You're viewing a topic that has been removed.
Experience? / ONENUO 228WTH Smoke Detector with Temp/Humidity: OBK Flashing, Chip Info, Battery Life
io2345 120 0
  • #1 21580054
    io2345
    >>21579263 I did flash OBK in the meantime.
    Obviously you cannot set the channelType at whatever value. Look at a log:
    Info:MAIN:Time 18, idle 181045/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:TuyaMCU:Received: 55 AA 00 05 00 08 17 02 00 04 00 00 00 CD F6
    Info:TuyaMCU:ProcessIncoming[v=0]: cmd 5 (WiFiSelect) len 15
    Info:TuyaMCU:V0_ParseRealTimeWithRecordStorage: processing id 23, dataType 2-val and 4 data bytes
    Info:TuyaMCU:V0_ParseRealTimeWithRecordStorage: int32 205
    Info:GEN:CHANNEL_Set channel 23 has changed to 205 (flags 0)
    Info:MQTT:Channel has changed! Publishing 205 to channel 23
    Info:MQTT:Publishing val 205 to Rauchmelder/23/get retain=0
    Info:MQTT:Publishing val 3 to Rauchmelder/sockets retain=0
    Info:MAIN:Time 19, idle 184373/s, free 58496, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MQTT:Publishing val -55 to Rauchmelder/rssi retain=0
    Info:MAIN:Time 20, idle 187486/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:GEN:dhcp=0 ip=192.168.0.38 gate=192.168.0.1 mask=255.255.255.0 mac=38:a5:c9:db:de:73
    Info:GEN:sta:rssi=-55,ssid=Hausnummer28,bssid=2c:3a:fd:ce:a8:2e,channel=13,cipher_type:CCMP
    Info:MQTT:Publishing val 20 to Rauchmelder/uptime retain=0
    Info:MAIN:Time 21, idle 184582/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:TuyaMCU:Received: 55 AA 00 05 00 08 18 02 00 04 00 00 00 3C 66
    Info:TuyaMCU:V0_ParseRealTimeWithRecordStorage: processing id 24, dataType 2-val and 4 data bytes
    Info:TuyaMCU:V0_ParseRealTimeWithRecordStorage: int32 60
    Info:GEN:CHANNEL_Set channel 24 has changed to 60 (flags 0)
    Info:MQTT:Channel has changed! Publishing 60 to channel 24
    Info:MQTT:Publishing val 60 to Rauchmelder/24/get retain=0
    Info:MQTT:Publishing val 70192 to Rauchmelder/freeheap retain=0
    Info:MAIN:Time 22, idle 181040/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MQTT:Publishing val 192.168.0.38 to Rauchmelder/ip retain=0
    Info:MAIN:Time 23, idle 186952/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MQTT:Channel has changed! Publishing 1 to channel 1
    Info:MQTT:Publishing val 1 to Rauchmelder/1/get retain=0
    Info:MAIN:Time 24, idle 186739/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:TuyaMCU:Received: 55 AA 00 06 00 00 05
    Info:TuyaMCU:ProcessIncoming[v=0]: cmd 6 (SetDP) len 7
    Info:TuyaMCU:ProcessIncoming: received TUYA_V0_CMD_OBTAINLOCALTIME, so sending back time
    Info:TuyaMCU:MCU time to set: 0
    Info:TuyaMCU:ptime ->gmtime => tm_hour: 0
    Info:TuyaMCU:ptime ->gmtime => tm_min: 0
    Info:TuyaMCU:Received: 55 AA 00 05 00 05 65 01 00 01 01 71
    Info:TuyaMCU:ProcessIncoming[v=0]: cmd 5 (WiFiSelect) len 12
    Info:TuyaMCU:V0_ParseRealTimeWithRecordStorage: processing id 101, dataType 1-bool and 1 data bytes
    Info:TuyaMCU:V0_ParseRealTimeWithRecordStorage: byte 1
    Info:GEN:No change in channel 11 (still set to 1) - ignoring
    Info:MQTT:Channel has changed! Publishing 0 to channel 7
    Info:MQTT:Publishing val 0 to Rauchmelder/7/get retain=0
    Info:MAIN:Time 25, idle 179214/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MQTT:Channel has changed! Publishing 1 to channel 11
    Info:MQTT:Publishing val 1 to Rauchmelder/11/get retain=0
    Info:MAIN:Time 26, idle 185723/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MQTT:Channel has changed! Publishing 0 to channel 15
    Info:MQTT:Publishing val 0 to Rauchmelder/15/get retain=0
    Info:MAIN:Time 27, idle 184179/s, free 69888, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:TuyaMCU:Received: 55 AA 00 05 00 08 0F 02 00 04 00 00 00 32 53
    Info:TuyaMCU:V0_ParseRealTimeWithRecordStorage: processing id 15, dataType 2-val and 4 data bytes
    Info:TuyaMCU:V0_ParseRealTimeWithRecordStorage: int32 50
    Info:GEN:CHANNEL_Set channel 15 has changed to 50 (flags 0)
    Info:MQTT:Channel has changed! Publishing 50 to channel 15
    Info:MQTT:Publishing val 50 to Rauchmelder/15/get retain=0
