Grundig 55 GUB 8962 LCD TV: Black/White Screen Issue with T-Con Ribbon Disconnection
cszrwi 1467 3
  • #1 21308103
    cszrwi
    Diagnose Grundig LCD TV panel problem. 55"
    LCD TV No Picture backlight OK sound OK. Power voltages OK and Mainboard is OK, Disconnecting the T-Con board left and right ribbons gives same results both sides. Disconnected side is white and connected side is black no trace of a picture on either side. When I swap over which ribbon is disconnected it gives the same result just different sides.
    I can not find any faults in voltages on the T-Con and only one leak to earth on one side of the screen (thin boards connected to foils) but even though the resistance on the DMM is only 35 ohms it does not seem to drop the voltage down. The voltage is 1.8 volts. There must be no current flowing.
    What does it tell us when we have black half and white half screen when disconnecting one of the TCon ribbons, same on either side?
    Does anyone have any clues? Thanks Rob
    AI: Could you please provide the specific model number of your Grundig 55 LCD TV? TV is Grundig 55 GUB 8962 Main board is Z02190R-5 T-Con is 6870C-0769A Panel is LC550EGY SLA1 AI: Were there any recent changes or events, such as a power surge or physical damage, before the issue with the screen started? The TV used to start with a Black screen but with the sound OK and after about 30 mins the picture would appear. Now the TV standby seems to time out before the picture comes on. TV will come on Backlight and sound screen black then after about 30 mins it will go back to standby.
  • #2 21312211
    abramkyr1995
    >>21308103 Not worth repairing! May the problem inside the panel.
    If you want to try, search for pinout on T-CON and cut on board some signals.
  • #3 21312569
    lisek
    Service technician RTV
    Help: 6332
    Rate: 6843
    White screen (half) .... is no power to the matrix
    T-con has been written about Link .
  • #4 21362897
    cteespinho
    Coff problem?
