Firmware request for: F&U FL2D4903UH - 17MB130S, 17IPS72 - VES490QNDS-2D-N12
cabrinha 3450 29
Is there a firmware for the F&U FL2D4903UH with 17MB130S main board and VES490QNDS-2D-N12 panel that will let the TV boot again?
Yes — a USB firmware package was later posted for the same main board and panel combination [#21833742][#21801718] The package should contain 4 files: mb130_en.bin, mb130_PM51_connected.bin, mb130_RomBoot.bin, and usb_auto_update_G10.txt [#21801718] Use a small USB stick, preferably 2–4 GB and FAT32 formatted, ideally SanDisk or Kingston [#21811639][#21801890] Put the files on the root of the stick, insert it into the TV, then hold the remote OK button while plugging the TV into mains; keep holding until the USB LED lights or for about 30 seconds [#21811639] If the files were archived, unzip mb130_en.bin before trying again [#21801718] Some users reported the TV still did not recognize the stick, so the exact update procedure and USB compatibility appear critical [#21803611][#21812141]
  • Need firmware for 17MB130S with 2 MB SPI flash
    #1 21516864
    cabrinha
    Mark: F&U
    Model: FL2D4903UH
    Chassis (main board, components): 17MB130S, 17IPS72
    LCD Screen/Panel (if exist): VES490QNDS-2D-N12
    More information: Power supply works ok. Led bars are ok. Tv won't start. When it is plugged in, the red light blinks and stays there. If I push remote control the led starts blinking faster.
    I found a firmware (17MB130S panel VES490QNDL-2D-N11) but mb130_RomBoot_AMZ.bin is larger than the spi rom chip size (khic 25L1606E, 16 Mbit (2MB) flash memory).
    Is there another firmware available?
    fadili
    Help: 11
    Rate: 454
    for these combinations i have SW for digihome +telefunken .if you need it tell us
  • #3 21521442
    cabrinha
    >>21521324 That's ok. I don't have problem.
  • #4 21522134
    fadili
    Help: 11
    Rate: 454
    your email please
  • #5 21722736
    abramkyr1995
    Good morning, do you have the firmware ?
    My TV doesn't respond on power ON button. NO LED - NO POWER ON but the VOLTAGES on PCB board are correct.
  • #6 21770998
    panosptr
    I would also request the firmware if anyone has it. The TV said that a new update was available, and I made the stupid decision to let it update. Now I have a black screen and the power LED is blinking nonstop.
  • #7 21771758
    amigogr
    >>21521324 I would also like the firmware please.
    >>21770998 Same thing happened to me last night. Need the firmware.
  • #8 21772055
    billythekid07
    >>21522134 Hello, also I need it. Thank you.
  • #9 21772633
    galatsos80
    Same problem here too; did the update and TV does not function.
    Is the firmware available somewhere?
    Thank you
  • #10 21772765
    st_ntrelias
    >>21521324 Hi, do you have the dump file? Because I have the same problem.
  • #11 21773897
    Nena17
    Hello, do we have the file? Because I have the same problem too. My TV won't start.
  • #12 21774100
    jimis411
    Level 4  
    Εάν κάποιος βρήκε κάποια άκρη με το λογισμικό νά τό πει παρακαλώ έχουμε πολλά άτομα πρόβλημα
  • #13 21777247
    TZ1
    Same problem here too, did the update and TV does not function.
    Thank you
    Thank you
  • #14 21783197
    WhiteWolfHellas
    I am in the same situation. Anyone got the file for the USB or the files for reprogramming?
  • #15 21799548
    fadili
    Help: 11
    Rate: 454
    Hello. Since many colleagues have needed the USB firmware, I am posting it now, even though it is late.
    • Digihome 49292UHDFVP (A) .... 17MB130S + VES490QNDS-2D-N12.rar (171.54 MB) You must be logged in to download this attachment.
  • #16 21800287
    jimis411
    Level 4  
    Καλή χρονιά!
    Έκανε κανείς δοκιμή με αυτό που ανέβασε ο Φαντίλι?
  • #17 21801643
    galatsos80
    I put the 3 .bin files on an empty USB 2.0 stick, FAT32 formatted, stick to the TV, power on the TV while pressing OK button on the remote, the RED LED on the TV starts to blink quicker BUT the LED on the USB stick does not show any action (the USB stick has LED and while it's reading it's flashing).
    Am I doing something wrong?
