Grundig 40 VLE 2012 EC/LBM000 - Black Screen Issue, LED or Firmware Update?
bruh123 2190 1
  • #1 19410868
    bruh123
    Hello!
    I have a problem with my TV, a Grundig 40 VLE 2012 EC, the symbol is LBM000, there is also another code LTA400HM13-C09 at the bottom of the back cover. The TV has power, I can turn it on, the Grundig logo is displayed, but after that the screen is pitch black. If I inspect it with a flashlight, I can see that everything works fine, for example when I change channels, the sound works as well.
    My questions are:
    Are my LEDs fried or can I update the firmware of the TV to fix the issue?
    If I can update the firmware or even reflash it with an older version, where can I get a firmware package for this model of Grundig TV?
    Thank you in advance!
  • #2 19412691
    zdzich42
    Help: 587
    Rate: 867
    The led tester will tell you the truth. If you don't have, disassemble the matrix.