    Info:MQTT:Channel has changed! Publishing 0 to channel 16
    Info:MQTT:Publishing val 0 to Rauchmelder/16/get retain=0
    Info:MAIN:Time 28, idle 181369/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 29, idle 185250/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 30, idle 182170/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:GEN:sta:rssi=-56,ssid=Hausnummer28,bssid=2c:3a:fd:ce:a8:2e,channel=13,cipher_type:CCMP
    Info:TuyaMCU:Received: 55 AA 00 05 00 05 01 04 00 01 00 0F
    Info:TuyaMCU:V0_ParseRealTimeWithRecordStorage: processing id 1, dataType 4-enum and 1 data bytes
    Info:TuyaMCU:V0_ParseRealTimeWithRecordStorage: byte 0
    Info:GEN:CHANNEL_Set channel 1 has changed to 0 (flags 0)
    Info:MQTT:Publishing val 0 to Rauchmelder/1/get retain=0
    Info:MAIN:Time 31, idle 177728/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 32, idle 189273/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 33, idle 185265/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:TuyaMCU:Received: 55 AA 00 05 00 05 6B 04 00 01 02 7B
    Info:TuyaMCU:V0_ParseRealTimeWithRecordStorage: processing id 107, dataType 4-enum and 1 data bytes
    Info:TuyaMCU:V0_ParseRealTimeWithRecordStorage: byte 2
    Info:GEN:CHANNEL_Set channel 7 has changed to 2 (flags 0)
    Info:MQTT:Channel has changed! Publishing 2 to channel 7
    Info:MQTT:Publishing val 2 to Rauchmelder/7/get retain=0
    Info:MAIN:Time 34, idle 184354/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 35, idle 188902/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 36, idle 190248/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:GEN:No change in channel 23 (still set to 205) - ignoring
    Info:MAIN:Time 37, idle 189278/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 38, idle 187167/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 39, idle 190722/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:GEN:No change in channel 24 (still set to 60) - ignoring
    Info:MAIN:Time 40, idle 186068/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:GEN:sta:rssi=-54,ssid=Hausnummer28,bssid=2c:3a:fd:ce:a8:2e,channel=13,cipher_type:CCMP
    Info:MAIN:Time 41, idle 185263/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 42, idle 188174/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 43, idle 187001/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 44, idle 188130/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 45, idle 190365/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 46, idle 190384/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:TuyaMCU:Received: 55 AA 00 05 00 05 65 01 00 01 00 70
    Info:GEN:CHANNEL_Set channel 11 has changed to 0 (flags 0)
    Info:MQTT:Channel has changed! Publishing 0 to channel 11
    Info:MQTT:Publishing val 0 to Rauchmelder/11/get retain=0
    Info:MAIN:Time 47, idle 185262/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 48, idle 185051/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 49, idle 189726/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 50, idle 188182/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 51, idle 187057/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 52, idle 190867/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 53, idle 188108/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 54, idle 186843/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 55, idle 191909/s, free 69464, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 56, idle 192272/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 57, idle 188997/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 58, idle 187844/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 59, idle 189979/s, free 69768, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 60, idle 186010/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 61, idle 188800/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 62, idle 188134/s, free 69888, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 63, idle 197152/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 64, idle 191639/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 65, idle 189714/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 66, idle 187682/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 67, idle 195104/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 68, idle 186733/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 69, idle 190446/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 70, idle 191096/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 71, idle 184116/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 1, socks 3/38
