[RTL8710CF] How to Reflash Firmware on Kasa HS103 WiFi Plug Mini
Jerther 87 0
  • #1 21552681
    Jerther
    Level 4  
    HS103P2 is just a pack of 2 HS103. I think the version is more important, but you'll only know that by reading the label on the device, and ultimately you'll have to compare the innards with what I posted. If the microcontroller is the same but the board is different, openrtl should work but you may have to figure out how to flash it and what its gpio layout is.
    Skasowano z tematu: [RTL8710CF] How to Reflash Firmware on Kasa HS103 WiFi Plug Mini
    przez Jerther dnia 18 May 2025 12:12
