How to Seamlessly Pair Android to Multi-Transmitter Bluetooth Audio Module Without Selection
645 8
  • Clarifying seamless pairing to multiple Bluetooth transmitters
    #1 21667190
    Johnny Sandberg
  • #2 21667191
    Mark Harrington
  • #3 21667192
    Johnny Sandberg
  • Only one Bluetooth stream can be active at a time
    #4 21667193
    Mark Harrington
  • Bluetooth security and remote-control risks
    #5 21667194
    Mark Harrington
  • Bluegiga WT32 firmware supports multiple connections
    #6 21667195
    Johnny Sandberg
  • #7 21667196
    Johnny Sandberg
  • Bluetooth supports streaming to multiple receivers
    #8 21667197
    Johnny Sandberg
  • Bluetooth security concerns and background pairing risks
    #9 21667198
    Mark Harrington
The discussion addresses the challenge of streaming audio from an Android device to multiple Bluetooth receivers simultaneously without requiring manual selection between multiple transmitters. It is clarified that standard Bluetooth A2DP profiles typically allow only one active audio stream connection at a time, although devices can maintain paired records with multiple units. Some Bluetooth modules claim support for up to seven connections, but this generally means holding paired device records rather than simultaneous streaming. An alternative approach considered is rapid sequential streaming to multiple receivers, potentially minimizing perceptible delay. The Bluegiga WT32 module is mentioned as a candidate hardware platform, with connection capabilities dependent on firmware. Official Bluetooth specifications indicate that a piconet can support communication with up to seven devices, and a 2008 Bluetooth whitepaper suggests multi-headphone audio streaming is possible. However, practical implementation complexities and security considerations are noted, emphasizing the need for specialized software and firmware support to achieve seamless multi-device audio streaming.