    Info:MAIN:Time 72, idle 188085/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 2, socks 3/38
    Info:MAIN:Time 73, idle 190634/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing 3, socks 2/38
    Info:MAIN:Time 74, idle 189099/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 4, socks 3/38
    Info:MQTT:MQTT client in mqtt_incoming_publish_cb topic Rauchmelder/16/set
    Info:MQTT:MQTT client in mqtt_incoming_data_cb data is 0 for ch 16
    Info:GEN:No change in channel 16 (still set to 0) - ignoring
    Info:MAIN:Time 75, idle 187507/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 5, socks 3/38
    Info:MAIN:Time 76, idle 191876/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 6, socks 3/38
    Info:MAIN:Time 77, idle 187990/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 7, socks 3/38
    Info:MAIN:Time 78, idle 188684/s, free 58192, MQTT 1(1), bWifi 1, secondsWithNoPing 8, socks 3/38
    Info:MAIN:Time 79, idle 190451/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 9, socks 3/38
    Info:MAIN:Time 80, idle 188422/s, free 69888, MQTT 1(1), bWifi 1, secondsWithNoPing 10, socks 2/38
    Info:MAIN:Time 81, idle 184553/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 11, socks 3/38
    Info:MAIN:Time 82, idle 189139/s, free 69888, MQTT 1(1), bWifi 1, secondsWithNoPing 12, socks 2/38
    Info:MAIN:Time 83, idle 191126/s, free 69888, MQTT 1(1), bWifi 1, secondsWithNoPing 13, socks 2/38
    Info:MAIN:Time 84, idle 188896/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 14, socks 3/38
    Info:MAIN:Time 85, idle 189821/s, free 69888, MQTT 1(1), bWifi 1, secondsWithNoPing 15, socks 2/38
    Info:MAIN:Time 86, idle 190174/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 16, socks 3/38
    Info:MAIN:Time 87, idle 188875/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 17, socks 3/38
    Info:MAIN:Time 88, idle 191159/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 18, socks 3/38
    Info:MAIN:Time 89, idle 186421/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 19, socks 3/38
    Info:MAIN:Time 90, idle 187040/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 20, socks 3/38
    Info:MAIN:Time 91, idle 187487/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 21, socks 3/38
    Info:MAIN:Time 92, idle 188962/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 22, socks 3/38
    Info:MAIN:Time 93, idle 187175/s, free 69888, MQTT 1(1), bWifi 1, secondsWithNoPing 23, socks 2/38
    Info:MAIN:Time 94, idle 188981/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 24, socks 3/38
    Info:MAIN:Time 95, idle 189284/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing 25, socks 2/38
    Info:MAIN:Time 96, idle 191024/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 26, socks 3/38
    Info:MAIN:Time 97, idle 189743/s, free 69888, MQTT 1(1), bWifi 1, secondsWithNoPing 27, socks 2/38
    Info:MAIN:Time 98, idle 190497/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 28, socks 3/38
    Info:MQTT:MQTT client in mqtt_incoming_data_cb data is 1 for ch 16
    Info:GEN:CHANNEL_Set channel 16 has changed to 1 (flags 0)
    Info:MQTT:Channel has changed! Publishing 1 to channel 16
    Info:MQTT:Publishing val 1 to Rauchmelder/16/get retain=0
    Info:MAIN:Time 99, idle 181908/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 29, socks 3/38
    Info:MAIN:Time 100, idle 191107/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 30, socks 3/38
    Info:MAIN:Time 101, idle 186281/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 31, socks 3/38
    Info:MAIN:Time 102, idle 190879/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 32, socks 3/38
