MAN F 2000: Brake Pedal & APS Pneumatic Connection Diagram - Identifying Individual Tekalons
gajowy 100 9870 7
  • #1 16592909
    gajowy 100
    I am asking for a connection diagram of the brake pedal and APS with a hint where the individual tekalons go
  • #2 16606852
    zycior
    Help: 5
    Rate: 13
    Diagram from model F2000 26.414 6x2 2001
  • #3 16608531
    gajowy 100
    Thank you, the diagram helped me a lot, although I have four axles
  • #4 16608974
    zycior
    Help: 5
    Rate: 13
    Enter VIN, I will send you a diagram specifically for your car.
  • #5 16610262
    gajowy 100
    WMAT45ZZZ1M310584
    zycior
    Help: 5
    Rate: 13
    The complete pneumatic system of your car with a list of components is attached. Everything that was available for your car on the MAN After Sales Portal.
    best regards
    • WMAT45ZZZ1M310584.zip (1.07 MB) You must be logged in to download this attachment.
  • #7 16612392
    gajowy 100
    Thank you very much . I appreciate your help.
  • #8 21744388
    Grzegorz Kry
    Hello, I will renew the topic. I have a MAN F2000, VIN WMAT32ZZZYM289573. There is the same problem with the air, but a bit in the opposite direction, air is escaping from the main foot valve when the handbrake is applied. I followed the diagram and on the G7 foot valve I unscrewed the line from socket 21 and air comes out of the line when the handbrake is applied. This wire goes to G16/G54 but I can't work out what the valve is. If the manual is released, everything is ok, I am ruling out the actuators. Please help, thank you in advance.
    Added after 4 [hours] 9 [minutes]:
    Fault cleared , my fault was that I looked at the wrong plan , I did not see the trailer control valve G17.201 on it , it was the cause , thank you and sorry for the trouble.
✨ The discussion revolves around obtaining a connection diagram for the brake pedal and APS (Air Processing System) of the MAN F 2000 model. A user initially requested a diagram indicating the placement of individual tekalons. A response provided a diagram for the F2000 26.414 6x2 model from 2001, which was helpful to the user, who noted having a four-axle vehicle. Further assistance was offered by requesting the vehicle's VIN to provide a more specific diagram. A comprehensive pneumatic system diagram and component list were later shared, sourced from the MAN After Sales Portal, which the user appreciated.
