LM392 Dual Comparator Circuit for Accurate Real-Time Temperature Differential Sensing
246 7
  • Request for LM392 improvements and reference material
    #1 21662165
    Tony Matteo
  • #2 21662166
    Frank Bushnell
  • PNP 2N4403 replaces 2N2222 and 100 kΩ removed
    #3 21662167
    Tony Matteo
  • #4 21662168
    Frank Bushnell
  • #5 21662169
    Tony Matteo
  • Pin 4 grounding and nulling pot bias suggestion
    #6 21662170
    Frank Bushnell
  • Request for simpler explanation of LM392 external parts
    #7 21662171
    Tony Matteo
The discussion centers on designing an accurate real-time temperature differential sensing circuit using the LM392 dual comparator IC, targeting a precision of 0.5°F or better. The project involves comparing two thermistors at a single location to detect minute temperature differences as low as 0.025°F across multiple sensor arrays (up to eight sensors). The temperature measurements cover various surfaces including liquids, air, metals, and skin, with applications in performance efficiency monitoring and early heat-related indicators. Circuit improvements suggested include proper grounding of pin 4 on the LM392, adjusting the nulling potentiometer to provide an intermediate voltage (around half Vcc) for stable output, and considering an output proportional to temperature difference rather than a simple comparator on/off signal. The author seeks clearer, practical explanations of how external components affect the LM392 output to enhance understanding and circuit accuracy within a working range of -5°C to 5°C. Reference material on operational amplifiers was recommended to aid comprehension of the IC’s behavior and design considerations.