    Info:MAIN:Time 103, idle 188781/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing 33, socks 2/38
    Info:MAIN:Time 104, idle 191599/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 34, socks 3/38
    Info:MAIN:Time 105, idle 189468/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 35, socks 3/38
    Info:MAIN:Time 106, idle 190473/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 36, socks 3/38
    Info:MAIN:Time 107, idle 189930/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 37, socks 3/38
    Info:MAIN:Time 108, idle 196904/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 38, socks 3/38
    Info:MAIN:Time 109, idle 187344/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 39, socks 3/38
    Info:MAIN:Time 110, idle 191605/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 40, socks 3/38
    Info:GEN:sta:rssi=-58,ssid=Hausnummer28,bssid=2c:3a:fd:ce:a8:2e,channel=13,cipher_type:CCMP
    Info:MAIN:Time 111, idle 183104/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing 41, socks 2/38
    Info:MAIN:Time 112, idle 197159/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 42, socks 3/38
    Info:MAIN:Time 113, idle 189708/s, free 61584, MQTT 1(1), bWifi 1, secondsWithNoPing 43, socks 3/38
    Info:MAIN:Time 114, idle 189812/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 44, socks 3/38
    Info:MAIN:Time 115, idle 191770/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing 45, socks 2/38
    Info:MAIN:Time 116, idle 193782/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 46, socks 3/38
    Info:MAIN:Time 117, idle 190892/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing 47, socks 2/38
    Info:MAIN:Time 118, idle 192609/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 48, socks 3/38
    Info:MAIN:Time 119, idle 190148/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing 49, socks 2/38
    Info:MAIN:Time 120, idle 190008/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 50, socks 3/38
    Info:GEN:sta:rssi=-57,ssid=Hausnummer28,bssid=2c:3a:fd:ce:a8:2e,channel=13,cipher_type:CCMP
    Info:MAIN:Time 121, idle 184881/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 51, socks 3/38
    Info:MAIN:Time 122, idle 194146/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 52, socks 3/38
    Info:MAIN:Time 123, idle 189849/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 53, socks 3/38
    Info:MAIN:Time 124, idle 195756/s, free 69960, MQTT 1(1), bWifi 1, secondsWithNoPing 54, socks 3/38
    Info:MAIN:Time 125, idle 188810/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 55, socks 3/38
    Info:MAIN:Time 126, idle 190023/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 56, socks 3/38
    Info:MAIN:Time 127, idle 186480/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 57, socks 3/38
    Info:MAIN:Time 128, idle 187811/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 58, socks 3/38
    Info:MAIN:Time 129, idle 187198/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 59, socks 3/38
    Info:MAIN:Time 130, idle 190501/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 60, socks 3/38
    Info:MAIN:Time 131, idle 190759/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 61, socks 3/38
    Info:MAIN:Time 132, idle 189460/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 62, socks 3/38
    Info:MAIN:Time 133, idle 184551/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 63, socks 3/38
    Info:MAIN:Time 134, idle 190062/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 64, socks 3/38
    Info:MAIN:Time 135, idle 195435/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 65, socks 3/38
    Info:MAIN:Time 136, idle 191182/s, free 61368, MQTT 1(1), bWifi 1, secondsWithNoPing 66, socks 4/38
    Info:MAIN:Time 137, idle 188770/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 67, socks 3/38
    Info:MAIN:Time 138, idle 189123/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 68, socks 3/38
    Info:MAIN:Time 139, idle 188330/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 69, socks 3/38
    Info:MAIN:Time 140, idle 190280/s, free 61368, MQTT 1(1), bWifi 1, secondsWithNoPing 70, socks 4/38
