MEC1732 EEPROM Erase Instructions Needed from Datasheet DS00003583G
jawaljawad 624 1
  • No dedicated pin for MEC1732 EEPROM erase
    #2 21448303
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    jawaljawad wrote:
    Hey https://ww1.microchip.com/downloads/en/DeviceDoc/MEC172x-Data-Sheet-DS00003583G.pdf. This document for mec1732 I need erase eeprom interne with pin @ElektrodaBot
    Initial Assessment of Available Information
    You referenced the Microchip MEC172x datasheet (DS00003583G) for the MEC1732 device, specifically asking whether it is possible to erase its internal EEPROM using a dedicated pin. The sample answers suggest that there is no single “erase” pin that directly triggers an internal EEPROM erase. Instead, the EEPROM (or in some references, the emulated EEPROM within flash memory) is typically erased through software commands, debug interfaces (like JTAG or SWD), or specialized programming tools.
    Direct Answer to the Question
    Based on both the datasheet and Microchip’s typical embedded controller implementations, there is no single physical pin on the MEC1732 that performs a direct “erase internal EEPROM” function. To erase the device’s non-volatile memory:
    1. Use the debug/programming interface (JTAG, SWD, or proprietary in-circuit programming tools) or,
    2. Use firmware-based erase commands if the device is accessible through a host interface (SPI, I2C, LPC, or eSPI), depending on your system design.
    In other words, a simple external pin-toggling sequence to erase EEPROM does not exist on the MEC1732.
    Detailed Problem Analysis
    1. Nature of MEC1732 Memory
    According to Microchip’s documentation, the MEC172x/MEC1732 family often uses internal flash or flash-backed registers to emulate what some call “EEPROM.” This memory is integrated with the embedded controller’s architecture.
    2. No Dedicated Erase Pin
    The device datasheet does not list a specialized hardware pin (e.g., “Erase#”) that triggers a memory erase. Some microcontrollers do provide factory-reset or secure erase pins, but the MEC1732 does not appear to facilitate bulk EEPROM erasure purely through pin manipulation.
    3. Erasing via Software or Debug Interface
    - A typical erase sequence involves:
    1. Writing to control registers or using special unlock sequences to enable write/erase operations.
    2. Issuing an erase command to the flash controller.
    3. Waiting for the operation to complete by polling status bits.
    - Debug tools such as MPLAB ICD (In-Circuit Debugger), pickit units, or third-party programming hardware can invoke chip-erase commands or sector-erase commands on the MEC device.
    4. Use of Reset Pin
    The device has reset pins (often labeled EC_RST#). While toggling these pins resets the microcontroller, it does not erase internal memory. Thus, simply grounding or pulsing the reset line will not remove data in the EEPROM region.
    5. Security and Lock Bits
    Some MEC devices have optional security features that lock down the flash region. Erase operations may require further steps, such as unlocking or clearing security registers before full or partial erasure can occur.
    Current Information and Trends
    Many modern embedded controllers, particularly those featuring onboard EEPROM or flash, rely on:
    - Software-based bootloaders,
    - Vendor-provided development tools,
    - Comprehensive debug interfaces (JTAG, SWD, eSPI),
    - Command-based erase sequences.
    It is increasingly uncommon to have a dedicated hardware pin for mass erase, especially in embedded controllers intended for complex host systems. The approach typically used is a software-based or debugger-based sequence to protect the device from accidental or malicious erasures.
    Supporting Explanations and Details
    - Why no dedicated pin?
    Microcontrollers and especially embedded controllers used in PCs or laptops (like the MEC series) incorporate security features and complex memory management. A dedicated “erase everything” pin could be a security vulnerability. Hence, the typical approach is to require authorized firmware or debug-level access.
    - What about older EEPROM devices?
    Older, standalone EEPROM chips (e.g., 24C-series or 93C-series) might have dedicated pins or simpler hardware triggers. The MEC1732, being an advanced embedded controller, centralizes erase and programming functionalities within its internal logic and expects an external host or debug tool to orchestrate those operations.
    Interdisciplinary Connections
    - Firmware Development: Knowledge of the firmware or bootloader is crucial for sending any erase commands.
    - Hardware Security: Hardware-based secure erase solutions often consider cryptographic erasure or overwriting strategies rather than just toggling a pin.
    Ethical and Legal Aspects
    Erasing firmware or configuration data on critical systems (e.g., in automotive or medical applications) must comply with safety and regulatory constraints so that an accidental or malicious erase does not compromise the device’s functional safety.
    Practical Guidelines
    1. Obtain the Proper Tools: Use Microchip’s MPLAB IPE or a third-party debugger.
    2. Check Security/Lock Bits: Ensure the device is not locked before attempting an erase.
    3. Perform a Backup: If possible, back up the existing firmware or configuration data to avoid losing valuable or calibration data.
    4. Follow the Datasheet: Consult the memory programming chapter in the datasheet or supplementary Microchip tech notes that might give step-by-step instructions.
    Possible Disclaimers or Additional Notes
    - Any procedure that erases embedded memory should be undertaken with caution, as it is generally irreversible.
    - If the MEC1732 is part of a system that has other dependencies, erasing might disrupt or damage the overall platform if not done in a controlled manner.
    Suggestions for Further Research
    - Microchip’s Programming Specification: Look for a separate “MEC1732 Programming Specification” if available.
    - Application Notes: Microchip often publishes application notes detailing recommended steps for erasing and reprogramming.
    - Development Board Documentation: If using a development kit for MEC172x, see what example erase routines exist in provided firmware.
    Brief Summary
    There is no single “erase EEPROM” pin on the MEC1732. Instead, you must use either an authorized debugging/programming interface or appropriate firmware-level commands to erase its internal memory. This design minimizes accidental erasure and enhances security. Consult Microchip’s programming specifications, use debugging tools (like MPLAB ICD or other compatible programmers), or implement the appropriate memory erase commands through the device’s interface.
    Questions for the User
    1. Which interface (I2C, SPI, eSPI, JTAG, etc.) do you currently have available for the MEC1732?
    2. Are you trying to perform a mass erase or selectively erase certain sections?
    3. Do you have access to Microchip’s MPLAB-based programming environment or a similar debug tool?
    Feel free to follow up with any specific details about your development setup and goals. That information will help refine the erase procedure and ensure you can successfully clear the EEPROM region on the MEC1732.
