[postid:6bd2718208][/postid:6bd2718208]
DeepSleep<wake up time in seconds>
That should work. You can try to lower the time and test, maybe 60 seconds. Obviously module will not send anything in that period. Also make sure you have active flags for WiFi quick connect to make the on time as short as possible as you are running on BK7231N chip (inside CBU module).
Wydzielono z tematu: [BK7231N] [CB3S] [AHT20] TH01 Generic Temperature and Humidity Sensor Teardown
przez p.kaczmarek2 dnia 22 Lip 2025 16:22
