Searching Flash and EMMC File for Philips 55PUS7502/12 Main Board 715G8465-MOD-B00-005T
E2000 5697 8
  • Requesting flash and eMMC files for Philips 55PUS7502/12
    #1 20809634
    E2000
    Level 4  
    Hello, when the TV turns on, the PHILIPS logo appears, and then the screen turns black with LED lighting. After a few minutes of use, it restarts again. I am looking for the FLASH and EMMC files.
    Can you tell me where to download them?
    Thank you in advance.
    Model: Philips 55PUS7502/12
    Chassis: TPM17.1ELA
    Mainboard: 715G8465-MOD-B00-005T
    FLASH: MX25L1606EM2I-12G 16Mb SOP-8(200m)
    EMMC: THGBMHG7C2LBAIL 16GB BGA-153
  • #2 20810440
    lisek
    Service technician RTV
    Help: 6353
    Rate: 6884
    Page (UA) for Philips Link ,, FW (Ukrainian version.).
  • #3 20815844
    E2000
    Level 4  
    Hello, on this page I can only download the firmware for USB, I need the firmware for eMMC, thanks for responding
  • #4 20818358
    sergiy141
    Help: 26
    Rate: 70
    Have you found the firmware? There is a snapshot of other models, but on this chassis.
  • #5 20820187
    E2000
    Level 4  
    Hello, I have not found the firmware. If you can send me the files for another model, I would appreciate it. Greetings.
  • #6 20821105
    Lolo81700
    Help: 10
    Rate: 46
    Hello, have you tried the upgrade_loader.pkg?
    Before changing the memory, it is best to have the software repaired by Philips' basic software.
  • #7 20824123
    E2000
    Level 4  
    Hello, I have not tried this basic repair system, where could I download this file?
  • #9 20827205
    E2000
    Level 4  
    Hello, I tried to update the firmware, and the TV has the same problem.
    I'm going to replace the motherboard.
    Thank you.
The discussion revolves around a Philips 55PUS7502/12 TV experiencing issues where it displays the PHILIPS logo before the screen turns black and restarts after a few minutes. The user is seeking FLASH and EMMC firmware files for the main board model 715G8465-MOD-B00-005T. Responses include suggestions to check for firmware updates, specifically mentioning the upgrade_loader.pkg for software repair. However, the user reports unsuccessful attempts with firmware updates and plans to replace the motherboard as a final solution. Links to firmware archives are provided, but specific EMMC files remain elusive.
