektroda, lisek, post #19043203]
What if the replacement board is out of stock?
Availability varies. The OP checked a suggested listing and noted it was sold out. If unavailable, set up restock alerts or seek a donor set. [Elektroda, mjoao, post #19047639]
Should I upload my defective dump when asking for help?
Yes. A contributor requested, "Post the defective dump." Experts can spot size issues, corruption, or mismatches and advise a correct file. [Elektroda, jeloi, post #19042549]
What serial did the original poster share for identification?
The OP provided serial BS49E148FMOPOE6Y-96140200560. Sharing the serial helps others match the correct firmware image. [Elektroda, mjoao, post #19041804]
Is there a shared dump for serial BS49E148BFM0P0E06S?
Yes. A user later attached a dump specifically for BS49E148BFM0P0E06S. Check their post for the file reference. [Elektroda, danutu71, post #21308675]
What panel and T-CON are paired with this chassis here?
This case uses the LC490DUY-SHA1 panel with T-CON 6870C-0532B. Matching these helps ensure firmware compatibility and stable operation. [Elektroda, mjoao, post #19038800]
Why do helpers ask for feedback after sending a bin?
It confirms compatibility and guides next steps. One helper said, "use this bin file and let me know if it works correctly." Feedback accelerates troubleshooting. [Elektroda, billobirillo, post #19041946]
