MAN Diesel 6 x 4 Horse F2000 - I am in need of a wiring/electrical diagram for M
DavidDelco 2520 4
  • #1 19881732
    DavidDelco
    Good day,
    I am in need of an electrical/wiring diagram for 1999 MAN t81 F2000 truck tractor horse 6x4.
    I have need to rewire chassis and repair cab wires, as the vehicle is 1999, and all electricians have shown their mark in the loom.
    It is now time for a complete rewire.
    I will appreciate a diagram in English, yet if not available, I suppose another language will do.
    Your help is most appreciated.
    Kind Regards
    David
  • #3 19888937
    DavidDelco
    Hello. Thank you for the response.
    I went to the link, registered and joined up.
    The link which showed has an icon for pictures, but if I select then it shows "no picture available."
    I spent some hours on this site trying this and that.
    I need to go to the interpreter mostly so I go slow.
    I will try again later in the evening.
    I bought a truck and all the wires are either corroded, burnt, broken or ripped up. It is a mess.
    I have managed to do the re-pipe for all the pneumatics, fitted all new valves and boosters. All air systems are good and tested.
    The last major item is to make the electric safe and original.
    I appreciate all help and intended help.
    Kind Regards
    David
  • #4 19890413
    DavidDelco
    Hello, Thank you.
    I was able to receive help on that site you sent me.
    Very helpful.
    Cześć Dziękuję.
    Mogłem otrzymać pomoc na tej stronie, którą mi wysłałeś.
    Bardzo pomocne.
  • #5 19892311
    darfur5
    Help: 267
    Rate: 1708
    Hello! Sometimes the archive files are empty but I can see that you are not giving up!
