Connecting Two Pairs of Bluetooth Headphones to a Single Phone/Laptop: Procedures and Possibilities
greycat 76479 4
  • #1 19202471
    greycat
    Good morning,
    I really care about connecting two pairs of bluetooth headphones to one phone / laptop.
    Will it be possible and how can it be done?
    Thanks in advance for all the advice!
  • #2 19202502
    OPservator
    Help: 557
    Rate: 1247
    Depends on the software. JBL has its own applications for this, Samsung from what I know too.
  • #3 19202523
    greycat
    Thank you for your answer.
    Unfortunately, from what I can see, all the apps on JBL are hopeless (when it comes to an Android phone).
    Can someone recommend me a specific application with which I will be able to connect two pairs of headphones, but from different companies?
  • Dual-output Bluetooth transmitter recommendation
    #4 19202524
    Polon_us
    Help: 1184
    Rate: 1280
    greycat wrote:
    two pairs of bluetooth headphones for one phone / laptop.
    You can connect two pairs of headphones to a phone or TV.
    The only question is whether both will work at the same time, because from what I can guess, this colleague depends on it.
    If the attempts with the phone / TV are unsuccessful, I would suggest looking for BT receivers / transmitters that allow up to two devices to work simultaneously, in this case two pairs of headphones at the same time. There are many such devices on Allegro.
    This receiver / transmitter can be connected to a laptop or phone in analog, i.e. via a mini-jack socket.
    This is one option that you can consider to fix the problem :)
  • #5 20331916
    miroslawbeza
    Try installing the audio router.exe program on your computer. I was also looking for a solution and it works for me. Plays sound on two pairs of headphones at the same time.
