How to Increase Sine Wave Generator Output Voltage for Amplifier Input?
390 6
  • Need higher sine amplitude to drive amplifier
    #1 21661696
    AHMAD ANDIKA
  • #2 21661697
    Mark Harrington
  • #3 21661698
    AHMAD ANDIKA
  • Use a unity-gain buffer op-amp stage
    #4 21661699
    Robert Bos
  • #5 21661700
    AHMAD ANDIKA
  • Clarifying gain, coupling, and amplifier topology
    #6 21661701
    Steve Lawson
  • Op amp needs negative feedback to avoid comparator action
    #7 21661702
    Jeff Evemy
The discussion addresses the issue of insufficient output voltage from a sine wave generator to properly drive an amplifier input, specifically to turn on a transistor stage. The original sine wave generator produces about 2 V peak-to-peak, which is inadequate to bias the transistor in the amplifier. Suggestions include using a dual operational amplifier (op-amp) such as the TL082, with one half configured as a buffer (unity gain, non-inverting) to provide impedance matching and the other half as a gain stage to amplify the voltage and current sufficiently. It is emphasized that directly connecting the sine wave generator output to an op-amp input without a proper feedback network results in the op-amp acting as a comparator, producing a square wave instead of an amplified sine wave. Proper negative feedback resistor networks are necessary to set the gain and maintain waveform integrity. Additional considerations include understanding the transistor biasing for linear operation, the type of coupling (AC or DC) between stages, and the desired amplification parameters (voltage, current, or power). Using an op-amp buffer stage before the amplifier input is a common solution to drive the transistor effectively without distortion.
