LG 55UC970V Wont Start: Limited eMMC Access Despite Reprogramming
Lolo81700 1776 1
  • Limited eMMC access despite matching firmware contents
    #1 21098738
    Lolo81700
    Help: 10
    Rate: 46
    brandt: LG
    Model: 55UC970V
    motherboard: EAX66104204
    Hello repairer friends
    I received this TV for a customer, once turned on, no indicator, no backlight, no optical indicator
    The R5F100GEA standby micom responds to the button and the remote control. The micom starts the main microprocessor power supplies, there is access to SPI MX25L3205 and eMMC (oscilloscope measurements). Access to the eMMC is too short for full firmware loading.
    I took the eMMC apart to read and compare it with the contents of another eMMC found on a repair forum. The reading of my memory is consistent with that of comparison, whether by sector or content.
    I did the same for the SPI and EEPROM.
    I reprogrammed the memories with the recovery content from the friend's site, and the result is the same. I still have limited access to the eMMC from the microprocessor.
    Do you have any ideas to share with me? THANKS
  • #2 21099534
    sergiy141
    Help: 26
    Rate: 70
    First check the boot configuration. Reset function [162] 0x00
    Boot configuration [179] 0x78
    Boot bus [177] 0х00 Besides, in these cases there is often a problem with the processor, warm it up without fanaticism.