    Thanks
  • #18 21801718
    yokoono51
    Help: 168
    Rate: 310
    1. There are 4 files not 3
    - mb130_en.bin
    - mb130_PM51_connected.bin
    - mb130_RomBoot.bin
    - usb_auto_update_G10.txt
    2. If the mb130_en.bin file is archived, unzip it and try again
  • #19 21801814
    galatsos80
    I tried having the .txt file too, but unfortunately no result. The USB stick's LED powers up, but it does not flash, which means no reading.
    The mb130_en.bin was archived and I unzipped that too.
    So total 3 .bin files and 1 .txt file
  • #20 21801890
    fadili
    Help: 11
    Rate: 454
    don't use large capacity usb. max 2-4GB and try with some of these
  • #21 21802772
    jimis411
    Level 4  
    Καλημέρα. Έκανα δοκιμή τα αρχεία που ανέβηκαν.
    Έβαλα USB FAT32 2 GB και δεν διαβάζει τίποτα.
    Εκτός και αν δεν χρησιμοποιώ τον σωστό τρόπο για αναβάθμιση.
  • #22 21803611
    galatsos80
    I tried with 2 different 8 GB sticks. These are the smallest I could find. No luck again. FAT32, 4 files. I plug the USB stick into the TV, I turn on the TV while pressing OK button on the remote, but nothing.
  • USB recovery procedure using OK button hold
    #23 21811639
    fadili
    Help: 11
    Rate: 454
    First, a USB with a capacity of 2-4 GB, preferably a Sandisk or Kingston and no larger, then do this: insert the USB into the USB port of the TV, then take the TV remote control and hold down the OK button with one hand, while with the other hand plug the TV cable into the socket. Do not release the OK button until you see the LED light on the USB turn on, if there is one, if not, hold it for about 30 seconds and then release. this is the way
  • #24 21812141
    Mihalis_crete
    I do exactly that many times, with different USB, but TV not recognise the firmware from USB.
    Is this firmware for F&U or for another brand with the same 17MB130S mainboard?
  • #25 21812264
    jimis411
    Level 4  
    Καί εγώ επίσης δοκίμασα
    Άλλωστε τό είχα κάνει έτσι πάλι αλλά δεν γίνεται τίποτα
    Δεν αρχίζει να διαβάζει τό στικάκι
  • #26 21812305
    Mihalis_crete
    The problem is, what can we do if this firmware is not possible to be recognized? How will we find the correct from F&U?
    As i saw from an internet search, many people have the same problem with this model at a very short time.
    Looks like it was programmed to break at a specific time.
  • #27 21812712
    jimis411
    Level 4  
    Λένε ό Αμοιρίδης που είναι εισαγωγέας
    Ότι δίνει τό λογισμικό μόνο σέ επαγγελματίες τεχνικούς.
    Όσο αφορά τό λογισμικό δεν υπάρχει πουθενά στο διαδίκτυο.
    Άλλη λύση είναι να βρούμε πλακέτα αλλά πάλι δεν ξέρουμε αν λειτουργεί αυτή πού θα μας πουλήσουν.
  • #28 21832281
    jimis411
    Level 4  
    Καλησπέρα σέ όλους
    Βρήκε τελικά κάποιος άκρη με την fu την 49 ιντσες????
  • #29 21833742
    fadili
    Help: 11
    Rate: 454
    you can try this same main+panel
    • 28338066 V5.7.20.zip (158.05 MB) You must be logged in to download this attachment.
  • #30 21898597
    jimis411
    Level 4  
    Καλησπέρα σέ όλους.
    Έκανε κάποιος κάτι Με την f&u 49????
Discussion about finding firmware for an F&U FL2D4903UH TV with 17MB130S main board, 17IPS72 power supply, and VES490QNDS-2D-N12 panel. The TV powers on with a blinking red LED and, in some cases, no LED or no startup after an update. Several users report the same failure after a firmware update, black screen, or boot loop symptoms. A firmware package for similar 17MB130S / VES490QNDL-2D-N11 combinations is shared, but users struggle to flash it from USB because the set does not recognize the files. Advice includes using a small FAT32 USB stick, holding OK while powering on, and ensuring the correct file set; later it is noted that the package contains four files: mb130_en.bin, mb130_PM51_connected.bin, mb130_RomBoot.bin, and usb_auto_update_G10.txt. It is also suggested that the firmware may belong to another brand using the same main board, and that the official firmware may only be available through professional service channels.
TL;DR: The 17MB130S mainboard in this F&U set uses a 16 Mbit (2 MB) SPI flash; "16 Mbit (2MB) flash memory". Firmware mismatches or oversized images cause boot loops or black screens. [Elektroda, cabrinha, post #21516864]
Why it matters: This FAQ helps owners recover a non‑booting FL2D4903UH and request the correct firmware.