    Info:MAIN:Time 141, idle 189127/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 71, socks 3/38
    Info:MAIN:Time 142, idle 191632/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing 72, socks 2/38
    Info:MAIN:Time 143, idle 199323/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 73, socks 3/38
    Info:MAIN:Time 144, idle 188888/s, free 61496, MQTT 1(1), bWifi 1, secondsWithNoPing 74, socks 3/38
    Info:MAIN:Time 145, idle 189230/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 75, socks 3/38
    Info:MAIN:Time 146, idle 190348/s, free 61368, MQTT 1(1), bWifi 1, secondsWithNoPing 76, socks 4/38
    Info:MAIN:Time 147, idle 188139/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 77, socks 3/38
    Info:MAIN:Time 148, idle 190964/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 78, socks 3/38
    Info:MAIN:Time 149, idle 186819/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 79, socks 3/38
    Info:MAIN:Time 150, idle 187326/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 80, socks 3/38
    Info:MAIN:Time 151, idle 185153/s, free 69888, MQTT 1(1), bWifi 1, secondsWithNoPing 81, socks 2/38
    Info:MAIN:Time 152, idle 194210/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 82, socks 3/38
    Info:MAIN:Time 153, idle 188748/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 83, socks 3/38
    Info:MAIN:Time 154, idle 190171/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 84, socks 3/38
    Info:MAIN:Time 155, idle 186792/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 85, socks 3/38
    Info:MAIN:Time 156, idle 190771/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 86, socks 3/38
    Info:MAIN:Time 157, idle 188071/s, free 69984, MQTT 1(1), bWifi 1, secondsWithNoPing 87, socks 2/38
    Info:MAIN:Time 158, idle 189838/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 88, socks 3/38
    Info:MAIN:Time 159, idle 189113/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 89, socks 3/38
    Info:MAIN:Time 160, idle 202384/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 90, socks 3/38
    Info:MAIN:Time 161, idle 183340/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 91, socks 3/38
    Info:MAIN:Time 162, idle 188748/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 92, socks 3/38
    Info:MAIN:Time 163, idle 187232/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 93, socks 3/38
    Info:MAIN:Time 164, idle 189492/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 94, socks 3/38
    Info:MAIN:Time 165, idle 188800/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 95, socks 3/38
    Info:GEN:No change in channel 11 (still set to 0) - ignoring
    Info:MAIN:Time 166, idle 189366/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 96, socks 3/38
    Info:GEN:No change in channel 15 (still set to 50) - ignoring
    Info:MAIN:Time 167, idle 184883/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 97, socks 3/38
    Info:MAIN:Time 168, idle 190741/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 98, socks 3/38
    Info:MAIN:Time 169, idle 188675/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 99, socks 3/38
    Info:MAIN:Time 170, idle 186437/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 100, socks 3/38
    Info:MAIN:Time 171, idle 182233/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 101, socks 3/38
    Info:MAIN:Time 172, idle 191968/s, free 61368, MQTT 1(1), bWifi 1, secondsWithNoPing 102, socks 4/38
    Info:MAIN:Time 173, idle 186699/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 103, socks 3/38
    Info:MAIN:Time 174, idle 189489/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 104, socks 3/38
    Info:MAIN:Time 175, idle 188614/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 105, socks 3/38
    Info:MAIN:Time 176, idle 190308/s, free 69672, MQTT 1(1), bWifi 1, secondsWithNoPing 106, socks 3/38
    Info:MAIN:Time 177, idle 188144/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 107, socks 3/38
    Info:MAIN:Time 178, idle 190535/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 108, socks 3/38
