Best embedded development boards for HMI, analog input, touchscreen, AC motor control
195 13
What embedded development board or platform should I use for a medical-device HMI with analog inputs, a touchscreen, and AC motor control, and how much programming effort will it take?
An embedded Linux or Android solution is the most practical path, with a Freescale iMX53-based Android board or an Olimexino-STM32/Maple-style ARM board suggested as starting points. [#21660126][#21660130] If you want an easier HMI stack, Android was described as handling much of the OS work for you, with the UI built in Java/XML and the controller linked by Bluetooth or USB. [#21660129][#21660130] For your analog signals, these boards and Arduino have 0–3.3 V analog inputs with 0–1023 counts, and a 4–20 mA signal can be converted to that range; serial inputs were also said to be straightforward. [#21660134] Be careful with real-time motor control: FEZ Cobra and Netduino Plus were praised for ease of use, but a roughly 20 ms delay from the .NET Microframework may be a drawback if tight timing is required. [#21660127] On effort, one reply said a good Android app likely would not take 200 hours, while another estimated 600+ hours for the full project, so this looks more like months of work than weeks. [#21660129][#21660135]
  • #1 21660123
    Peter Halick
  • #2 21660124
    Joe Wolin
  • Seeking embedded programmer/designer for HMI project
    #3 21660125
    Peter Halick
  • #4 21660126
    Ralph Pruitt
  • FEZ Cobra and Netduino Plus recommendations
    #5 21660127
    Robin Moss
  • #6 21660128
    Peter Halick
  • Android simplifies HMI development with XML and Java
    #7 21660129
    Ralph Pruitt
  • #8 21660130
    Per Zackrisson
  • #9 21660131
    Peter Halick
  • #10 21660132
    Peter Halick
  • #11 21660133
    Peter Halick
  • #12 21660134
    Robin Moss
  • Suggesting WiFi, PIC RF, and PC-based HMI options
    #13 21660135
    Mark Harrington
  • #14 21660136
    Peter Halick
The discussion focuses on transitioning from off-the-shelf PLCs and programmable touchscreens to embedded development boards for a medical device HMI with analog inputs, touchscreen capability, and AC motor control. Recommended platforms include mainstream microcontrollers such as AVR and PIC for their extensive community support. Alternatives suggested are embedded Linux or Android-based solutions, notably the Freescale iMX53 with Android OS, which simplifies UI development via Java and XML. For easier microcontroller entry, boards like FEZ Cobra and Netduino Plus, both supporting analog inputs and .NET Microframework, were proposed, though with some latency considerations. The OLIMEXINO-STM32 MAPLE board, Arduino-compatible with an ARM processor, was also recommended for users familiar with Arduino. Analog input solutions for load cells and serial inclinometers were discussed, with suggestions to convert 4-20mA signals to 0-3.3V for compatibility. Development time estimates vary, with programming potentially requiring hundreds of hours depending on the chosen platform and developer expertise. Additional ideas include leveraging mobile phone platforms (e.g., BlackBerry) with touchscreen and Java-based development, and using wireless networking (WiFi, XBee) to interface embedded devices. Overall, the choice depends on real-time processing needs, programming skills, and budget constraints.
TL;DR: Expect 200–600+ hours for an HMI with analog I/O, touchscreen, and AC motor control; “it’s quite [a] project.” [Elektroda, Mark Harrington, post #21660135] Why it matters: This FAQ helps PLC-to-embedded movers pick boards, plan effort, and avoid real-time and analog pitfalls for medical HMI builds.
What’s a practical starter board for HMI with a touchscreen?
FEZ Cobra and Netduino Plus are entry-friendly and community-backed. They support touch UIs and peripherals. Note that .NET Micro Framework adds latency, so evaluate response time. FEZ’s RLP lets you offload time‑critical routines. Start with dev kits, then migrate to custom PCBs. [Elektroda, Robin Moss, post #21660127]
Can these boards read my analog sensors directly?
Yes, their ADCs accept 0–3.3 V with 10‑bit resolution (0–1023). For 4–20 mA loops, use a shunt and scale to 0–3.3 V. Serial sensors like RS‑485 inclinometers also connect with proper transceivers. “Serial data is no problem either.” Validate noise and grounding early. [Elektroda, Robin Moss, post #21660134]
How many hours should I budget to move from PLCs to embedded?
