Teflon-Coated Ni-Chrome Wire vs Surface Heater for Toxic Chemical Chamber Heating
330 7
  • Suggesting low-cost heater options for corrosive chambers
    #1 21659503
    Ralph Pruitt
  • Heating resistor resources and chamber examples
    #2 21659504
    Cody Miller
  • #3 21659505
    Ralph Pruitt
  • #4 21659506
    Cody Miller
  • #5 21659507
    Ralph Pruitt
  • #6 21659508
    Bob Casiano
  • #7 21659509
    Bob Casiano
  • #8 21659510
    Per Zackrisson
The discussion addresses heating solutions for a chemical measurement device containing highly toxic and corrosive chemicals, requiring temperature maintenance above 10°C. Two main heating approaches are considered: Teflon-coated Ni-chrome wire with a thermocouple and microcontroller-based power control, and a surface heater with an I2C temperature sensor. Additional suggestions include using heating resistors, PCB-based serpentine trace heaters, and custom heater boards made from high-temperature laminates such as FR-408, capable of operating up to 180°C. Ohmite TA series power resistors were also mentioned as effective heating elements in a Teflon PCB mini heat chamber design. The device is battery powered and small (~1 cubic inch), with a heating requirement to raise temperature from as low as -10°C to 10°C. External heating solutions like hotplates, Thermostreams, and heating chambers were referenced, along with frost guard systems as potential alternatives. Thermal insulation using rock wool and metal enclosures was noted for maintaining temperature stability in corrosive environments.