    Info:MAIN:Time 179, idle 189369/s, free 70192, MQTT 1(1), bWifi 1, secondsWithNoPing 109, socks 2/38
    Info:MAIN:Time 180, idle 186757/s, free 61584, MQTT 1(1), bWifi 1, secondsWithNoPing 110, socks 3/38
    Info:MAIN:Time 181, idle 183567/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 111, socks 3/38
    Info:MAIN:Time 182, idle 187370/s, free 61368, MQTT 1(1), bWifi 1, secondsWithNoPing 112, socks 4/38
    Info:MAIN:Time 183, idle 188411/s, free 61368, MQTT 1(1), bWifi 1, secondsWithNoPing 113, socks 4/38
    Info:MAIN:Time 184, idle 190400/s, free 61584, MQTT 1(1), bWifi 1, secondsWithNoPing 114, socks 3/38
    Info:MAIN:Time 185, idle 188479/s, free 61584, MQTT 1(1), bWifi 1, secondsWithNoPing 115, socks 3/38
    Info:MAIN:Time 186, idle 189200/s, free 61584, MQTT 1(1), bWifi 1, secondsWithNoPing 116, socks 3/38
    Info:MAIN:Time 187, idle 191605/s, free 61368, MQTT 1(1), bWifi 1, secondsWithNoPing 117, socks 4/38
    Info:MAIN:Time 188, idle 187538/s, free 61584, MQTT 1(1), bWifi 1, secondsWithNoPing 118, socks 3/38
    Info:MAIN:Time 189, idle 189067/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 119, socks 3/38
    Info:MAIN:Time 190, idle 191924/s, free 61584, MQTT 1(1), bWifi 1, secondsWithNoPing 120, socks 3/38
    Info:MAIN:Time 191, idle 184433/s, free 61584, MQTT 1(1), bWifi 1, secondsWithNoPing 121, socks 3/38
    Info:MAIN:Time 192, idle 184669/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 122, socks 3/38
    Info:MAIN:Time 193, idle 188640/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 123, socks 3/38
    Info:MAIN:Time 194, idle 190926/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 124, socks 3/38
    Info:GEN:CHANNEL_Set channel 11 has changed to 1 (flags 0)
    Info:MAIN:Time 195, idle 187012/s, free 69976, MQTT 1(1), bWifi 1, secondsWithNoPing 125, socks 3/38
    Info:MAIN:Time 196, idle 201964/s, free 70168, MQTT 1(1), bWifi 1, secondsWithNoPing 126, socks 3/38
    Info:MAIN:Time 197, idle 187633/s, free 62080, MQTT 1(1), bWifi 1, secondsWithNoPing 127, socks 3/38
    Info:MAIN:Time 198, idle 194287/s, free 70472, MQTT 1(1), bWifi 1, secondsWithNoPing 128, socks 3/38
    Info:MAIN:Time 199, idle 189195/s, free 62080, MQTT 1(1), bWifi 1, secondsWithNoPing 129, socks 3/38
    Info:MAIN:Time 200, idle 187773/s, free 62080, MQTT 1(1), bWifi 1, secondsWithNoPing 130, socks 3/38
    Info:MAIN:Time 201, idle 181267/s, free 62080, MQTT 1(1), bWifi 1, secondsWithNoPing 131, socks 3/38
    Info:MAIN:Time 202, idle 191744/s, free 70472, MQTT 1(1), bWifi 1, secondsWithNoPing 132, socks 3/38
    Info:MAIN:Time 203, idle 188157/s, free 62080, MQTT 1(1), bWifi 1, secondsWithNoPing 133, socks 3/38
    Info:MAIN:Time 204, idle 191285/s, free 70472, MQTT 1(1), bWifi 1, secondsWithNoPing 134, socks 3/38
    Info:MAIN:Time 205, idle 187471/s, free 70472, MQTT 1(1), bWifi 1, secondsWithNoPing 135, socks 3/38
    Info:MAIN:Time 206, idle 191834/s, free 70472, MQTT 1(1), bWifi 1, secondsWithNoPing 136, socks 3/38
    Info:MAIN:Time 207, idle 190149/s, free 70472, MQTT 1(1), bWifi 1, secondsWithNoPing 137, socks 3/38
    Info:MAIN:Time 208, idle 191561/s, free 70472, MQTT 1(1), bWifi 1, secondsWithNoPing 138, socks 3/38
    Info:MAIN:Time 209, idle 189885/s, free 62080, MQTT 1(1), bWifi 1, secondsWithNoPing 139, socks 3/38
    Info:MAIN:Time 210, idle 192005/s, free 62080, MQTT 1(1), bWifi 1, secondsWithNoPing 140, socks 3/38
    Info:TuyaMCU:Received: 55 AA 00 05 00 05 01 04 00 01 01 10
    Info:GEN:CHANNEL_Set channel 1 has changed to 1 (flags 0)
    Info:MAIN:Time 211, idle 177397/s, free 61864, MQTT 1(1), bWifi 1, secondsWithNoPing 141, socks 4/38
    Info:MAIN:Time 212, idle 188381/s, free 62080, MQTT 1(1), bWifi 1, secondsWithNoPing 142, socks 3/38
    Info:MAIN:Time 213, idle 186711/s, free 70472, MQTT 1(1), bWifi 1, secondsWithNoPing 143, socks 3/38
    Info:MAIN:Time 214, idle 190056/s, free 62080, MQTT 1(1), bWifi 1, secondsWithNoPing 144, socks 3/38
    Info:MAIN:Time 215, idle 188823/s, free 62080, MQTT 1(1), bWifi 1, secondsWithNoPing 145, socks 3/38
    Another Log:
    Info:CFG:####### Boot Count 30 #######
    Warn:CFG:CFG_InitAndLoad: Correct config has been loaded with 6 changes count.
