Best Software for PCB Designing: Comparing Altium Designer, Eagle, KiCad, and OrCAD
1605 17
Which PCB design software is best for my project and experience level?
There is no single best PCB design package; the right choice depends on your experience and project needs. If you are a beginner, Eagle is described as simple to use and almost free [#21660968][#21660972] For more advanced or complex designs, Altium Designer is recommended, especially for complex work like DDR RAM layout and copying symmetric layout sections [#21660971][#21660972] If the software’s features match what you need, that is the best choice for you [#21660972]
  • #1 21660964
    ANDANI PRASHANT
  • #2 21660965
    Waseem Bari
  • Clarifying what “best” PCB software means
    #3 21660966
    Steve Lawson
  • #4 21660967
    Rathina Vel
  • #5 21660968
    StrykerTECH
  • #7 21660970
    Liberty Zhang
  • #8 21660971
    Rajesh Kumar
  • #9 21660972
    elle Jimenez
  • Eagle as a free PCB design option
    #10 21660973
    Bech Bej
  • #12 21660975
    Andrew Dsouza
  • #13 21660976
    Steve Lawson
  • #14 21660977
    John Steave
  • Additional PCB design tools and low-cost board fab options
    #16 21660979
    Steve Lawson
  • Additional PCB design software and low-cost fabrication options
    #17 21660980
    Steve Lawson
  • #18 21660981
    Dishan Pangan
The discussion compares various PCB design software options including Altium Designer, Eagle, KiCad, OrCAD, Proteus, Protel, ExpressPCB, Fritzing, CircuitWizard, PCBWeb, and PCBFX. Altium Designer is highlighted for advanced features suitable for complex designs like DDR RAM layouts and strong online support. Eagle is noted for its popularity, ease of use, affordability, and availability of extensive tutorials, making it suitable for beginners. Proteus and Protel are mentioned as easier-to-use alternatives with schematic and PCB design capabilities. ExpressPCB is suggested as a simple option. Fritzing and CircuitWizard cater more to beginners and hobbyists but have limitations in component libraries and simulation capabilities. PCBWeb is introduced as a web-based PCB design tool. The choice depends on user experience, specific project requirements, budget, and desired features such as simulation, community support, and user interface preferences.
TL;DR: There isn’t one “best” PCB tool; one post lists 10 selection criteria and says “Define ‘best’.” Pick based on needs, budget, and support. [Elektroda, Steve Lawson, post #21660966]
Why it matters: This FAQ helps beginners and practitioners quickly match PCB software to project goals, cost limits, and learning time.
What’s the best PCB design software right now?
“Define ‘best’.” Prioritize by your goal: price, ease, vendor/community support, features in free tiers, student deals, UI preference, and required toolchain (schematic, layout, simulation). Make a short list using these criteria, then test-drive before committing. [Elektroda, Steve Lawson, post #21660966]
Is Eagle good for beginners?
Yes. Several users call CadSoft Eagle easy to learn, which helps you ship your first simple PCB quickly. Start with a small design, then explore libraries and autorouter settings only after you grasp manual routing. “Easy to learn” beats feature overload for first boards. [Elektroda, StrykerTECH, post #21660968]
When should I choose Altium Designer?
Choose Altium when tackling complex, high‑speed layouts. One user highlights DDR work, symmetry copy of layout sections, and helpful online resources. These strengths matter when length‑matching, tuning impedance, and keeping teams productive. If complexity rises, Altium’s workflow can save hours on iteration. [Elektroda, Rajesh Kumar, post #21660971]
Does Proteus include both schematic and PCB in one tool?
Yes. Proteus (ISIS + ARES) bundles schematic capture and PCB layout, which streamlines symbol‑to‑footprint consistency and shortens early‑stage prototyping. This integration reduces context switching for students and hobbyists building microcontroller projects with simple layouts. [Elektroda, Waseem Bari, post #21660965]
Is Protel still worth learning?
Some users find Protel easy to work with, and Protel 99 still gets mentions. If you inherit older designs or libraries, knowing Protel can help maintenance work. For new projects, evaluate current tools first, but keep Protel knowledge for legacy support. [Elektroda, Rathina Vel, post #21660967]
Where can I find a solid Eagle tutorial?
Use the well‑known SparkFun Eagle tutorial referenced in the thread. It walks you from schematic to board, helping you avoid common beginner mistakes like missing ERC/DRC checks. “There’s also a great tutorial at SparkFun.com.” [Elektroda, Steve Lawson, post #21660978]
Is ExpressPCB worth a look for simple boards?
It can be for straightforward projects or when you want a linked design‑to‑fab flow. A user recommends expresspcb.com in the thread. Check their software, then compare board pricing and design limits before committing your layout workflow. [Elektroda, Andrew Dsouza, post #21660975]
Are there web‑based PCB design tools?
Yes. PCBWeb is cited as a web application for PCB design. Browser‑based tools reduce install hassles and help quick evaluations in labs or shared computers. Export options and library breadth should guide your choice. [Elektroda, Dishan Pangan, post #21660981]
What free or hobby‑focused options are mentioned?
The thread notes Fritzing for beginners and hobbyists. It’s approachable for first boards and learning nets, footprints, and board outlines. Use it to validate simple circuits before moving to advanced constraint‑driven tools. [Elektroda, Steve Lawson, post #21660979]
Can I make PCBs at home without a fab house?
Yes, with DIY systems like PCBFX. However, expect no plated‑through holes and no solder mask, which limits double‑sided routing and durability. This is an intentional trade‑off for speed and learning at home. [Elektroda, Steve Lawson, post #21660979]
How do I quickly choose a PCB tool for my project?
Use this 3‑step shortcut:
  1. Rank your top three criteria (price, ease, support, features).
  2. Shortlist two tools that fit those criteria.
  3. Build a 30‑minute “hello board” in each, then pick the smoother run. [Elektroda, Steve Lawson, post #21660966]
What is CircuitWizard and should I rely on it?
CircuitWizard is highlighted as educational. It’s useful for learning, but the noted limitations include restricted component sets and simulation constraints. Use it for teaching basics, not for modern regulator or MOSFET‑heavy designs. [Elektroda, Steve Lawson, post #21660980]
What is Eagle ULP and why use it?
Eagle’s ULP (User Language Program) lets you write small scripts to automate tasks, generate data, or create plugins. A contributor planned tutorials covering ULP to extend Eagle’s capabilities. Automation saves time on repetitive library or checking steps. [Elektroda, Bech Bej, post #21660973]
I’m a student—should I hunt for special pricing?
Yes. One post explicitly lists “the best student deal” among key selection criteria. Educational pricing can unlock advanced tools within a student budget, making complex features accessible for capstone or research projects. [Elektroda, Steve Lawson, post #21660966]
Any edge cases I should watch for with beginner tools?
Beginner‑friendly tools can cap component choices or simulation accuracy. For example, an education‑focused suite was noted as lacking modern regulators and MOSFETs. Validate your BOM before committing time to a restricted platform. [Elektroda, Steve Lawson, post #21660980]
