Best 8-bit Microcontroller for LEDs, Motor Control, USB Programming: PIC, Atmel, Arduino?
315 20
Which beginner microcontroller kit should I buy for a small LED-and-motor project that must be programmable over USB?
For a beginner, the easiest path is an Arduino UNO or a PICAXE board, both of which can be programmed from a laptop over USB, with Arduino offering the broadest example base and PICAXE being the simplest BASIC-based option [#21661796][#21661801][#21661806][#21661810] Arduino is described as the easiest to get started with because it comes as a working board with an IDE, one-click upload, and plenty of motor-control add-ons [#21661796][#21661806][#21661810] PICAXE is also recommended for education because it uses BASIC, needs only a USB programming cable plus a breadboard and a few resistors, and comes in versions from 8-pin to 40-pin [#21661801][#21661807] If you want a standard PIC instead, replies suggest starting with a smaller device such as the PIC16F88, while warning that the PIC16F877A is likely more complex than you need for this project [#21661797][#21661798][#21661808] For the motor, use an H-bridge driver and consider PWM for speed control, and don’t forget switch debouncing and noise suppression because motors can upset the ports and reset circuitry [#21661808][#21661815]
  • Recommend Arduino for simple USB programming
    #1 21661795
    Peter Emson
  • #2 21661796
    Stephen Shaffer
  • #3 21661797
    Ashesh Sharma
  • Start with a PIC16F877 kit and MPLAB tutorials
    #4 21661798
    sachin Kothari
  • Considering the PIC16F877 as a simpler choice
    #5 21661799
    Peter Emson
  • #6 21661800
    Ashesh Sharma
  • PICAXE as an easy PIC microcontroller option
    #7 21661801
    Frank Bushnell
  • #8 21661802
    Hiren Niranjani
  • #9 21661803
    Swap Pamecha
  • #10 21661804
    Swap Pamecha
  • #11 21661805
    Peter Emson
  • Arduino easiest for beginners and motor control addons
    #12 21661806
    Per Zackrisson
  • Picaxe recommended as easiest starter platform
    #13 21661807
    Frank Bushnell
  • Recommend H-bridge PWM and PIC16F88 basics
    #14 21661808
    Mark Harrington
  • #15 21661809
    Mark Harrington
  • Arduino uses C/C++ and includes USB programming tools
    #16 21661810
    Per Zackrisson
  • Microchip recommendation over Arduino for easier use
    #17 21661811
    Mark Harrington
  • Arduino IDE uses Java, not OOP complexity
    #18 21661812
    Mark Harrington
  • Recommend starting with PIC16F88 and C basics
    #19 21661813
    Mark Harrington
  • #20 21661814
    Peter Emson
  • Simple microcontroller choice and noise-handling advice
    #21 21661815
    Mark Harrington
The discussion focuses on selecting the best 8-bit microcontroller for a university project involving LED and motor control with switch inputs, emphasizing ease of programming via USB. Arduino UNO is recommended for beginners due to its simplicity, integrated USB programming, extensive community support, and use of Atmel chips. PIC microcontrollers, particularly the PIC16F877A, are also suggested for their wide availability, robust development tools (MPLAB IDE, free C compiler), and suitability for embedded applications, though they may require more initial learning. PICAXE microcontrollers offer an easy BASIC programming environment and USB programming cable but require purchasing pre-programmed chips, limiting flexibility. Philips 89v51rd2 is mentioned as an option for beginners with USB-to-serial converters for programming. The importance of using H-bridge drivers (e.g., HIP4080A) for motor control with PWM and reverse capability is noted. The debate includes considerations about programming complexity, with some advising starting with simpler C programming on PIC before moving to Arduino's C++-based environment. Overall, Arduino is favored for quick start and ease, while PIC offers deeper learning and flexibility. USB programming compatibility is a key factor, with Arduino and PIC kits providing suitable solutions.
TL;DR: For simple LEDs and a DC motor, Arduino boards cost about $25–35 and “With arduino you can start direct.” [Elektroda, Per Zackrisson, post #21661806]
Why it matters: This FAQ helps students and beginners pick a USB‑programmable 8‑bit platform fast, avoid dead ends, and ship a working demo.
What’s the best 8‑bit microcontroller to start with for LEDs and a motor?
Start with an Arduino UNO. It’s beginner‑friendly, USB‑programmable, and has many motor control shields. “With arduino you can start direct.” Price runs about $25–35, which keeps total cost down for a class project. [Elektroda, Per Zackrisson, post #21661806]
Is ARM better than 8‑bit for this project?