    Error:CMD:no file early.bat err -2
    Info:MAIN:Main_Init_Delay
    Info:MAIN:Using SSID [Hausnummer28]
    Info:MAIN:Using Pass [passcode]
    Error:HTTP:Created HTTP SV thread with (stack=2048)
    Info:MQTT:MQTT_RegisterCallback called for bT Rauchmelder/ subT Rauchmelder/+/set
    Info:MQTT:MQTT_RegisterCallback called for bT cmnd/Rauchmelder/ subT cmnd/Rauchmelder/+
    Info:MQTT:MQTT_RegisterCallback called for bT Rauchmelder/ subT Rauchmelder/+/get
    Info:CMD:CMD_StartScript: started @startup at the beginning
    Info:CMD:CMD_StartScript: started autoexec.bat at the beginning
    Info:MAIN:Started TuyaMCU.
    Info:MAIN:Started tmSensor.
    Info:GEN:Channel 1 type not set because ReadOnlyAlarmNormal is not a known type
    Info:GEN:Channel 15 type changed to ReadOnly
    Info:TuyaMCU:value is not a valid var type
    Info:GEN:Channel 16 type not set because bool is not a known type
    Info:GEN:Channel 23 type not set because ReadOnlyTemperature_div10 is not a known type
    Info:GEN:Channel 24 type changed to Humidity
    Info:GEN:Channel 11 type not set because ReadOnlybool is not a known type
    Info:GEN:Channel 7 type not set because ReadOnlyNiedrigHoch is not a known type
    Info:MAIN:Time 1, idle 208366/s, free 75960, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:TuyaMCU:Received: 55 AA 00 01 00 24 7B 22 70 22 3A 22 66 7A 62 35 75 70 32 69 65 68 6A 63 72 6E 71 79 22 2C 22 76 22 3A 22 31 2E 30 2E 37 22 7D 01
    Info:TuyaMCU:ProcessIncoming[v=0]: cmd 1 (QueryProductInformation) len 43
    Info:TuyaMCU:ParseQueryProductInformation: received {"p":"fzb5up2iehjcrnqy","v":"1.0.7"}
    Info:MAIN:Time 2, idle 187884/s, free 75960, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 3, idle 188482/s, free 75960, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 4, idle 190851/s, free 75960, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 5, idle 189389/s, free 75960, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:MAIN:WiFi SSID: waiting for SSID switch 1/3 (using SSID1)
    Info:MAIN:Registered for wifi changes
    Info:MAIN:Connecting to SSID [Hausnummer28]
    Info:MAIN:Time 6, idle 179967/s, free 71208, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 7, idle 196658/s, free 71208, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 8, idle 85704/s, free 69448, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 9, idle 0/s, free 69448, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 10, idle 0/s, free 69448, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:GEN:dhcp=0 ip=0.0.0.0 gate=0.0.0.0 mask=0.0.0.0 mac=38:a5:c9:db:de:73
    Info:GEN:sta: 0, softap: 0, b/g/n
    Info:MAIN:Main_OnWiFiStatusChange - WIFI_STA_CONNECTING - 1
    Info:MAIN:Time 11, idle 93652/s, free 70168, MQTT 0(0), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:TuyaMCU:Received: 55 AA 00 02 00 00 01
    Info:TuyaMCU:ProcessIncoming[v=0]: cmd 2 (MCUconf) len 7
    Info:TuyaMCU:ProcessIncoming: TUYA_CMD_MCU_CONF, TODO!