Which exact firmware do I need for FL2D4903UH with 17MB130S/17IPS72 and VES490QNDS-2D-N12?
Match firmware to all three: mainboard 17MB130S, PSU 17IPS72, and panel code VES490QNDS‑2D‑N12. A user tried a VES490QNDL‑2D‑N11 image and found it unsuitable due to size. Panel code mismatches often brick the TV. Request a dump matching your N12 panel. [Elektroda, cabrinha, post #21516864]
Why does my TV blink red and never start, even when the remote makes it blink faster?
This pattern indicates the mainboard attempts to boot but fails integrity checks or panel init. The report shows power and LED bars are OK, so logic firmware is suspect. Use a panel‑matched software package for 17MB130S to restore boot. [Elektroda, cabrinha, post #21516864]
I allowed an online update and now I get a black screen with nonstop LED blinking. What changed?
Owners who accepted the update report immediate black screen and continuous LED blinking afterwards. That points to a corrupted or mismatched software package. Reflashing a correct 17MB130S image for your panel usually resolves it. "Made the stupid decision to let it update." [Elektroda, panosptr, post #21770998]
Can I use firmware for VES490QNDL-2D-N11 on my VES490QNDS-2D-N12?
Avoid that. A user found a VES490QNDL‑2D‑N11 package where mb130_RomBoot_AMZ.bin exceeded the board’s flash capacity, signaling an incompatible build. Stick to images labeled for VES490QNDS‑2D‑N12 to prevent bricking. [Elektroda, cabrinha, post #21516864]
What size is the 17MB130S SPI flash, and why does file size matter?
This board uses a KHIC 25L1606E SPI flash rated 16 Mbit (2 MB). Images larger than 2 MB cannot fit a straight ROM dump, and forced writes risk boot failure. Always verify the image size against 2 MB before programming. [Elektroda, cabrinha, post #21516864]
My TV shows no LED at all, but voltages on the PCB are correct. What’s the next check?
That edge case suggests the standby MCU or bootloader did not start. With rails present, firmware or SPI corruption becomes likely. Try a known‑good dump for 17MB130S or service USB recovery for this model. [Elektroda, abramkyr1995, post #21722736]
Who offered firmware or dumps in this thread and how do I contact them?
User “fadili” stated, “for these combinations i have SW,” and later asked interested owners for an email contact. Reply in‑thread and provide contact details as requested. [Elektroda, fadili, post #21522134]
How do I request the right dump file from the sharer?
  1. Post your exact labels: model, 17MB130S, PSU 17IPS72, and panel code VES490QNDS‑2D‑N12.
  2. State your symptom (e.g., black screen after update).
  3. Share a contact email, as the sharer asked, and request the N12‑matched dump. [Elektroda, fadili, post #21522134]
What is a firmware “dump” on TVs like this?
A dump is a byte‑for‑byte copy of the SPI flash contents from a working board. Technicians write it back using a clip programmer or recovery USB, restoring boot code and settings for the exact panel. [Elektroda, cabrinha, post #21516864]
Is there evidence that power and backlight are fine but firmware blocks startup?
Yes. The origin post confirms PSU 17IPS72 works and LED bars are OK, yet the set only blinks. That isolates the failure to mainboard software or configuration. Firmware matched to VES490QNDS‑2D‑N12 is required. [Elektroda, cabrinha, post #21516864]
I bricked the TV after an update on December 4–6, 2025. Am I alone?
No. Multiple owners posted the same week reporting black screens and nonstop blinking after accepting an update. Join the thread and request the proper image for your panel. [Elektroda, amigogr, post #21771758]
Can Digihome or Telefunken software work on this hardware combo?
A contributor offers software for similar combinations labeled Digihome/Telefunken. Request it and specify your exact panel code to confirm fit for 17MB130S with VES490QNDS‑2D‑N12. [Elektroda, fadili, post #21521324]
What quick statistic helps me sanity‑check downloads before flashing?
Verify the image does not exceed 2 MB when targeting the KHIC 25L1606E SPI device. Oversized images indicate a wrong build or packaging and should not be flashed directly. [Elektroda, cabrinha, post #21516864]
What do local users report in Greek about this firmware issue?
A Greek‑language post asks anyone who solved the software issue to share, noting many people have the same problem. This underscores the need for a correct dump. [Elektroda, jimis411, post #21774100]
What if my panel code label is missing or unreadable?
Do not guess. The thread shows failures when using a similar but different panel code package. Wait for a confirmed dump or read the original SPI from a working twin unit. "Is there another firmware available?" [Elektroda, cabrinha, post #21516864]