Plan for 200–600+ hours depending on features, safety, documentation, and validation. Networking, motor control, and HMI polish expand scope. One contributor estimated “600 Plus” for a robust solution. Timebox learning spikes and keep noncritical features for phase two. [Elektroda, Mark Harrington, post #21660135]
Should I choose Android or Embedded Linux for the HMI?
Android offers fast UI development in Java with declarative XML layouts. Many tasks are off‑the‑shelf, reducing OS plumbing. Boards like Freescale i.MX53 run Android for rich touch interfaces. Validate real‑time needs and use external controllers for tight loops. [Elektroda, Ralph Pruitt, post #21660126]
Is Android UI coding heavy for this use case?
UI scaffolding is quick since Android handles views and events, and XML defines layouts. “The app and underlying code is Java.” The main learning curve is Android’s component model. Prototype screens first, then integrate hardware services. [Elektroda, Ralph Pruitt, post #21660129]
Do I need a real-time OS for motor control?
If your control loop needs sub‑millisecond timing, avoid pure .NET MF loops. Expect ~20 ms framework overhead. Offload timing‑critical PWM or FOC to native code or a dedicated MCU while the HMI runs managed code. [Elektroda, Robin Moss, post #21660127]
What about the load cells—can I skip the expensive conditioner?
Your current design uses a signal conditioner and a Phoenix analog module. Maintain equivalent conditioning or replace with a suitable front‑end before the MCU’s ADC. Budget time to validate accuracy and drift across temperature. [Elektroda, Peter Halick, post #21660132]
How do I connect an RS‑485 inclinometer to an HMI board?
Use an RS‑485 transceiver and match baud, polarity, and termination. Cobra‑class boards can handle serial framing in software. Keep cable shielding and biasing correct to avoid intermittent data dropouts. [Elektroda, Robin Moss, post #21660134]
Which microcontroller families are safest bets for community help?
Pick mainstream lines like AVR or PIC to tap large communities and examples. This reduces bring‑up risk and accelerates debugging. Decide based on available libraries, tools, and your team’s skills. [Elektroda, Joe Wolin, post #21660124]
What skills or components inflate project time the most?
Networking stacks (Wi‑Fi/Bluetooth), secure comms, motor PWM control, and multi‑device integration add effort. Server links, RS‑232/Ethernet bridges, and radio modules like XBee expand scope. Expect research and validation cycles. [Elektroda, Mark Harrington, post #21660135]
What is the .NET Micro Framework, and when is it OK?
.NET MF lets you write embedded apps in C# on boards like FEZ and Netduino. It simplifies UI and logic but adds ~20 ms latency. Use it for HMI and supervisory tasks; push tight control to native layers. [Elektroda, Robin Moss, post #21660127]
I’m an Arduino‑savvy mechanical engineer—can I self‑deliver?
Yes, with scope control. Boards discussed expose analog inputs and serial easily, easing transition from PLCs. Aim for a working HMI first, then add motor control. Timebox to 200 hours for MVP, expand afterward. [Elektroda, Robin Moss, post #21660134]
How do I quickly prototype an Android‑based HMI?
  1. Choose an i.MX53‑class board that runs Android.
  2. Build the UI in XML and app logic in Java.
  3. Bridge hardware via serial, USB, or Ethernet and test end‑to‑end. “Android takes care of much of the work of the OS.” [Elektroda, Ralph Pruitt, post #21660126]
What’s a reasonable definition of “incredibly easy to develop” here?
In this context, it means rapid HMI iteration, built‑in analog and serial I/O, and active forums for answers. FEZ and Netduino fit this, with the caveat of real‑time latency. RLP provides a path for time‑critical routines. [Elektroda, Robin Moss, post #21660127]
Any edge cases I should plan for before committing?
Plan for failure modes: serial framing errors, ADC saturation beyond 3.3 V, and motor stalls during latency spikes. Add hardware protection and watchdogs. Validate the 20 ms managed overhead against your control loop budget. [Elektroda, Robin Moss, post #21660127]
How can I find the right embedded talent if I don’t DIY?
Target developers experienced with AVR or PIC, as suggested, and review community contributions. Share a lean spec and ask for a fixed‑scope prototype quote. Prioritize candidates with HMI and motor‑control portfolios. [Elektroda, Joe Wolin, post #21660124]