    Info:MAIN:Time 12, idle 188722/s, free 70208, MQTT 0(0), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MQTT:mqtt_userName mqtt
    mqtt_pass ********
    mqtt_clientID Rauchmelder
    mqtt_host 192.168.0.167:1883
    Info:MAIN:Time 13, idle 193080/s, free 69912, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MQTT:mqtt_subscribed to Rauchmelder/+/set
    Info:MQTT:mqtt_subscribed to cmnd/Rauchmelder/+
    Info:MQTT:mqtt_subscribed to Rauchmelder/+/get
    Info:MQTT:Publishing val Rauchmelder to Rauchmelder/host retain=0
    Info:MAIN:Time 14, idle 181728/s, free 70104, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:TuyaMCU:Received: 55 AA 00 10 00 01 00 10
    Info:TuyaMCU:ProcessIncoming[v=0]: cmd 16 (Unknown) len 8
    Info:TuyaMCU:Received: 55 AA 00 05 00 08 17 02 00 04 00 00 00 FC 25
    Info:TuyaMCU:V0_ParseRealTimeWithRecordStorage: int32 252
    Info:GEN:CHANNEL_Set channel 23 has changed to 252 (flags 0)
    Info:MQTT:Channel has changed! Publishing 252 to channel 23
    Info:MQTT:Publishing val 252 to Rauchmelder/23/get retain=0
    Info:TuyaMCU:Received: 55 AA 00 05 00 05 10 01 00 01 00 1B
    Info:TuyaMCU:V0_ParseRealTimeWithRecordStorage: processing id 16, dataType 1-bool and 1 data bytes
    Info:MQTT:Publishing val OpenBK7231N 1.18.111 Jun 15 2025 11:20:36 to Rauchmelder/build retain=0
    Info:MAIN:Time 15, idle 175934/s, free 70104, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MQTT:Publishing val 38:a5:c9:db:de:73 to Rauchmelder/mac retain=0
    Info:MAIN:Time 16, idle 191778/s, free 70104, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:TuyaMCU:Received: 55 AA 00 05 00 08 18 02 00 04 00 00 00 2D 57
    Info:TuyaMCU:V0_ParseRealTimeWithRecordStorage: int32 45
    Info:GEN:CHANNEL_Set channel 24 has changed to 45 (flags 0)
    Info:MQTT:Channel has changed! Publishing 45 to channel 24
    Info:MQTT:Publishing val 45 to Rauchmelder/24/get retain=0
    Info:MQTT:Publishing val 30.80 to Rauchmelder/temp retain=0
    Info:MAIN:Time 17, idle 183458/s, free 70104, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MQTT:Publishing val Hausnummer28 to Rauchmelder/ssid retain=0
    Info:MAIN:Time 18, idle 188339/s, free 70104, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MQTT:Publishing val 2 to Rauchmelder/sockets retain=0
    Info:MAIN:Time 19, idle 190974/s, free 69896, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MQTT:Publishing val -57 to Rauchmelder/rssi retain=0
    Info:MAIN:Time 20, idle 176901/s, free 69872, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 21, idle 186276/s, free 70104, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MQTT:Publishing val 70104 to Rauchmelder/freeheap retain=0
    Info:MAIN:Time 22, idle 191913/s, free 70104, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:GEN:No change in channel 1 (still set to 0) - ignoring
    Info:MAIN:Time 23, idle 185979/s, free 70104, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 24, idle 195970/s, free 70104, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 25, idle 188177/s, free 69872, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:GEN:No change in channel 23 (still set to 252) - ignoring
    Info:MAIN:Time 26, idle 182260/s, free 70104, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 27, idle 198766/s, free 70104, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 28, idle 191292/s, free 70104, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:GEN:No change in channel 24 (still set to 45) - ignoring
    Info:MAIN:Time 29, idle 183795/s, free 69872, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 30, idle 193058/s, free 70104, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 31, idle 183932/s, free 70104, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 32, idle 186666/s, free 69888, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 33, idle 188924/s, free 70104, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 34, idle 190484/s, free 70104, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 35, idle 190637/s, free 61496, MQTT 1(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Skasowano z tematu: Experience? / ONENUO 228WTH Smoke Detector with Temp/Humidity: OBK Flashing, Chip Info, Battery Life
    przez io2345 dnia 15 Jun 2025 16:16