ARM gives more speed per dollar, but setup is tougher for a newcomer. For a first build with switches, LEDs, and one motor, focus on finishing quickly with Arduino, then explore ARM later if you enjoy it. “ANY ARM platform is likely faster.” [Elektroda, Stephen Shaffer, post #21661796]
Can I program everything over USB if my laptop has no serial/parallel ports?
Yes. Arduino programs directly over USB. For microcontrollers that expect UART, use a USB‑to‑serial converter. That adapter is inexpensive and common, enabling bootloading or in‑system programming from modern laptops. [Elektroda, Hiren Niranjani, post #21661802]
What is PICAXE, and is it flexible enough for coursework?
PICAXE is a PIC with a preloaded BASIC firmware, very easy for education. However, it doesn’t run on blank PICs, so you must buy PICAXE‑branded chips. That reduces flexibility if you later want raw PIC devices. [Elektroda, Peter Emson, post #21661805]
Which PIC should I consider if I skip Arduino?
For fundamentals, consider a small PIC like the 16F88. It’s simpler than the feature‑heavy 16F877A and suits learning timers, interrupts, and I/O without overload. Expect low chip cost and free IDE/compiler options. [Elektroda, Mark Harrington, post #21661808]
Is the PIC16F877A a good first chip?
It works, but it’s overkill for a first project. Its multiple timers and peripherals increase complexity. If you are new, start simpler, then graduate once you’re comfortable with flowcharts, debouncing, and fuse settings. [Elektroda, Mark Harrington, post #21661808]
How do I reverse and vary the speed of a DC motor safely?
Use an H‑bridge driver for direction and PWM for speed control. Plan current margins and switching losses. A dedicated H‑bridge driver IC simplifies design and protects your microcontroller from back‑EMF and noise. [Elektroda, Mark Harrington, post #21661808]
What is an H‑bridge in plain terms?
An H‑bridge is a four‑switch circuit that lets you drive a DC motor forward or reverse by flipping current direction. Pair it with PWM from your microcontroller for smooth speed control. [Elektroda, Mark Harrington, post #21661808]
Any gotchas when using motors next to microcontrollers?
Yes. Motor noise can corrupt registers or cause resets. Add decoupling, proper grounding, and consider brownout detection. Place bulk and ceramic capacitors near regulators and drivers to suppress transients. [Elektroda, Mark Harrington, post #21661815]
I just need LEDs and one motor—why not jump straight to C++ and OOP?
You can, but mastering embedded basics first reduces bugs and time lost. Learn I/O, debouncing, timers, and simple C. Then move to richer frameworks with confidence. “Get the basics right.” [Elektroda, Mark Harrington, post #21661813]
How much will a starter Arduino setup cost me?
Typical boards cost about $25–35, and you can program over USB out of the box. Add a low‑cost motor shield or driver, and your class project stays very affordable compared to full dev kits. [Elektroda, Per Zackrisson, post #21661806]
What’s a quick USB programming workflow without a built‑in programmer?
Try this: 1) Build or buy a USB‑to‑serial converter. 2) Install its driver and your chip’s programming tool. 3) Connect RX/TX and reset per the reference design, then flash. [Elektroda, Mark Harrington, post #21661809]
Is Arduino really C/C++ under the hood?
Yes. The Arduino language is a set of C/C++ functions compiled by avr‑g++. You write sketches, the IDE generates prototypes, and uploads over USB. The learning curve stays gentle for newcomers. [Elektroda, Per Zackrisson, post #21661810]
Do I need Java knowledge to use the Arduino IDE?
No. The IDE is written in Java, but users don’t code in Java to program boards. You install it and write C/C++ style sketches; the toolchain handles the rest. [Elektroda, Per Zackrisson, post #21661810]
What’s a budget alternative to full dev boards?
Use a low‑cost PIC on breadboard plus a simple programmer. One post cites PIC chips around £2.05. You’ll learn power, clocking, fuses, and programming interfaces directly. [Elektroda, Mark Harrington, post #21661808]
Any simple LED/motor demo idea that scores marks?
Implement debounced switches, PWM speed control, and direction with an H‑bridge. Document flowcharts and algorithms; tutors value process. Add serial prints for telemetry to showcase understanding. [Elektroda, Mark Harrington, post #21661808]
