IC for generating 1-10Hz dual phase-shifted square waves, alternative to TL494?
288 10
  • #1 21662254
    Gunther Sator
  • #2 21662255
    Mark Harrington
  • #3 21662256
    DAVID CUTHBERT
  • #4 21662257
    Gunther Sator
  • #5 21662258
    Gunther Sator
  • #6 21662259
    DAVID CUTHBERT
  • #7 21662260
    Gunther Sator
  • #8 21662261
    Mark Harrington
  • #10 21662263
    Gunther Sator
  • #11 21662264
    Gunther Sator
✨ The discussion addresses the need for an integrated circuit alternative to the TL494 capable of generating dual phase-shifted square waves at very low frequencies (1 to 10 Hz). The TL494 is noted to operate typically between 300 kHz and 500 kHz, making it unsuitable for low-frequency applications. Suggestions include using microcontrollers such as PIC or Atmel to program custom PWM outputs with adjustable timing and fault detection routines. Another proposed solution involves the CD4017 decade counter IC combined with diode ORing to create two square waves with dead time; the 4017 can operate from DC up to about 1 MHz, but precise phase adjustment may be challenging. Additional recommendations include circuits using D-type flip-flops and 555 timer-based PWM configurations to achieve adjustable dead times and phase shifts. Analog Devices programmable PWM ICs operating around 78 Hz were also mentioned as a workaround. Overall, the discussion highlights trade-offs between simplicity, frequency range, and phase control precision when selecting components for low-frequency dual phase-shifted square wave generation.
