[Solved] I need Firmware for ARIELLI LE - I need Firmware for ARIELLI LED 3219 HD
DELFINI 8850 5
  • #1 19293693
    DELFINI
    I need Firmware for ARIELLI LED 3219 HD. My email is "delfini33@gmail.com"[/syntax]
  • #2 19305647
    kroscho
    Rate: 8
    chassis hk-t.rt 295761
    • Arielli_LED3219HD_HK-T.RT295761_25Q64.rar (7.03 MB) You must be logged in to download this attachment.
  • #3 19306364
    DELFINI
    Thanks for sending the TV file ARIELLI LED-3219 HD but I wanted it in a format IMG (no bin format) to get it on TV with a USB stick.
    TV chassis is the HK-T.RT2957P61
    Email delfini33(_at_)gmail.com
    Thanks
  • #4 19307395
    jeloi
    Help: 285
    Rate: 597
    There is no chassis for that with a USB stick!
    kroscho
    Rate: 8
    Unzip and save to an empty flash drive. Turn on the flash drive in the TV, then you turn on the power plug. Do not turn off while the upgrade is in progress.
    • arielli 3219hd.rar (10.16 MB) You must be logged in to download this attachment.
  • #6 19334300
    DELFINI
    Thanks a lot for the help, the TV worked
